Can You Swim During Your Period? Pool Safety & Hygiene Guide
Is it okay to swim in my pool while on my period?
Replaced my carefree summer pool days with period anxiety that's eating through my swim time way faster than it should. I have a pool in my backyard and don't want to gross anyone out or cause any health issues, but also don't want to avoid swimming for a whole week every month.
What kind of protection works best for swimming, and do I need to worry about messing up my pool chemistry or anything like that? Just want to make sure I'm being considerate of other swimmers while still being able to enjoy my own pool!
Yes, you can swim during your period safely. Proper menstrual protection and maintaining balanced pool chemistry ensure hygiene and comfort for all swimmers.
Understanding Pool Chemistry and Menstrual Flow
A well-maintained pool with proper chlorine levels (1-3 ppm free chlorine) will effectively sanitize any bodily fluids, including menstrual blood. The small amount of menstrual flow that might occur while swimming poses no health risk to you or other swimmers when the pool chemistry is balanced correctly.
Your pool should maintain these chemical levels for optimal sanitation:
- Free Chlorine (FC): 1-3 ppm for daily swimming
- pH: 7.4-7.6 for comfort and chlorine effectiveness
- Total Alkalinity (TA): 80-120 ppm for regular pools, 60-80 for salt water
- Cyanuric Acid (CYA): 30-50 ppm to protect chlorine from UV rays
Test your water with a reliable test kit like the Taylor K-2006 before swimming to ensure proper sanitization levels.
Choosing the Right Menstrual Protection for Swimming
Tampons
Tampons are the most popular choice for swimming during periods. They create an internal seal that prevents water from entering the vaginal canal and menstrual fluid from leaking out. Insert a fresh tampon right before swimming and change it immediately after getting out of the pool. The tampon string may absorb some pool water, but this won't affect its effectiveness.
Menstrual Cups
Menstrual cups like the DivaCup or Lunette provide excellent protection for swimming. They create a complete seal and can be worn for up to 12 hours, making them ideal for long pool sessions. Since they collect rather than absorb menstrual fluid, there's virtually no risk of leakage while swimming.
Period Swimwear
Specialized period swimwear with built-in absorbent layers offers another option. Brands like Knix and Modibodi create swimsuits designed to absorb menstrual flow while looking like regular swimwear. These work best for lighter flow days and provide peace of mind for extended pool time.
Water Pressure Benefits
One of the advantages of swimming during your period is that water pressure naturally reduces menstrual flow while you're submerged. The hydrostatic pressure of the water temporarily slows the flow of menstrual fluid, giving you additional protection beyond your chosen menstrual product.
This natural phenomenon means you're less likely to experience leakage while actively swimming, though flow will resume normally when you exit the water.
Pool Maintenance Considerations
If you're concerned about pool cleanliness, focus on maintaining proper chemical balance rather than avoiding swimming during your period. A properly chlorinated pool will handle normal bodily fluids without issue.
Testing and Adjusting Chemistry
- Test your pool water 2-3 times per week using a quality test kit
- Maintain free chlorine between 1-3 ppm for regular use
- If chlorine drops below 1 ppm, add liquid chlorine at 1 gallon per 30,000 gallons to raise FC by 1 ppm
- Keep pH between 7.4-7.6 using muriatic acid to lower or sodium carbonate to raise
- Shock weekly with liquid chlorine to maintain water clarity
Comfort and Confidence Tips
Pre-Swimming Preparation
Insert a fresh tampon or empty your menstrual cup right before entering the pool. This ensures maximum protection and comfort during your swim. If using period swimwear, make sure it fits snugly for optimal performance.
Post-Swimming Care
Change your menstrual protection immediately after swimming, even if it doesn't seem full. Pool chemicals and extended wear can cause irritation. Rinse off with fresh water to remove chlorine from your skin and swimwear.
Managing Flow Concerns
If you have a heavy flow, consider swimming during lighter days of your cycle or use double protection (tampon plus period underwear) for extra confidence. Remember that most people won't notice anything even if minor leakage occurs, and properly chlorinated water will sanitize any discharge.
Health and Safety Considerations
Swimming during your period won't increase infection risk when the pool is properly maintained. In fact, chlorinated water helps prevent bacterial growth. However, avoid swimming in poorly maintained pools, hot tubs with questionable chemistry, or natural bodies of water during your period to reduce infection risk.
Change out of wet swimwear promptly after swimming to prevent yeast infections or bacterial growth. The combination of moisture, warmth, and menstrual fluid can create an environment for unwanted bacteria if you remain in wet clothing too long.
Addressing Common Concerns
Will Sharks Be Attracted?
This myth persists but has no scientific basis in pool swimming. Even in ocean swimming, the minimal amount of menstrual fluid released while using proper protection poses no increased shark risk.
Will Other Swimmers Notice?
With proper protection, other swimmers won't know you're menstruating. The small amount of discharge that might occur is quickly diluted and sanitized by properly chlorinated pool water.
Can I Use Pads?
Regular menstrual pads aren't suitable for swimming as they'll absorb pool water and become ineffective. Stick to internal protection or specialized period swimwear designed for water activities.
