Heaters Heaters — Do I Need Pool Heating in Orlando in May? Temperature Guide
Tom I.
Tom I.
Weekend Pool Warrior
Orlando pool heating in May - worth it for comfort swimming?
My neighbor insists pool heating is pointless in Orlando by May, the pool store says my 18,000-gallon inground absolutely needs it, and YouTube videos are giving me completely different advice.
I've been checking the water temperature with a digital thermometer, and it's been running around 78-80°F during the day in May, which feels okay but not quite warm enough for extended swimming sessions. My family prefers the water to feel really comfortable, more like 82-84°F if possible. We're early risers and often want to use the pool around 7 AM, plus evening swims are important for our routine.
Is pool heating typically necessary in Orlando during May, or do most people find the natural temperatures comfortable enough? I'm wondering if a heater would be worth the investment to extend our daily swimming hours and make the water more inviting for the whole family.
In Orlando, May pool temperatures typically reach 78-82°F naturally, making heating optional for most swimmers. However, if you prefer water temperatures above 82°F or have early morning/evening swimmers, a heater can extend comfortable swimming hours.
Orlando May Pool Temperature Expectations
Orlando's May climate creates favorable conditions for unheated pools. Average air temperatures range from roughly 66-89°F, with highs typically in the mid-to-upper 80s and increasing sunshine hours warming pool water naturally. Unheated pools typically maintain:
  • Early May: 76-79°F as spring transitions to summer
  • Mid to Late May: 78-82°F with consistent warming
  • Nighttime temperatures: 4-6°F cooler than daytime peaks
  • Cloudy/rainy days: Can drop 3-5°F below normal ranges
These temperatures fall within the comfortable swimming range for most people (78-82°F), making May one of the first months many Orlando pool owners can swim comfortably without heating.
When You Might Still Need Heating in May
Temperature Preferences Above 82°F
If your family prefers warmer water (83-86°F), heating remains beneficial in May. Children, elderly swimmers, and those using pools for therapy often require higher temperatures for comfort and safety.
Early Morning and Evening Swimming
Pool temperatures drop overnight, especially after cool fronts. Morning temperatures can be 4-6°F lower than afternoon peaks. If you swim before 10 AM or after 7 PM regularly, heating ensures consistent comfort.
Weather Variability
May occasionally brings unseasonably cool periods. Late-season cold fronts can drop air temperatures into the 60s, significantly cooling pool water. Having heating capability provides flexibility during these temporary cool spells.
Pool Construction and Exposure
Certain pool characteristics affect heating needs:
  • Shaded pools: Trees or structures blocking sunlight keep water cooler
  • Large surface area: more exposed water surface increases evaporative heat loss
  • Depth: Deeper pools take longer to warm naturally
  • Pool finish: Dark finishes absorb more solar heat than light colors
Heating Options for Orlando May Weather
Solar Heating Systems
May's increasing sunshine makes solar heating highly effective. Solar systems can add 3-6°F to your pool temperature, turning a 78°F natural temperature into a comfortable 81-84°F. Installation costs range from $3,000-6,000, but operating costs are minimal since Orlando receives abundant sunshine in May.
Heat Pumps
Heat pumps work efficiently in May's mild temperatures, extracting heat from warm 80s daytime air. They're cost-effective for maintaining desired temperatures with typical operating costs of $50-100 monthly for moderate use. Heat pumps excel at maintaining consistent temperatures rather than rapid heating.
Gas Heaters
Gas heaters provide rapid heating when needed but have higher operating costs ($100-250 monthly with regular use). They're ideal for occasional heating during cool spells rather than constant use in May's generally warm conditions.
Cost Considerations for May Heating
Heating costs in May are significantly lower than winter months due to smaller temperature differentials. Natural gas costs approximately $3-6 per degree of temperature increase per day for a typical 15,000-20,000 gallon pool, while heat pumps cost $1-3 per degree increase daily for a typical 15,000-20,000 gallon pool. Solar heating, after initial investment, costs virtually nothing to operate.
Consider these factors when evaluating May heating costs:
  • Pool size: Larger pools require proportionally more energy
  • Desired temperature increase: Each degree costs more incrementally
  • Usage patterns: Heating only when needed reduces costs significantly
  • Pool cover usage: Covers can reduce heating costs by 50-70%
Energy-Efficient May Heating Strategies
Use Pool Covers
Pool covers retain heat gained during warm May days, often eliminating heating needs entirely. A good cover can maintain water temperature 3-6°F warmer overnight.
Optimize Heating Schedules
Program heaters to activate only before swimming times rather than maintaining constant temperatures. May's warm air temperatures allow pools to retain heat well between uses.
Combine Heating Methods
Use solar heating as your primary method with backup gas or electric heating for cloudy periods or temperature boosts.
Don't over-heat in May: Many pool owners maintain winter heating schedules unnecessarily, wasting energy when natural temperatures are adequate.
Avoid ignoring weather forecasts: Plan heating around expected temperature drops rather than reacting after pools cool.
Don't neglect pool covers: Even in May, covers significantly improve heating efficiency and reduce costs.
Making Your Decision
Most Orlando pool owners can comfortably swim without heating by mid-May. Consider heating if you prefer temperatures above 82°F, swim during cooler morning/evening hours, or want flexibility during occasional cool weather. Solar heating offers the best long-term value for May conditions, while heat pumps provide reliable temperature control for moderate costs.
Recommended for this job
LuxBlue Floating Pool Thermometer, Solar, Large LCD Easy-read floating thermometer for pool water temperature. View on Amazon →
Tags: #orlando #may #pool-heating #temperature #seasonal
