Filters Filters — How to Clean DE Pool Filter: Complete Step-by-Step Guide
Lisa B.
Lisa B.
New pool owner - how often should I clean my DE filter?
I woke up to a $180 quote for cleaning my DE pool filter and I'm wondering if this is something I can tackle myself as a new homeowner. The previous owner left me with a DE filter system and I'm trying to figure out the maintenance routine. The pool store told me I need to backwash regularly, but they weren't super clear on the details.
How often should I be backwashing? And do I need to do anything else besides just hitting the backwash cycle? I want to make sure I'm taking proper care of the filter so I don't mess anything up in my first season as a pool owner.
Clean your DE pool filter by backwashing for 2-3 minutes, then perform a complete teardown every 4-6 backwashes to hose off filter grids and apply fresh DE powder at 1 pound per 10 square feet of filter area.
Quick Solution
You can restore your DE pool filter to peak performance in just 20 minutes using nothing more than a garden hose and basic household tools. Start by backwashing for 2-3 minutes until water runs clear, then add fresh DE powder through your skimmer. For deep cleaning, shut down the system, remove filter grids, hose them clean, and reassemble with fresh DE coating.
Regular Backwashing Process
The most frequent maintenance your DE filter requires is backwashing, which should be done when your pressure gauge reads 8-10 PSI above the clean starting pressure.
  1. Turn off your pool pump completely
  2. Turn the multiport valve handle to "Backwash" position
  3. Turn the pump back on and let it run for 2-3 minutes
  4. Watch the sight glass - continue until water runs clear
  5. Turn off pump, set valve to "Rinse" and run for 30 seconds
  6. Turn off pump, return valve to "Filter" position
  7. Restart pump and check for normal operation
After backwashing, you've removed the DE coating along with the trapped debris, so you must add fresh DE powder. Add 1 pound of DE per 10 square feet of filter area (check your filter manual for exact square footage). Mix the DE powder in a bucket of pool water until smooth, then slowly pour through your skimmer basket while the pump runs.
Complete Filter Grid Cleaning
Every 4-6 backwashes or monthly, your filter grids need thorough cleaning that backwashing cannot achieve. This removes oils, lotions, and fine particles that embed in the fabric.
Disassembly Process
  1. Turn off pump and close all valves to isolate the filter
  2. Release pressure using the air relief valve on top
  3. Remove the filter tank lid or clamp band
  4. Carefully lift out the grid assembly - it will be coated with dirty DE
  5. Remove the top manifold and separate individual grids
  6. Take grids to an area where you can rinse without DE entering storm drains. Collect and dispose of DE waste water according to local environmental regulations - never allow it to enter storm drains or natural waterways
Grid Cleaning Methods
Use a garden hose with a spray nozzle to rinse each grid thoroughly. Spray from inside to outside, working systematically across each panel. For stubborn buildup, you have several options:
  • Soaking method: Only if mineral scale remains after a degreaser soak, soak grids briefly in a dilute acid solution (about 1 part acid to 10-20 parts water); never acid-soak greasy grids, and don't make acid a routine step, as it shortens grid life
  • TSP cleaning: Mix 1 cup trisodium phosphate per 5 gallons of water and soak grids for 2-3 hours to remove oils
  • Filter cleaner products: Use commercial filter cleaners like Natural Chemistry Filter Perfect following label directions
  • Dishwasher method: Some pool owners run grids through a dishwasher cycle without detergent for deep cleaning
Safety warning: Always add acid to water, never water to acid. Wear safety glasses and gloves when handling muriatic acid. Work in a well-ventilated area. Neutralize used acid solution with baking soda before disposal and follow local regulations for hazardous waste disposal.
Reassembly and DE Application
Once grids are clean and dry, reassemble in reverse order:
  1. Stack grids onto the bottom manifold in proper sequence
  2. Install the top manifold and ensure all grids are properly seated
  3. Lower the assembly into the tank, aligning with the center standpipe
  4. Replace the tank lid and tighten clamp band evenly
  5. Open valves and restart the pump
  6. Check for leaks and proper pressure readings
Now precoat with fresh DE powder. Your filter requires its full DE charge - typically 4-8 pounds depending on filter size. A Hayward DE4820 (48 sq ft) requires about 6 pounds for a full precoat after a teardown (roughly 4 pounds is the top-up needed after a routine backwash), while a Pentair FNS Plus 60 needs 6 pounds. Mix DE powder with pool water in a bucket until it forms a smooth slurry, then pour slowly through the skimmer while the pump circulates.
Cloudy Water After Cleaning
If water remains cloudy after cleaning, you may have added too much DE too quickly, creating a coating that's too thick. Backwash and reapply DE more slowly, ensuring even distribution.
Short Backwash Cycles
If you're backwashing every few days, your grids likely need deep cleaning or replacement. Grids typically last 5-10 years with proper maintenance.
DE in Pool
DE powder entering your pool indicates torn or damaged grids, or improper reassembly. Inspect all grids for holes or loose fabric and replace as needed.
Maintenance Schedule
Establish a regular cleaning routine:
  • Weekly: Check pressure gauge readings
  • Every 2-4 weeks: Backwash when pressure rises 8-10 PSI
  • Monthly: Complete grid cleaning and inspection
  • Seasonally: Deep clean with a commercial filter cleaner or degreaser (reserve acid only for confirmed mineral scale, since routine acid use shortens grid life)
  • Annually: Replace worn or damaged grids
Proper DE filter maintenance keeps your pool crystal clear while extending equipment life. The key is consistency - regular backwashing prevents excessive buildup, while monthly deep cleaning ensures optimal filtration performance. Always keep spare DE powder on hand, as you'll need it after every backwash to restore proper filtration.
Tags: #DE filter #diatomaceous earth #filter cleaning #backwashing #pool maintenance
