How to Lower Pool Alkalinity Cheaply - DIY Methods
What's the cheapest way to lower my pool's total alkalinity myself?
Tried everything to balance my 18,000 gallon inground pool, but it's eating through pH adjusters way faster than it should with alkalinity stuck at 180-200 ppm. The water looks fine but I know this isn't good long term. I'm trying to avoid calling a pool service company since money's tight right now. Is this something I can handle myself with store-bought chemicals? What's the most budget-friendly approach that actually works? I have basic test strips and can get to the pool supply store, but I don't want to mess this up and create a bigger expensive problem.
Use muriatic acid or sodium bisulfate to lower alkalinity, adding small amounts gradually while testing frequently. The process typically takes several days of adjustments to avoid overshooting your target range.
Understanding Your Alkalinity Problem
Don't panic — high pool alkalinity might seem like a chemistry nightmare, but you can fix it yourself for under $20 using simple household products. When alkalinity exceeds the ideal range (typically 150 ppm), it acts like a buffer that makes your pH extremely stubborn to adjust. You'll end up wasting money on pH chemicals that don't work, and your chlorine becomes less effective.
If Your Alkalinity is 150-200 ppm
This is the sweet spot for DIY fixes. You have two budget-friendly chemical options:
- Muriatic acid - Usually the cheapest option at around $3-5 per gallon
- Sodium bisulfate (dry acid) - More expensive but easier to handle safely
For example, an 18,000-gallon pool at 180 ppm alkalinity might need approximately 48-60 fluid ounces of muriatic acid total, though actual amounts vary based on your specific water conditions. Don't add it all at once - this is a gradual process.
If Your Alkalinity is Over 200 ppm
You're looking at a more intensive process. The chemical costs jump significantly, and you'll need to be extra patient. Consider whether the time and chemical investment makes sense versus getting professional help for the initial knockdown.
The Step-by-Step Reduction Process
- Start small: Add only 12-16 fluid ounces of muriatic acid per treatment
- Pour directly into deep end - Wearing protective equipment including gloves and eye protection, slowly pour acid into water (never water into acid) at the deep end with pump running for maximum circulation. Always add acid to water to prevent dangerous reactions.
- Wait 4-6 hours before retesting - never rush this
- Retest and repeat until you reach 80-120 ppm range
If You're Seeing pH Drop Too Low
This is the tricky part that catches DIYers off guard. Muriatic acid hammers both alkalinity and pH. If your pH drops below 7.0 during treatment:
- Stop adding acid immediately
- Let it sit for 24 hours - pH often rebounds naturally as alkalinity buffers it
- If pH stays below 7.0, add small amounts of baking soda to raise pH without spiking alkalinity too much
Money-Saving Testing Strategy
Forget expensive digital testers for this project. Quality test strips that measure both pH and alkalinity work fine and cost under $15. Test before each acid addition and 4-6 hours after. Don't waste strips by testing more frequently - the readings won't be accurate anyway.
If You Have a Salt Water Pool
Turn off your salt cell during this process. The electrolytic process in salt systems naturally drives pH and alkalinity up, working against your acid additions. You're basically throwing money away if you leave it running.
Troubleshooting Stubborn Alkalinity
If you've added the calculated amount of acid but alkalinity won't budge below 150 ppm, you might be dealing with cyanuric acid interference or calcium buffering. At this point, partial water replacement becomes the most cost-effective solution rather than dumping more chemicals in.
The Aeration Method
Here's a free trick that helps: after acid additions, run water features, point return jets upward, or even use a shop vacuum on blow mode to create surface agitation. This drives off CO2 and helps stabilize your new alkalinity level faster.
When to Call for Help
If alkalinity exceeds 250 ppm or you're not comfortable handling muriatic acid, the chemical costs and complexity often justify professional service for the initial correction. You can maintain proper levels yourself once they get it in range.
