How to Lower Pool Alkalinity: Complete Step-by-Step Guide
High alkalinity driving me crazy - how do I actually fix this?
Since that heavy downpour last weekend, my pool's alkalinity skyrocketed to 180 ppm and nothing I've tried will bring it down to normal levels. The water looks okay but I know this high alkalinity is going to cause problems with my pH and make it impossible to balance properly.
I've been throwing chemicals at this thing for weeks and I'm starting to think I'm doing something fundamentally wrong. Can someone please walk me through the exact steps to lower alkalinity? I need specific amounts and timing because clearly winging it isn't working for me anymore.
Lower pool alkalinity by adding muriatic acid to the deep end with the pump running. Add 1 quart per 10,000 gallons to reduce alkalinity by 10 ppm, then test and rebalance pH after 4-6 hours.
Understanding High Alkalinity Problems
Wondering why your pool water stays cloudy and your pH keeps climbing no matter what you do? The answer is simpler than you think. When alkalinity is too high, your pool's pH will constantly rise despite your efforts to lower it, creating a frustrating cycle of chemical adjustments.
The ideal alkalinity range is 80-120 ppm for traditional chlorine pools and 60-80 ppm for salt water generator systems. Lowering alkalinity requires patience since the only safe method involves using acid, which also affects pH.
What You'll Need
Before starting, gather these essential items:
- Reliable test kit (Taylor K-2006 or comparable)
- Muriatic acid (31.45% hydrochloric acid)
- Measuring cup (acid-resistant)
- Safety gear: goggles, gloves, and closed-toe shoes
- Sodium carbonate (soda ash) for pH adjustment
The Acid Demand Method
The most effective approach is the "acid demand" method, which involves adding larger doses of muriatic acid while monitoring pH closely. This method is more efficient than small, frequent additions.
Calculating Your Acid Dose
For muriatic acid (31.45% strength):
- 1 quart per 10,000 gallons reduces TA by approximately 10 ppm
- 1 gallon per 10,000 gallons reduces TA by approximately 40 ppm
- Always round down for safety - you can add more later
For a 20,000-gallon pool with 150 ppm alkalinity targeting 100 ppm:
You need to reduce TA by 50 ppm, so add approximately 5 quarts of muriatic acid (50 ppm ÷ 10 ppm per quart × 2 pools worth).
Step-by-Step Application Process
Safety First
Never add acid without proper safety equipment. Muriatic acid can cause severe burns and respiratory irritation. Work in well-ventilated areas and keep a water source nearby.
Application Procedure
- Test current TA and pH levels using a reliable test kit
- Calculate required acid dose based on your pool size
- Ensure pool pump is running for proper circulation
- Put on safety gear: goggles, gloves, and appropriate clothing. Position yourself on the downwind side and avoid breathing acid vapors
- Measure acid carefully using an acid-resistant container
- Pour acid slowly into the deepest part of the pool near return jets for proper mixing, never the shallow end
- Pour in one location - do not walk around while pouring
- Allow pump to run for at least 4-6 hours for complete mixing
- Never swim during treatment - wait at least 4-6 hours after acid addition and until pH is above 7.0 before swimming
- Retest both TA and pH levels
- Repeat process if necessary, waiting at least 6 hours between applications
Managing pH During the Process
Muriatic acid will significantly lower your pH, often dropping it below 7.0. This is normal and expected. Do not add soda ash to raise pH until you've reached your target alkalinity. Adding base too early will increase alkalinity again, forcing you to start over.
Once your alkalinity reaches the desired level, use sodium carbonate (soda ash) to bring pH back to 7.4-7.6. Add 8-12 ounces of soda ash per 10,000 gallons to raise pH by approximately 0.2 units.
Alternative: Aeration Method
For those uncomfortable with large acid doses, you can use the aeration method:
- Lower pH to 7.0-7.2 using muriatic acid
- Run pool equipment continuously
- Add fountain features, point returns upward, or use air blower
- pH will naturally rise due to aeration, consuming alkalinity
- When pH reaches 7.6, add small amounts of acid to lower it again
- Repeat until alkalinity drops to desired level
This method takes 2-7 days but uses less acid overall.
Testing and Monitoring Schedule
Test alkalinity and pH:
- Before starting the process
- 4-6 hours after each acid addition
- Daily during the adjustment process
- Weekly once balanced
Use only reliable test kits like the Taylor K-2006. Test strips are insufficient for accurate alkalinity readings during adjustment periods.
Don't add acid to a skimmer or return line - this can damage equipment. Never mix chemicals together, and always add acid to water, never water to acid. Avoid adjusting pH while lowering alkalinity, as this prolongs the process and wastes chemicals.
Be patient with the process. Rushing by adding too much acid at once can damage pool surfaces and equipment while creating unsafe swimming conditions.
