How Is Pool Chlorine Made? Complete Manufacturing Guide
What's the actual manufacturing process for pool chlorine?
Always assumed pool chlorine was just bleach in a fancy package until my chemistry teacher neighbor said it's actually manufactured completely differently. Now I'm curious — what exactly goes into making pool chlorine and is there really a difference between the cheap and expensive stuff?
Pool chlorine is primarily made by reacting chlorine gas with sodium hydroxide (caustic soda) to create sodium hypochlorite (liquid chlorine) — the chlorine and caustic are themselves produced by electrolyzing salt water, then recombined — or by combining chlorine gas with lime to make calcium hypochlorite (powder/granular).
Liquid Chlorine Manufacturing Process
Liquid chlorine, chemically known as sodium hypochlorite, is the most common form used by professional pool technicians and follows the TFP method recommendations. The manufacturing process is surprisingly straightforward:
Electrolysis Method
The primary method involves electrolyzing a solution of salt water (sodium chloride brine). Electrolysis of salt water produces chlorine gas, hydrogen gas, and sodium hydroxide (caustic soda) separately, in large industrial electrolytic cells; the chlorine gas is then reacted with the caustic soda to form sodium hypochlorite. Direct single-cell electrolysis can make hypochlorite in one step, but only at low strength (under ~1%), which is why it's used in on-site units rather than for bottled pool chlorine.
The chemical reaction is: Cl₂ + 2NaOH → NaOCl + NaCl + H₂O
Commercial liquid chlorine typically contains 10-12.5% available chlorine, making it highly effective for pool sanitization. This is why many pool professionals prefer liquid chlorine over store-bought "pool shock" - it's essentially the same product used in municipal water treatment.
Tablet and Powder Chlorine Production
Calcium hypochlorite (cal-hypo) tablets and powder undergo a more complex manufacturing process that involves handling dangerous chlorine gas.
Cal-Hypo Manufacturing Steps
First, manufacturers produce chlorine gas through the electrolysis of salt water, but instead of creating the final product directly, they capture the chlorine gas separately. This chlorine gas is then reacted with slaked lime (calcium hydroxide) in large reaction vessels under controlled conditions.
The reaction produces calcium hypochlorite: 2Cl₂ + 2Ca(OH)₂ → Ca(OCl)₂ + CaCl₂ + 2H₂O
For tablet production, the resulting calcium hypochlorite powder is mixed with stabilizers, binders, and sometimes cyanuric acid (CYACyanuric Acid (stabilizer) — Sunscreen for your chlorine — it keeps sunlight from burning it off. The catch: the more you have, the more chlorine you need to keep. learn more →), then compressed into tablet form. This is why tablets often contain built-in stabilizer - it's added during manufacturing.
Trichlor Tablet Manufacturing
Trichlor tablets (trichloroisocyanuric acid) are made through a different process involving cyanuric acid. Manufacturers react cyanuric acid with chlorine gas under specific temperature and pressure conditions. This creates tablets that contain about 90% available chlorine but also add CYA to your pool with every dose.
Important note: This is why TFP methodology recommends careful monitoring of CYA levels when using trichlor tablets, as excessive CYA buildup can make your chlorine less effective.
Salt Water Chlorine Generator Process
Your salt water chlorine generator uses direct electrolysis — the same low-strength, single-step method, on a much smaller scale — rather than the high-strength chlorine-gas-plus-caustic process used to make bottled liquid chlorine. When you add salt to your pool and run the generator, it electrolyzes the salt water to produce sodium hypochlorite directly in your pool.
The process generates the same sodium hypochlorite as commercial liquid chlorine, producing it continuously to maintain pool residual levels (typically 3-6 ppm). This is why salt water pools still require proper water balance - you're still using chlorine, just producing it on-site.
Quality Control in Chlorine Manufacturing
Commercial chlorine manufacturers must maintain strict quality control because pool owners depend on consistent available chlorine levels. Liquid chlorine is tested for:
- Available chlorine percentage (usually 10-12.5%)
- pH levels (typically 13+ for sodium hypochlorite)
- Heavy metal contamination
- Stability over time
This quality control is why purchasing chlorine from pool supply stores or having it delivered from pool service companies often provides more consistent results than big-box store alternatives.
Storage and Degradation Factors
Understanding manufacturing helps explain why proper storage matters. Liquid chlorine degrades quickly, losing roughly 20% of its potency per month even at room temperature (about half-strength in three months), and much faster in warm temperatures. Heat and sunlight accelerate this process by causing the sodium hypochlorite to decompose back into its component chemicals.
Calcium hypochlorite tablets and powder are more stable because they're in solid form, but they're also more dangerous to handle due to their concentrated nature and potential for explosive reactions with organic materials.
Environmental Considerations
Modern chlorine manufacturing has become more environmentally conscious. Many facilities now capture and reuse the hydrogen gas produced during electrolysis, and some use renewable energy sources to power the electrolytic process. The sodium hydroxide byproduct is often sold to other industries, reducing waste.
Safety reminder: Never attempt to manufacture chlorine at home. The industrial processes involve high voltages, dangerous gases, and require specialized equipment and safety protocols.
