Maintenance Maintenance — Can You Swim During Your Period? Pool Safety & Hygiene Guide
Kim X.
Kim X.
Pool Service Hobbyist
Is it safe to swim on my period? Pool hygiene concerns
Wondering why my period only seems to show up when it's scorching hot outside and I desperately want to jump in my pool? I've heard mixed things about hygiene and whether the water stays clean enough.
The pool store guy tried to sell me all these expensive "sanitizing boosters" when I mentioned having guests over, but I'm already spending way too much on chemicals as it is. Does regular chlorine actually keep things sanitary enough for swimming during menstruation? And is there any real risk to the water quality or other swimmers?
Yes, you can safely swim during your period. Pool chlorine maintains sanitary conditions, and water pressure may briefly slow your flow underwater but doesn't stop it, so still use a tampon or cup. Free chlorine (FC) levels should be maintained according to the FC/CYA chart, and pH levels should be between 7.2-7.8, with 7.4-7.6 being ideal. Regular testing and chemical balancing ensure a hygienic swimming environment.
How Pool Chemistry Keeps Water Safe
Properly maintained pool water provides a sanitary environment that's safe for swimming during menstruation. Here's how your pool's chemistry works to maintain hygiene:
Free Chlorine Sanitization
Your pool's free chlorine (FCFree Chlorine — The chlorine actively sanitizing your water right now. This is the number you keep an eye on. how much you need →) level should be maintained according to the FC/CYAFC/CYA chart — The chart that sets your chlorine target from your stabilizer (CYA) level — the two go together. see the chart → chart - for example, with 30 ppm CYACyanuric Acid (stabilizer) — Sunscreen for your chlorine — it keeps sunlight from burning it off. The catch: the more you have, the more chlorine you need to keep. learn more → you need at least 2 ppm FC, and with 50 ppm CYA you need at least 4 ppm FC. This chlorine actively kills bacteria, viruses, and other contaminants that might enter the water. When FC levels are properly maintained according to the FC/CYA relationship, any trace amounts of menstrual fluid are immediately sanitized. Properly balanced chlorine kept to the FC/CYA chart is all you need here - you don't have to buy any special "sanitizing booster" product a pool store might push.
pH Balance Impact
Maintaining proper pH levels between 7.2-7.8 ensures chlorine works effectively, with 7.4-7.6 being ideal. If your pH drifts too high (above 7.8), chlorine becomes less effective at sanitizing. Test your water weekly using a reliable test kit like the Taylor K-2006 to ensure optimal sanitization.
Shock Treatment Benefits
Regular shocking with liquid chlorine (sodium hypochlorite) oxidizes organic contaminants. For routine maintenance, add chlorine as needed to maintain proper FC levels based on testing results, or shock to the level for your CYA when addressing water quality issues. This ensures any organic matter is quickly broken down.
Physical Considerations While Swimming
Water Pressure Effects
When you're submerged in water, the hydrostatic pressure naturally reduces menstrual flow. However, this effect is partial and unreliable - flow resumes when you move, stand up, cough, or laugh, so internal protection (a tampon or menstrual cup) is still needed.
Temperature Impact
Cool pool water (typically 78-82°F) can actually help reduce menstrual cramping for many women. The exercise and movement of swimming also releases endorphins that can alleviate period-related discomfort.
Hygiene Best Practices
Before Swimming
  • Use a fresh tampon or menstrual cup immediately before entering the pool
  • Shower before swimming to remove any external bacteria
  • Avoid swimming if you're experiencing heavy flow days and feel uncomfortable
During Swimming
  • Take breaks every 30-45 minutes to check and change protection if needed
  • Stay hydrated, as swimming during menstruation can be more tiring
  • Listen to your body - exit the pool if you feel any discomfort
After Swimming
  • Change out of wet swimwear immediately
  • Shower thoroughly with soap
  • Replace tampon or empty menstrual cup promptly
Pool Maintenance Considerations
Increased Bather Load Adjustments
If you have frequent swimmers during summer months, you may need to adjust your pool chemistry routine:
  • Test chlorine and pH levels twice weekly instead of once
  • Increase chlorine during peak usage based on demand—heavy bather loads and heat raise chlorine use, so adjust to your test results
  • Consider adding a weekly dose of non-chlorine shock (potassium peroxymonosulfate) to oxidize organic contaminants
Filtration System Optimization
Run your pool filter system at least 1 hour per 10°F of water temperature daily (typically 8-12 hours) during heavy use periods. Clean or backwash filters more frequently - every 2-3 weeks instead of monthly. A clean filter removes particles more effectively and helps maintain water clarity.
Common Myths Debunked
"Periods Contaminate Pool Water"
This is false. Properly chlorinated water immediately sanitizes any trace amounts of menstrual fluid. The risk is no different from other bodily fluids like sweat or saliva that routinely enter pools.
"Sharks in Pools" Myth
Some worry about attracting "attention" even in pools. This stems from ocean swimming concerns and doesn't apply to residential pools. Chlorinated water disperses any trace fluid, and there's no shark risk in a residential pool anyway.
"Tampons Don't Work in Water"
Tampons remain effective in water and absorb only minimal water and stay in place during normal swimming (change shortly after you get out).
When to Avoid Swimming
While generally safe, consider avoiding pool swimming if:
  • You're experiencing unusually heavy flow
  • You have severe menstrual cramps that affect mobility
  • You feel weak or dizzy
  • The pool's free chlorine is below the minimum for your CYA (especially near or under 1 ppm) or pH is outside 7.2-7.8 range
Health Benefits of Swimming During Periods
Swimming during menstruation actually offers several benefits:
  • Low-impact exercise that doesn't strain joints
  • Natural pain relief through endorphin release
  • Improved circulation that can reduce bloating
  • Mental health benefits from continued routine exercise
Remember: Your properly maintained pool is designed to handle normal human contact safely. Regular testing and chemical balancing ensure a hygienic swimming environment for everyone, regardless of individual circumstances.
Tags: #swimming safety #pool hygiene #menstruation #water chemistry #bather load
