How Long Do Pool Cartridge Filters Last? Replacement Guide
How often should I replace my pool cartridge filters?
Between my pool store saying 2-4 weeks and everything online claiming 2-4 months, I'm completely lost on when to actually replace my cartridge filter. How long between cleanings? When do I throw them out completely and buy new ones?
Running my pool daily during summer. Want to stay on top of maintenance but not waste money replacing too early.
Clean a cartridge filter when pressure rises about 8-10 PSI (roughly 25%) above the clean reading, not on a fixed calendar — in practice that's often every 1-3 months, and a well-sized filter can go a full season. Replace the cartridge entirely every 2-5 years depending on usage, bather load, and care.
Cleaning vs. Replacement Schedule
Between Cleanings: Driven by Pressure
How fast the pressure climbs depends on several factors:
- Pool usage: Heavy bather load reduces time to 1-2 weeks
- Environmental conditions: Pollen, dust, and debris shorten intervals
- Water chemistry: Poor balance leads to faster clogging
- Filter size: Larger surface area lasts longer between cleanings
Complete Replacement: Every 2-5 Years
Even with regular cleaning, cartridge filter media eventually breaks down. Replace filters when you notice:
- Pleats starting to fray or separate
- Filter media becoming discolored or stained
- Cleaning becomes less effective
- Pressure differential increases quickly after cleaning
Signs Your Filter Needs Attention
Time to Clean (Weekly Check)
Monitor your pressure gauge weekly. When pressure rises 8-10 PSI above the clean starting pressure, it's time to clean your cartridges. For example, if your clean pressure is 12 PSI, clean when it reaches 20-22 PSI.
Time to Replace (Monthly Assessment)
Inspect cartridges monthly for these replacement indicators:
- Frayed pleats: Media separating from the plastic frame
- Permanent staining: Brown, green, or yellow discoloration that won't clean off
- Shortened cleaning cycles: Pressure rises faster than usual after cleaning
- Visible wear: Thin spots or holes in the filter media
- Poor water clarity: Cloudy water despite proper chemistry
Factors That Affect Filter Life
Pool Usage Patterns
Bather load dramatically impacts filter life. Each swimmer introduces oils, lotions, hair products, and organic contaminants. A busy family pool or one used for entertaining will require cleaning every 1-2 weeks, while a lightly used, well-balanced pool can go several months — sometimes a full season.
Environmental Conditions
Your location affects filter longevity:
- Windy areas: More debris means more frequent cleaning
- Trees nearby: Leaves, pollen, and organic matter reduce intervals
- Dusty climates: Fine particles clog filters faster
- Rainy seasons: Increased organic growth and debris
Water Chemistry Balance
Proper water balance extends filter life significantly. Maintain these TFP-recommended levels:
- pH: 7.4-7.6 for comfort and balanced water
- Free Chlorine: Follow the FC/CYAFC/CYA chart — The chart that sets your chlorine target from your stabilizer (CYA) level — the two go together. see the chart → relationship — our all-in-one pool calculator estimates the free chlorine target for your CYACyanuric Acid (stabilizer) — Sunscreen for your chlorine — it keeps sunlight from burning it off. The catch: the more you have, the more chlorine you need to keep. learn more →.
- Total Alkalinity: 60-80 ppm for SWGSalt Water Generator — The "salt cell" that makes chlorine from the salt in a saltwater pool. Same chlorine — it just makes its own. pool terms →, 80-120 for regular chlorine
- Calcium Hardness: 250-350 ppm for plaster pools
Poor chemistry leads to algae growth, scale formation, and increased organic loading that clogs filters rapidly.
Maximizing Filter Lifespan
Rotation System
Use a two-set rotation system. While one set filters your pool, the other set air-dries completely. This rotation extends filter life and ensures you always have clean filters ready.
Proper Cleaning Technique
Clean cartridges with a garden hose spray nozzle, working from top to bottom at a 45-degree angle. Avoid pressure washers, which damage the filter media. For deep cleaning, soak in a cartridge cleaner/degreaser, and only if mineral scale remains, follow with a brief dilute acid soak (about 1 part acid to 20 parts water; wear safety gear).
Chemical Balance Maintenance
Test water 2-3 times weekly using a Taylor K-2006C test kit. Maintain proper sanitizer levels to prevent algae growth that rapidly clogs filters. If water turns green, immediately begin a SLAMShock Level And Maintain — raise free chlorine to a target based on your CYA and hold it there until the algae is gone. It's a process, not a one-time dose. the SLAM walkthrough → process using liquid chlorine to restore clarity and reduce filter strain.
When to Replace Prematurely
Sometimes filters need early replacement:
- After algae blooms: Green water events can permanently stain and clog filters
- Following storms: Heavy debris loads may damage filter media
- Chemical accidents: Over-chlorination or pH swings can degrade filter material
- Winter damage: Freezing can crack or damage cartridge frames
Cost-Effective Filter Management
Quality cartridge filters cost $15-40 each, making replacement a significant expense. Extend value by:
- Buying filters in bulk during sales
- Maintaining proper water chemistry to prevent premature clogging
- Using a skimmer basket and leaf trap to reduce debris load
- Showering before swimming to reduce oils and lotions
Safety Note: When using muriatic acid for deep cleaning, always wear gloves, eye protection, and work in a well-ventilated area. Add acid to water, never water to acid.
