How Pool Salt Cells Work: Complete Electrolysis Guide
Karen V.
First-time Pool Owner
What's the science behind salt water pool chlorine generation?
My pool's eating through chlorine like crazy even after replacing the chlorinator, shocking three times, and rebalancing all the chemicals twice. Want to understand the actual process before I make the switch.
How does dissolved salt become chlorine? What happens inside those cells with the metal plates? Need the technical breakdown.
Pool salt cells use electrolysis to convert dissolved salt (sodium chloride) into chlorine by passing an electrical current through salt water between titanium plates coated with precious metals.
Step-by-Step Process of How Salt Cells Generate Chlorine
  1. Salt Water Circulation
    Your pool pump circulates water containing dissolved salt (typically 3,000-4,000 ppm) through the plumbing system and into the salt cell chamber.
  2. Electrical Current Activation
    The salt cell's control unit sends a low-voltage DC electrical current (usually 3-7 volts) to the titanium plates inside the cell housing.
  3. Electrolysis Reaction Begins
    As salt water flows between the charged titanium plates, the electrical current breaks apart the sodium chloride (NaCl) molecules through electrolysis: 2NaCl + 2H₂O → Cl₂ + H₂ + 2NaOH.
  4. Chlorine Gas Formation
    This reaction produces chlorine gas (Cl₂) at the anode (positive plate), hydrogen gas (H₂) at the cathode (negative plate), and sodium hydroxide (NaOH) which raises pH.
  5. Chlorine Dissolution and Conversion
    The chlorine gas immediately dissolves into the water and converts to hypochlorous acid (HOCl) and hypochlorite ion (OCl⁻) - your pool's active sanitizers.
  6. Sanitized Water Return
    The newly chlorinated water flows back into your pool through the return jets, providing continuous sanitation.
  7. Salt Regeneration Cycle
    The hydrogen gas escapes as bubbles, while the sodium hydroxide eventually reacts with dissolved CO₂ to reform salt, making the process self-sustaining.
Key Components That Make Salt Cells Function
Titanium Electrode Plates
The heart of any salt cell consists of titanium plates coated with precious metals like ruthenium, iridium, or platinum. These plates are arranged in parallel with alternating positive and negative charges. The coating is crucial because pure titanium would corrode rapidly. Quality cells like Pentair IntelliChlor or Hayward TurboCell use multiple thin plates to maximize surface area for more efficient chlorine production.
Cell Housing and Flow Design
The clear or opaque housing holds the plates while allowing water to flow between them. Proper flow rate (typically 15-40 gallons per minute depending on cell size) ensures adequate contact time without creating excessive back pressure in your plumbing system.
Power Supply and Control Unit
The control unit converts your home's 120V or 240V AC power to low-voltage DC current. Modern systems like the Pentair IntelliChlor or Jandy AquaPure include digital displays showing salt levels, cell life remaining, and chlorine output percentage.
Critical Water Chemistry for Proper Salt Cell Operation
Salt Level Requirements
Most salt cells require 3,000-4,000 ppm of salt (sodium chloride). Too little salt (below 2,700 ppm) prevents adequate chlorine production, while excessive salt (above 5,000 ppm) can damage the cell and create an unpleasant taste. Test salt levels monthly using a digital salt meter or Taylor K-1766 salt test kit.
pH and Alkalinity Balance
Salt cells naturally raise pH because they produce sodium hydroxide during electrolysis. Maintain pH between 7.2-7.6 and total alkalinity between 80-120 ppm (lower than traditional chlorine pools). High pH reduces chlorine effectiveness and can cause calcium scaling on the plates.
Stabilizer (CYA) Levels
Maintain cyanuric acid between 30-50 ppm for salt water pools. The stabilizer protects the generated chlorine from UV degradation. Without adequate CYA, your salt cell will run constantly trying to maintain free chlorine levels.
Reverse Polarity and Self-Cleaning Function
Quality salt cells feature automatic reverse polarity, where the electrical current switches direction every few hours. This prevents calcium buildup on the plates by alternating which plate acts as the anode (where scaling occurs). During reverse polarity, calcium deposits dissolve back into solution, extending cell life significantly.
Why Salt Cells Eventually Fail
Salt cells have finite lifespans (typically 3-7 years or 10,000 hours of operation) because the precious metal coating gradually erodes during electrolysis. High salt levels, improper pH, insufficient cleaning, and running the cell at maximum output accelerate this process. Signs of a failing cell include white calcium buildup that won't clean off, decreased chlorine production, and error codes on the control unit.
Maintenance Requirements for Optimal Performance
Inspect your salt cell monthly for calcium scaling or debris buildup. Clean quarterly by removing the cell from the plumbing system and using a 10:1 water-to-muriatic acid solution, soaking for 5-10 minutes maximum. Always wear safety equipment and ensure proper ventilation when handling muriatic acid. Never use metal tools or abrasives on the plates, as this damages the precious metal coating.
digital salt meter pool test kit muriatic acid for cleaning safety equipment
Tags: #salt cell #electrolysis #chlorine generation #salt water pools #pool chemistry
