Should I shock before winterizing? Pool store says yes but $$$
Is shocking actually necessary before winter closing, or is this just another upsell? If I do need to shock, does the timing matter with when I add the other winterizing chemicals? I'm tired of spending a fortune on pool maintenance when I feel like half of what they recommend is just to boost their profits.
Yes, you should shock your pool before closing it for winter, but timing is crucial. Shock 2-3 days before adding winterizing chemicals to ensure proper sanitization without chemical conflicts. This process eliminates bacteria, algae, and organic contaminants, ensuring your pool is clean and sanitized for the winter. Test and balance your water chemistry, including pH and CYA levels, before shocking. Use the all-in-one pool calculator for shock dosage and follow the SLAM process if needed.
Why Shocking Before Winter Closing Is Essential
Shocking your pool before winter serves several crucial purposes that protect your investment during the long closure period. First, it eliminates any lingering bacteria, algae spores, and organic contaminants that could multiply during winter months when your filtration system is offline. Even small amounts of organic matter can lead to significant problems come spring opening.
Second, proper shocking ensures your chlorine levels are adequate to work synergistically with winterizing algaecide and other closing chemicals. Many pool owners make the mistake of relying solely on winterizing chemicals without first establishing a clean, sanitized baseline through effective shocking.
Timing Your Pre-Winter Shock Treatment
The timing of your shock treatment is more important than many pool owners realize. Never shock your pool on the same day you add winterizing chemicals. This can cause chemical reactions that neutralize both products, wasting money and leaving your pool vulnerable.
Plan to shock your pool 2-3 days before your intended closing date. This schedule allows the shock to do its job completely, lets chlorine levels stabilize, and provides a clean slate for winterizing products to work effectively throughout the winter months.
Weather Considerations
Avoid shocking during extremely hot, sunny days as UV rays will rapidly break down the chlorine before it can sanitize effectively. Evening application is ideal, giving the shock overnight to work without sun interference. If you're closing due to an early freeze warning, shock at least 24 hours before temperatures drop, as cold water slows chemical reaction rates.
Step-by-Step Pre-Closing Shock Process
Testing and Balancing First
Before adding any shock, test your water chemistry using a reliable test kit like the Taylor K-2006. Keep pH in the normal 7.2-7.8 range before shocking; if it is above ~7.8, lower it with muriatic acid. Higher pH shifts more chlorine to the weaker hypochlorite ion (so slightly more FCFree Chlorine — The chlorine actively sanitizing your water right now. This is the number you keep an eye on. how much you need → may be needed), but the main reason to keep pH in range during a shock is to avoid cloudiness and scaling.
Check your cyanuric acid (CYACyanuric Acid (stabilizer) — Sunscreen for your chlorine — it keeps sunlight from burning it off. The catch: the more you have, the more chlorine you need to keep. learn more →) levels as well. If CYA is above 50 ppm, you'll need higher shock levels according to the FC/CYAFC/CYA chart — The chart that sets your chlorine target from your stabilizer (CYA) level — the two go together. see the chart → relationship. For CYA levels of 30-50 ppm, target a shock level of 12-20 ppm free chlorine, with higher levels needed for higher CYA.
Calculating Shock Dosage
For a handy reference to calculate shock dosage, use our all-in-one pool calculator. For liquid chlorine (typically 10-12.5% sodium hypochlorite), dosage depends on your CYA levels and target shock level - see manufacturer specs or pool calculator for estimated amounts as 1 gallon per 10,000 gallons may be insufficient for proper shock levels. For calcium hypochlorite granular shock, follow the product label for your pool volume. Always add shock to water, never water to shock, and dissolve granular products in a bucket before adding to prevent bleaching of pool surfaces.
Application Method
With your pump running on high speed, pour liquid chlorine around the pool perimeter, focusing on areas with poor circulation like steps and corners. For granular shock, pre-dissolve in a plastic bucket and pour the solution slowly around the pool. Never mix different types of shock products as this can cause dangerous chemical reactions.
For cyanuric acid (CYA), pre-dissolve the granules in a bucket of hot water and pour the solution slowly into the pool, or use the SOCK method by placing the CYA in a sock or nylon and placing it in the skimmer basket or hanging it in front of a return, squeezing occasionally. Never broadcast CYA granules directly onto the pool floor or dump them loose into the skimmer. CYA dissolves slowly, so retest after a few days to a week, and do not add more until you are sure the levels have stabilized.
Post-Shock Monitoring
Run your filtration system continuously for 24 hours after shocking. Test free chlorine levels after 8 hours - they should be at or above your target shock level. If levels have dropped significantly, you may have organic contamination that requires additional shock treatment.
The water should be crystal clear with no cloudiness or algae growth. If you notice any green tinting or persistent cloudiness, you may need to perform a SLAMShock Level And Maintain — raise free chlorine to a target based on your CYA and hold it there until the algae is gone. It's a process, not a one-time dose. the SLAM walkthrough → (Shock Level And Maintain) process, continuing to add chlorine until levels hold steady overnight.
Preparing for Winterizing Chemicals
Once your shock treatment is complete and chlorine levels have stabilized, wait 2-3 days before adding winterizing algaecide, enzyme treatments, or other closing chemicals. Test chlorine levels before adding any copper-based winterizing algaecide - let free chlorine fall below about 4 ppm first, so the high chlorine doesn't destroy the algaecide or cause metal staining. (If you're skipping algaecide, leaving FC near shock level at closing is fine and actually helps the pool stay clear over winter.)
This waiting period prevents chemical interactions that can reduce the effectiveness of your winterizing products. Some algaecides, particularly copper-based ones, can react with high chlorine levels, creating staining or precipitation issues.
Don't use store-bought "pool shock" products that contain fillers and stabilizers. These can cloud your water and add unwanted cyanuric acid. Stick with plain liquid chlorine or calcium hypochlorite, and avoid dichlor or trichlor "shock," which adds cyanuric acid you don't want building up over winter.
Avoid shocking and winterizing on the same day, regardless of product marketing claims about compatibility. This shortcut frequently leads to spring opening problems including persistent algae blooms and stained surfaces.
Never shock an uncovered pool during heavy leaf fall. The organic matter will consume your chlorine rapidly, making the treatment ineffective and potentially creating more contamination than you started with.
