What's the Ideal Pool Temperature? Comfort, Science & Cost
What temperature should I keep my pool? My kids beg for warm, but I'm in Minnesota and don't want to waste money
Every summer it's the same argument. The kids climb out shivering and beg me to crank the heater, but I'm staring at the energy bill thinking about how short our Minnesota season is anyway. Is there an actual *right* temperature for a pool, or is it just personal preference? I keep hearing different numbers — Disney pools, the Olympics, swim lessons — and they're all over the place. What does the science actually say, and where's the sweet spot between happy kids and a heating bill I can live with?
For most families the ideal pool temperature is 80-82°F, the all-purpose comfort zone Disney uses for its resort pools. The Dept. of Energy puts the normal range at 78-82°F; competition pools run cooler (77-82°F) and infant lessons much warmer. Water pulls body heat about 25x faster than air, so even 80°F feels cool. Active, cold-tolerant families can run cooler and save money; in a cold climate every 1°F costs roughly 10-30% more to heat, so a good cover beats chasing 86°F.
The Ideal Pool Temperature by Use and Swimmer
There is no single "correct" temperature because it depends entirely on who is in the water and what they are doing. Here is how the major guidelines and well-known pools break down:
| Use / Swimmer | Recommended Temp | Who says so |
| Lap swimming & fitness | 78°F | American Red Cross |
| Relaxed recreation / family play | 82-84°F | Common comfort guidance |
| Disney resort pools | 82°F year-round | Walt Disney World |
| Competition / Olympic swimming | 77-82°F (25-28°C) | World Aquatics (FINA) |
| Young kids, seniors, arthritis / therapy | 83-88°F | Common therapy-pool guidance |
| Infant & toddler swim lessons | 87-93°F (around 90°F) | Swim-school guidance |
| Hot tub / spa (for reference) | 100-104°F | 104°F safety max (CDC) |
For reference, the U.S. Department of Energy puts the normal range at 78-82°F, and suggests 80°F or warmer for young children and older swimmers; the American Red Cross recommends 78°F for competitive swimming. The 82-84°F "family comfort" figure is practical guidance rather than an official standard.
Notice that the "fun for kids" number and the "fast for racing" number are almost opposites. Competitive pools are kept cool on purpose, while your kids want it warm. More on why below.
The Science: Why 80°F Water Feels Cold but 80°F Air Feels Warm
This is the part most people get wrong, and it explains the whole argument with your kids. Water pulls heat out of your body roughly 25 times faster than air at the same temperature. Water is far denser than air and has a much higher heat capacity, so it carries warmth away from your skin far more aggressively.
Your body sits at about 98.6°F. Any water cooler than that is constantly drawing heat out of you. On a 95°F afternoon the air feels great, but step into 80°F water and it feels chilly, because that water is stripping warmth from your skin much faster than the air ever could. Kids feel this even more sharply: a child has more skin surface relative to body mass than an adult, so they lose heat faster and start shivering sooner. That is not them being dramatic, it is physics.
It is also why "warm" is relative to time. You can be comfortable for ten minutes at 78°F and chilled after an hour. In fact, prolonged immersion can chill a person even in water as warm as the mid-80s, which is exactly why swim schools keep lesson pools so warm and limit little kids to about 30 minutes.
The Famous Numbers, Explained
Why Disney keeps resort pools at 82°F
Walt Disney World heats its resort pools to a uniform 82°F all year. That is a deliberately chosen "comfortable for the most people" number: warm enough that a typical guest can swim a while without getting cold, but not so warm that it feels like a bath on a hot Florida day. (Their hot tubs, which Disney calls spas, are a separate animal at 104°F.) If you want a single target that pleases a mixed crowd of kids and adults, 82°F is a well-tested answer.
Why Olympic and competition pools are cooler
World Aquatics (formerly FINA) requires competition pools to be 25-28°C, which is 77-82.4°F, and serious meets often sit around 27°C (about 80-81°F). Cooler water helps athletes dump the enormous heat their muscles generate during all-out effort. Push the temperature too high and performance actually drops because the body cannot shed heat fast enough. So the "racing" temperature is built around hard exercise, not lounging, and it would feel cold to your kids floating on a noodle.
Why swim lessons and therapy pools run hot
Infant and preschool lessons are typically held in 87-93°F water (often around 90°F) because small children chill so fast. The same warm-water logic applies to seniors and anyone using the pool for arthritis relief or gentle therapy, where 83-88°F keeps muscles loose and comfortable for slow movement. The trade-off: that water feels muggy and unrefreshing for active swimming, and it is expensive to maintain.
Can a Pool Be Too Warm? Yes.
Warmer is not automatically better, and there are real reasons not to just crank it to 88°F:
- Warm water gives some germs an easier environment. Higher temperatures can speed bacterial growth, which is part of why hot tubs are the highest-risk recreational water environment for illness. The warmer your pool, the harder your sanitizer has to work to keep up.
- Warm water can increase sanitizer demand. Heat speeds up the reactions that consume free chlorine, so a hot pool can need noticeably more sanitizer and more attention to stay safe and clear.
- It stops being refreshing. On a 90°F day, 86°F water gives you nowhere to cool off. Part of the joy of a pool in summer is the contrast.
- Cost. Covered next, but warm water is the single biggest lever on your heating bill.
None of this means a warm pool is dangerous if you keep your chemistry in check. It just means "as warm as possible" is the wrong goal. Keep your sanitizer at the right level for your stabilizer (CYACyanuric Acid (stabilizer) — Sunscreen for your chlorine — it keeps sunlight from burning it off. The catch: the more you have, the more chlorine you need to keep. learn more →), and warmer water simply means staying on top of it.
Cooler Water Can Be Fine: It Depends on the Swimmer
Here is the honest counterpoint to the whole "kids want it warm" assumption: plenty of kids will happily swim in 65-75°F water when they are active, excited, and taking breaks. The comfort ranges above are typical setpoints for longer, casual swimming — they are not safety cutoffs. Whether a cooler pool feels fine has less to do with the number on the gauge and more to do with:
- How long they stay in
- Whether they are actively moving or just floating
- Wind and air temperature
- Body size and age (smaller kids chill faster)
- Whether there is an easy way to warm up afterward
- Whether they are starting to shiver, getting clumsy, or pushing through discomfort
If your kids are active swimmers and have a warm-up option nearby — a hot tub, dry towels, or warm sun — they may be perfectly happy in 65-75°F water for shorter sessions. A cold-tolerant family can run the pool cooler and save real money on heating. There is nothing wrong with a "cool but fun" pool if everyone is comfortable.
One safety caveat: cooler water is fine when swimmers are comfortable and supervised, but don't use a hot tub as a way to push a child past shivering or numbness. If a child is shaking, unusually quiet, clumsy, or asking to get out, that is the call — warm them up and end the swim. Shivering is the body's signal, not a phase to power through, and (as covered above) water pulls heat from a small body fast.
The Minnesota Math: What Each Degree Actually Costs
Here is the part that matters for a cold-climate budget. Raising your pool's temperature by just 1°F can increase heating costs by roughly 10-30%, according to the U.S. Department of Energy. The exact figure depends on your climate, wind, and how often you swim, but the principle holds: going from 80°F to 84°F is not a small bump, it can be a large chunk of your seasonal heating bill.
The reason is evaporation, which is by far the biggest way pools lose heat. When a pound of 80°F water evaporates off the surface, it carries away over 1,000 Btu of heat with it. Every breezy evening, your pool is quietly throwing away the energy you paid to put in. The warmer the water, the faster it evaporates, which is why the cost curve gets steep at the top end.
The single most effective fix is also the cheapest: a pool cover. The U.S. Department of Energy notes that covering a pool when it is not in use can cut heating costs by 50-70%, and the EPA's WaterSense program reports that a solid cover can reduce evaporation by more than 90%. In Minnesota, where the season is short and the night air is cool, a solar or bubble cover does more for your bill than any thermostat setting. A cover lets you run a lower setpoint and still have warm water when the kids get home.
So What Should You Set It To?
For a Minnesota family pool, here is the practical answer that keeps the kids happy without lighting money on fire:
- Set the thermostat to 80-82°F. This is the Disney-style "comfortable for everyone" zone. The kids will stay in far longer than they would at 76°F, and you are not paying for bathwater.
- Buy a pool cover and actually use it. This is the highest-value move you can make. It cuts evaporation, holds the day's solar warmth overnight, and lets you keep the heater setpoint lower. In a short cold-climate season it pays for itself fast.
- Let the sun do the work. An uncovered pool gains heat free during sunny afternoons. A cover at night locks it in, so you may barely need the heater on warm-week stretches.
- Drop the setpoint when nobody's swimming. If you are away for a few days, lower it. Reheating a few degrees costs less than holding 82°F against the night air all week.
- Get a real thermometer. Many heater displays drift. Knowing the true number ends the "it's freezing!" debate and helps you find your family's exact comfort line.
If your crew skews young, you may settle around 83-84°F and lean harder on a cover to manage cost. If you swim laps yourself, you will be happier at 80°F and the kids will adjust. Either way, the honest sweet spot for most families lands at 80-82°F with a cover — warm enough to win the argument, cool enough to keep the bill sane.
Bottom Line
There is no single magic number, just the one that fits your swimmers and your budget: cooler for fitness, warmer for little kids and therapy, and 82°F as the safe crowd-pleaser. Remember that water always feels cooler than the gauge reads, and that each degree adds 10-30% to your heating bill — so in a cold climate, a good cover does more for comfort-per-dollar than a higher thermostat ever will.
Sources
- U.S. Department of Energy – Managing Swimming Pool Temperature for Energy Efficiency
- U.S. Department of Energy – Swimming Pool Covers
- EPA WaterSense – Outdoor Pool Water Efficiency Guide
- CDC – Controlling Legionella in Hot Tubs
- World Aquatics (formerly FINA) Facilities Rules – competition pool water temperature 25–28°C
