Maintenance Maintenance — Are Natural Bio Pools Worth It? Costs, Pros & Cons
David O.
David O.
First-time Pool Owner
Are bio pools with plant filtration actually worth it in Wisconsin?
Is this actually a real thing people are doing, or is it more of a niche experiment? I'm curious how the plant zone actually purifies the water, whether it stays clear and safe to swim in, and whether a cold climate like mine would completely kill the concept. Also, is it realistic to convert what I already have, or would I basically be starting from scratch? I'm worried I'm missing some obvious downside that makes this impractical for most homeowners.
Natural bio pools — also called natural swimming pools or swim ponds — are a legitimate alternative to chlorine pools that use a plant-and-gravel regeneration zone to purify water biologically. They work in cold climates like Wisconsin, but come with higher upfront costs (roughly $50,000–$200,000+), a bigger footprint, and ongoing plant care. For the right homeowner they end chemical handling entirely and save the few hundred to few thousand dollars a year a chlorine pool spends on chemicals.
Safety First: What You Need to Know Before Going Chemical-Free
Before getting into the how and why of natural pools, there are a few safety realities worth understanding — especially since you're thinking about eliminating chlorine entirely. Chlorine in a conventional pool isn't just about clarity; it's your primary defense against bacteria and other waterborne pathogens such as E. coli and Giardia. A natural bio pool replaces that chemical barrier with a living biological system, which works — but only when it's properly designed, adequately sized, and actively maintained.
  • Do not attempt a DIY natural pool conversion without proper design guidance. An undersized or poorly balanced regeneration zone can create stagnant, bacteria-harboring water rather than clean swimming water.
  • Water testing still matters. Even without chlorine, you should regularly test pH and monitor for harmful bacterial growth, especially after heavy rain or periods of high swimmer load.
  • Children and immunocompromised swimmers: Natural pool water is safe when the system is functioning correctly, but because there is no chemical residual, a system that's temporarily out of balance poses a higher immediate risk than a chlorinated pool that's slightly off-spec.
  • Frozen pipes and pumps: In Wisconsin winters, any recirculation pump and plumbing serving the filtration zone must be properly winterized or drained to prevent freeze damage — just like a conventional pool.
So How Does a Bio Pool Actually Work?
The concept is genuinely elegant. A natural swimming pool is divided into two connected zones: the swimming zone (your actual pool) and the regeneration zone — a separate, shallow area filled with gravel, rock, and carefully selected aquatic plants. Water is slowly and continuously circulated from the swim zone through the regeneration zone and back again.
In that plant bed, a thriving community of beneficial bacteria colonizes the gravel substrate and the root systems of the plants. These microorganisms break down phosphates, nitrates, and organic waste — the same nutrients that feed algae and harbor bacteria in a conventional pool. The plants themselves absorb those nutrients directly. Submerged grasses and oxygenating plants keep dissolved oxygen levels high, which further suppresses harmful anaerobic bacteria. Species commonly used include water lilies, cattails, rushes, and various submerged oxygenators.
The result is water that ranges from crystal clear to a very faint, natural greenish tint depending on design and season. Well-designed and properly maintained natural pools can achieve very low levels of harmful bacteria and pathogens — in some documented cases comparable to conventional pools — without any added chlorine. Independent water quality testing is the best way to verify your specific system's performance. This isn't a fringe concept — it's been established in Europe (particularly Germany and Austria) for several decades and has grown significantly in North America over the past decade or more.
Will It Work in a Wisconsin Winter?
This is the right question to ask, and the good news is: yes, cold climates are absolutely workable. In fact, Wisconsin's winters aren't a dealbreaker — they're just a design consideration. Here's how it plays out:
  • The plant zone goes dormant in winter, just like any perennial garden. The plants die back to their root systems, which remain alive beneath the surface. Come spring, they re-establish and the biological filtration kicks back in.
  • The swimming zone can freeze over on the surface without harming the system. Many natural pool owners in northern climates simply close the swim area for winter, similar to a conventional pool closing. The key is winterizing your pump and any above-grade plumbing — check out our pool winterization guide for general principles that apply here.
  • Spring startup takes patience. After winter dormancy, the biological system needs time — potentially several weeks or longer depending on your climate and spring temperatures — to reactivate before swimming season. Plan on the plants re-establishing and bacterial colonies rebuilding — this is normal and expected, not a failure.
  • Freeze-thaw cycles can stress liner or concrete materials more aggressively than in warmer climates, so the build quality and materials matter more in your region. Discuss freeze-rated construction specs with any builder you consult.
What Does It Actually Cost — And Is Converting Your Existing Pool Realistic?
Here's where the conversation gets real. Natural bio pools are not the budget option. Natural bio pools typically cost significantly more than conventional pools — rough estimates in the industry range widely, but quality installations often start well above the cost of a comparable conventional pool and can climb substantially from there. Get multiple quotes from specialized builders in your region for accurate current pricing. Many natural pool designs allocate a substantial portion of total surface area — often roughly half or more — to the regeneration zone, though the exact ratio varies by design approach, climate, and expected swimmer load. Your builder will determine the right proportion for your site, which means a natural pool typically requires significantly more land than a conventional pool of the same swim area.
Converting an existing conventional pool is possible, but it usually isn't as simple as just adding plants. Most conversions require adding an entirely new regeneration zone adjacent to the existing pool, modifying or replacing the circulation system, and potentially restructuring the pool's depth profile. In many cases, it can be nearly as involved (and costly) as a new build. Get quotes from builders who specialize specifically in natural pools — this is not a general pool contractor job.
On the flip side, you'd eliminate the ongoing chemical costs of a conventional pool — which, depending on your pool size and water chemistry, can run several hundred to a few thousand dollars per year. Over time, those savings close the cost gap meaningfully.
The Honest Catch: It's a Garden, Not Just a Pool
The thing most people don't fully anticipate is that owning a natural pool means you're also maintaining a living aquatic garden — indefinitely. The plants need seasonal pruning, harvesting when they overgrow, and occasional replanting. If the balance tips — too many nutrients from heavy swimmer use, too little plant coverage, or a period of neglect — you can see algae blooms or murky water. It recovers, but it requires attention and some comfort with a living, dynamic system rather than a controlled chemical environment.
If your goal is simply a low-hassle swim season with reliable blue water and minimal reading, a salt water pool might actually be the easier middle ground — it dramatically reduces your hands-on chemical handling without requiring you to manage an ecosystem. But if you're genuinely excited by the idea of a chemical-free, wildlife-friendly, naturally beautiful water feature that doubles as a swimming pool, a bio pool can absolutely deliver that — Wisconsin winters included.
Bottom Line for Your Situation
Natural bio pools are real, proven, and workable in cold northern climates. The core tradeoffs are simple: higher upfront investment, more land required, and ongoing plant stewardship in exchange for zero chemical handling, lower long-term operating costs, and a genuinely healthier swimming experience. For the right homeowner — someone who enjoys gardening, values the environmental angle, and has the budget and yard space — it's often described as one of the most rewarding pool decisions they've made. For someone who just wants clean water with minimal involvement, a conventional or salt pool is still the more practical choice.
Tags: #natural pool #bio pool #chemical-free pool #plant filtration #swim pond #Wisconsin pool #cold climate pool #eco-friendly pool #pool alternatives #pool cost
