How to Determine Your Swimming Pool Size & Volume
How do I figure out my pool's volume? I flunked calculus...
I keep getting asked what my pool volume is and all I know is it's big. Geez, are there any standards for this? It looks like a lot of water, but I flunked calculus...
Pool volume is length x width x average depth x 7.5 for a rectangular pool - a 32x16 ft pool averaging 5.5 ft deep is about 21,000 gallons. Typical inground pools run 15,000-25,000 gallons. Round/oval/freeform shapes use different multipliers; use our calculator or guide for those.
First — breathe. You do not need calculus, and "it's big" is a totally normal place to start. Pool volume is just length × width × average depth × a multiplier, and most people land within a few percent in about two minutes.
Here's the 30-second version for a standard rectangular pool:
Length (ft) × Width (ft) × Average Depth (ft) × 7.5 = gallons
Average depth is just (shallow-end depth + deep-end depth) ÷ 2 — then our pool volume calculator turns your length, width and depth into gallons. That's it. That's the scary math.
Any standards? Here's the "is mine normal" cheat sheet
Rough typical volumes, so you can sanity-check your number:
- Small pool / large spa: 5,000–10,000 gallons
- Average residential inground: 15,000–25,000 gallons (a classic 16 × 32 ft pool is ~20,000)
- Big inground: 25,000–40,000+ gallons
- Round above-ground (24 ft): ~13,500 gallons
If your answer lands way outside the size that looks right, re-check your average depth — that's the number people most often get wrong (measure the water depth, not the wall height).
Round, oval, or freeform?
The multiplier changes (round and oval use 5.9; kidney shapes use 3.38). For a kidney shape, add both end widths together: (Width A + Width B) × Length × Average Depth × 3.38 — using a single width with this multiplier gives only about half the real volume. The measurements differ a little. We walk through every shape with worked examples in our complete guide to calculating pool volume.
Skip the arithmetic entirely
Type your measurements into our free calculator — it does every shape and spits out gallons instantly.
Open the Pool Volume Calculator →Got a weird, curvy, where-do-I-even-start shape? A cheap walk-along measuring wheel makes measuring the length and perimeter painless — roll it along the edge and read the number.
Once you've got your gallons, keep it handy: every dose on our all-in-one calculator is sized off that one number, so nailing it now makes the whole rest of pool care easier.
