Can Pool Salt Cells Be Rebuilt? Complete Repair Guide
Is it safe to rebuild our salt cell instead of buying new?
Woke up to a dead salt cell again — thing works flawlessly when it's under 85 degrees but won't generate a drop of chlorine once we hit the 90s. A local pool tech mentioned that these cells can sometimes be rebuilt by replacing the internal titanium plates, which would cost significantly less than buying a brand new unit.
I'm worried about whether a rebuilt cell would be as reliable and safe for my kids as a new one. The housing on our current cell looks fine, no cracks or damage that I can see. Has anyone had experience with rebuilding salt cells? I want to make sure we're not compromising water quality or safety just to save money. What should I consider before deciding between rebuilding versus replacing entirely?
Most salt water pool cells can be rebuilt by replacing the titanium plates and internal hardware, typically costing 50-70% less than a new cell. However, rebuilding is only worthwhile if the cell housing is intact and you have technical skills.
When Rebuilding Makes Sense
Salt cell rebuilding is most worthwhile when you have a premium cell (Hayward TurboCell, Pentair IntelliChlor, or Jandy AquaPure) where the titanium plates have worn out but the housing remains intact. The decision depends on several factors:
- Cell age: Cells under 5 years old are excellent rebuild candidates
- Housing condition: No cracks, corrosion, or thread damage
- Cost comparison: Rebuilds typically cost 50-70% less than new cells
- Warranty considerations: Rebuilt cells void manufacturer warranties
- Technical ability: Requires precision work with small components
What's Involved in Rebuilding
Salt cell rebuilding involves completely disassembling the cell and replacing the core components that generate chlorine. Here's what gets replaced during a professional rebuild:
Titanium Electrode Plates
The heart of any salt cell rebuild is installing new titanium plates coated with ruthenium or iridium oxide. These plates carry the electrical current that converts salt into chlorine. Over time, the coating wears away and plates develop calcium buildup that can't be cleaned off.
Internal Hardware
All internal connections, screws, and electrical contacts get replaced. This includes the bus bars that carry current between plates and any plastic spacers that maintain proper plate spacing. Using original manufacturer specifications is crucial for proper amperage flow.
Gaskets and Seals
New O-rings and gaskets prevent water leaks and ensure proper pressure. The main housing gasket is particularly important as it maintains the watertight seal when reinstalled in your plumbing system.
Professional vs DIY Rebuilding
While some pool owners attempt DIY rebuilds, professional rebuilding services offer significant advantages. A small number of specialist refurbishers — such as Salt Solutions Inc. and Pool Cell Repair Inc. — along with some local pool equipment shops, have the tools and replacement parts to do this work.
Professional Rebuild Benefits
- Precision spacing tools ensure optimal chlorine production
- Access to OEM-quality titanium plates and coatings
- Proper torque specifications prevent over-tightening
- 90-day to 1-year warranties on rebuilt cells
- Testing equipment to verify amperage draw
DIY Challenges
- Sourcing quality replacement plates can be difficult
- Improper plate spacing reduces efficiency
- Risk of damaging the housing during disassembly
- No warranty protection if rebuild fails
- Special tools required for some cell types
Cost Analysis: Rebuild vs Replace
The economics of rebuilding depend on your specific cell model and local pricing. The figures below are rough, vary by region, and move over time (and a direct replacement cell often beats both) — verify against current listings before deciding:
- Hayward TurboCell T-15: New $650-750, Rebuild $200-275
- Pentair IntelliChlor IC40: New $550-650, Rebuild $175-250
- Jandy AquaPure 1400: New $400-500, Rebuild $150-225
- Generic cells: Often not worth rebuilding due to low replacement cost
Factor in shipping costs for mail-in rebuilds, which typically add $25-40 to the total expense. Local rebuilders may offer pickup and delivery services.
When NOT to Rebuild
Several conditions make rebuilding inadvisable or impossible:
- Cracked housing: Cannot maintain proper seal or pressure
- Corroded threads: Won't reconnect securely to plumbing
- Cells over 7-8 years old: Housing materials may be brittle
- Multiple previous rebuilds: Housings wear out from repeated disassembly
- Low-cost cells: Rebuild cost approaches new cell pricing
Maximizing Rebuilt Cell Lifespan
A properly rebuilt cell should last 3-5 years with proper maintenance. Follow these practices to maximize longevity:
- Maintain salt levels between 2700-3400 ppm (check manufacturer specifications)
- Keep stabilizer (CYACyanuric Acid (stabilizer) — Sunscreen for your chlorine — it keeps sunlight from burning it off. The catch: the more you have, the more chlorine you need to keep. learn more →) in the range your salt generator's manufacturer recommends — often around 70-80 ppm for outdoor salt pools (higher than a traditional pool) to protect chlorine from UV
- Clean the cell only when scale is visible, using about a 4:1 water-to-muriatic acid solution (add acid to water) (or per manufacturer specifications) - always add acid to water, never water to acid
- Run system only when necessary - avoid over-chlorination
- Watch calcium hardness by surface type: lower hardness reduces scaling on the cell, but don't run plaster/gunite pools too low (keep roughly 250-350+ ppm) or the water can etch the plaster; vinyl and fiberglass tolerate the lower end
Finding Rebuild Services
Search for "salt cell rebuild" plus your area, or contact local pool equipment repair shops. Many offer mail-in services with 5-10 day turnaround times. Always verify they use quality replacement parts and offer warranties on their work.
Always turn off power to the salt system before removing the cell. Before shipping your cell, take photos of any damage and get a firm quote including return shipping. Reputable rebuilders will inspect your cell and contact you before proceeding if additional issues are discovered.
