DIY Pool Closing vs. Hiring a Pro: What to Know
Can I winterize my inground pool myself, or hire a pro?
My pool company just quoted me to close our inground pool for winter, and the number made me stop and think—how hard can this actually be? My pool is a standard rectangular inground with a single-speed pump, sand filter, and a basic chlorinator. Nothing exotic, no water features or fancy automation.
I'm reasonably handy around the house and comfortable following detailed instructions, but I've never closed a pool before. I'd rather not accidentally crack a pipe or ruin equipment just because I skipped a step or didn't have the right tool.
What does the closing process actually involve, what gear do I need, and which specific steps are the ones where a first-timer is most likely to cause expensive damage? Is it worth attempting myself, or should I just write the check and let the pros handle it?
You can absolutely close your inground pool yourself if you're methodical and have the right equipment, but a few specific steps—particularly blowing out the plumbing lines and balancing water chemistry—are where first-timers most often cause costly freeze damage. A professional closing typically takes about two hours and carries very low risk of error; DIY takes four to eight hours and raises that risk significantly. A smart middle ground: handle the simple prep yourself and let a pro tackle th
The Honest Answer: Yes, With Proper Planning
Closing an inground pool is a DIY project many can tackle, but it demands methodical care and focus on a few key details. The job consists of a series of simple preparations and a couple of precise, high-stakes actions. Your success come spring largely rests on two things: getting all the water out of the pipes and starting with correctly balanced pool water. The remaining steps set the stage for these primary objectives.
If you have a basic inground pool with a pump, sand filter, and regular return fittings, the process is within reach. Use this guide, paying special mind to the most vital sections.
What You'll Need
- Reliable water test kit (for accurate pre-closing readings, liquid or drop-test kits are preferable to test strips)
- Winter chemical package (often contains pH and alkalinity adjusters, shock, algaecide, and a stain or metal inhibitor)
- Air compressor or dedicated pool line blower with steady, strong airflow – this tool is essential
- Winterizing plug set that fits your pool's return jets and skimmer opening
- Gizzmo or similar compressible skimmer guard (to absorb potential ice pressure)
- Winter pool cover with an anchoring method (clips, water tubes, or weights)
- Standard cleaning gear (pool brush, leaf net, and vacuum)
- Propylene glycol pool/RV antifreeze (optional – see the line-clearing instructions)
Step-by-Step Closing Process
Clean the Pool Thoroughly
Brush the pool's walls and floor, then vacuum out all debris. Run the filter long enough to circulate the now-clean water. Beginning winter with a dirty pool traps organic material and algae spores, guaranteeing a more challenging reopening. A spotless pool now simplifies your spring.
Balance the Water Chemistry – The Critical Base Layer
Test and adjust all main water parameters before adding any winterizing chemicals. Properly balanced water safeguards your pool's surfaces and equipment from scale or corrosion over the off-season. Target these general ranges: pH 7.4–7.6, total alkalinity 80–120 ppm, and for plaster pools, calcium hardness 200–400 ppm. Your free chlorine level is not a fixed value; it must scale with your existing cyanuric acid (CYACyanuric Acid (stabilizer) — Sunscreen for your chlorine — it keeps sunlight from burning it off. The catch: the more you have, the more chlorine you need to keep. learn more →, or stabilizer) level. To understand this relationship, see our pool water chemistry guide or try our pool calculator. Once balanced, add a shock treatment and let the pump circulate it fully, ideally overnight.
Add Final Winterizing Chemicals
With the pump still running, add algaecide and any stain or scale prevention products as directed on their labels. Circulate these thoroughly before you shut the system down for winter. Do not combine algaecide with chlorine shock, as the shock can neutralize many algaecides. Add shock first, let it circulate and reduce, then follow the specific timing instructions for the algaecide.
Remove and Store Accessories
Take out ladders, handrails, diving boards (if applicable), skimmer baskets, and return jet fittings. Clean, dry, and store these items indoors or in a protected spot to avoid damage and staining.
Lower the Pool Water Level
The correct water level depends completely on your specific winter cover. Your cover manufacturer's instructions are the final authority. For a general idea on how far to lower the water: solid covers often only require a drop of 3–6 inches below the skimmer, since rain and snow will pool on top; mesh covers allow water through, so the common guidance is to go lower, typically 12–18 inches below the skimmer, though vinyl pools have a milder option. Always defer to your cover manual.
Clear and Plug the Plumbing – The Most Vital Step
This is the most technical part of closing and the most common source of expensive winter damage for DIY attempts. Water left inside pipes can freeze and expand, cracking PVC pipes or fittings and leading to major repairs.
Using your air compressor or blower, push air through each plumbing line at the equipment pad until a steady stream of air bubbles emerges at the corresponding outlet in the pool. Handle one line at a time. The instant a return jet is blowing only air, swiftly insert its winter plug to seal it. For the skimmer line: blow it clear, then install a Gizzmo or rubber plug directly into the port at the skimmer's base. The Gizzmo acts as a compressible cushion against any leftover water. Finally, place the skimmer winterizing cover plate.
If the pool has a main drain, you do not plug it at the pool floor; blow air down it until bubbles rise in the deep end, then shut its valve at the equipment pad while air is still flowing, creating an air lock in the pipe.
Note: If you are unsure a line is fully empty, you may optionally pour non-toxic propylene glycol pool/RV antifreeze into that specific line just before plugging it as an added safety measure. However, antifreeze is not a substitute for blowing out lines and should never be poured into an open skimmer well or the pool water itself. It serves only as a targeted backup for a line you suspect may hold some water.
Winterize the Equipment Pad
Drain all water from the pump, filter, heater (if present), and chlorinator. Remove drain plugs, clean them, and store them somewhere you won't forget (some people tape them inside the pump basket lid). Lubricate o-rings before storing. For sand filters, check your owner's manual for the correct multiport valve storage setting—some models have a "Winterize" position, while others should be left between functions. An incorrect valve position can result in a cracked valve body.
Install the Winter Cover Securely
Lay out your winter cover and anchor it firmly all the way around using the appropriate clips, water tubes, or weights. A cover that pulls loose or droops into the pool can undermine your entire winterizing effort. For safety covers, adjust all anchor springs to the proper tension.
Common DIY Closing Mistakes
Based on frequent reports from pool owners and service pros, the most typical errors are: not fully clearing water from a plumbing line (causing freeze-related cracks), rushing or skipping water chemistry balancing (leading to scale, stains, or corrosion over the winter), and leaving equipment drain plugs in place (which can result in cracked housings). These oversights are often responsible for the costly repairs found at opening.
Should You Just Hire a Pro?
If you have any doubts about safely clearing the plumbing lines—especially if your pool has a main drain, many return lines, or complex suction-side plumbing—considering a professional is a wise move. A technician will use a high-powered, dedicated blower, accurately identify all lines, and bring hands-on experience. The time saved is real, and there is clear value in having an expert perform the highest-risk steps.
A practical middle ground is to do the cleaning, accessory removal, and chemistry balancing yourself (these are simpler tasks) and then hire a pro exclusively for the line-blowing and equipment pad winterization. This approach lowers the cost, transfers the risk of the most critical steps, and lets you watch the process for possible future DIY efforts.
For a full, printable checklist covering different equipment setups, consult our detailed pool winterization guide.
