Do Saltwater Pools Need Cyanuric Acid? Essential Guide
Sue D.
Pool Service Hobbyist
Should I add cyanuric acid to my saltwater pool?
My saltwater pool opens every spring with the same nagging question about whether I actually need cyanuric acid or not. I know the salt cell generates chlorine automatically, but I'm not sure if that means I can skip the stabilizer. My pool gets tons of sun exposure throughout the day.
What's the ideal CYA level for saltwater pools, and does it work differently than regular chlorine pools? Don't want to waste money on chemicals I don't need, but also don't want my chlorine getting zapped by UV rays!
Yes, saltwater pools absolutely need cyanuric acid (stabilizer) to protect the chlorine generated by the salt cell from UV degradation. Maintain CYA levels between 70-80 ppm for optimal protection.
Why Saltwater Pools Need Cyanuric Acid
Salt water pools use a chlorine generator (salt cell) that converts dissolved salt into chlorine through electrolysis. This process creates the same free chlorine (hypochlorous acid) that sanitizes traditional pools. Without cyanuric acid, the sun's UV rays will rapidly destroy this chlorine, forcing your salt cell to work overtime and potentially shortening its lifespan.
Here's what happens without adequate CYA protection:
Optimal CYA Levels for Salt Water Pools
Industry standards recommend maintaining CYA levels between 30-50 ppm for saltwater pools, the same as traditional pools. This higher range accounts for the continuous chlorine production and provides better protection against UV degradation.
CYA Level Guidelines:
Testing and Adjusting CYA Levels
Test your CYA levels monthly using a reliable test kit. The Taylor K-2006 test kit provides the most accurate CYA readings using the turbidity method.
How to Test CYA:
  1. Fill the mixing bottle to the 25 mL mark with pool water
  2. Add CYA reagent R-0013 drop by drop while mixing
  3. Count drops until the black dot disappears when viewed from above
  4. Multiply the drop count by 7 to get your CYA reading in ppm
Adding Cyanuric Acid:
When CYA levels are below 70 ppm, add granular cyanuric acid at a rate of 1 pound per 3,000 gallons to raise CYA by approximately 13 ppm. Always add stabilizer gradually and retest after 48 hours for accurate readings.
  1. Calculate the amount needed based on your pool volume
  2. Dissolve the stabilizer in a bucket of warm water
  3. Pour the solution around the pool perimeter with the pump running
  4. Wait 48 hours before retesting (CYA dissolves slowly)
Balancing Chlorine with CYA Levels
With proper CYA levels, you'll need to adjust your free chlorine target accordingly. Use the FC/CYA ratio chart to determine optimal free chlorine levels:
Your salt chlorine generator's output should be adjusted to maintain these FC levels consistently.
Over-stabilization
The biggest mistake saltwater pool owners make is allowing CYA levels to climb too high. Unlike liquid chlorine, salt cells do not contribute stabilizer, as they only produce chlorine through electrolysis.
Neglecting Regular Testing
CYA levels remain relatively stable once established, but seasonal factors and pool maintenance can affect them. Test monthly and after major water additions or treatments.
Using Stabilized Chlorine Products
Avoid using dichlor or trichlor shock in saltwater pools, as these products contain CYA and can quickly push levels too high. Stick to liquid chlorine (sodium hypochlorite) when supplemental chlorination is needed.
Seasonal CYA Management
CYA levels may need adjustment based on seasonal use patterns:
When CYA Levels Are Too High
If CYA exceeds 100 ppm, partial water replacement is the only practical solution. Dilute the pool water by draining 25-50% and refilling with fresh water. This also helps maintain proper total dissolved solids (TDS) levels in salt pools.
Safety Warning: Always add chemicals to water, never water to chemicals. Wear protective equipment when handling cyanuric acid, and ensure proper ventilation in storage areas.
Taylor K-2006 test kit cyanuric acid stabilizer measuring cup stirring stick
Tags: #cyanuric acid #saltwater pools #pool stabilizer #CYA levels #chlorine protection
