How Do I Lower My Pool's Alkalinity Without Dropping pH Too Low?
I tested my pool water and alkalinity is at 150 ppm but my pH is already in the normal range. I don't want to add more acid and crash my pH—how can I lower alkalinity while keeping pH stable?
Quick Answer Use muriatic acid to lower both pH and alkalinity together, then aggressively aerate the water to raise pH back up while leaving alkalinity lowered. This "pH bounce" technique selectively reduces alkalinity over multiple cycles. Why Your Alkalinity Is High High alkalinity usually comes
High alkalinity usually comes from one of these common sources:
- Overusing alkalinity increaser (baking soda/sodium bicarbonate)
- Using cal-hypo or liquid chlorine regularly (both are alkaline and can nudge alkalinity up over time)
- Filling the pool with high-alkalinity source water (well water or some municipal supplies)
Step-by-Step Fix
Step 1: Test Your Water
Use a reliable test kit (Taylor K-2006 or equivalent) to measure total alkalinity (TATotal Alkalinity — The buffer that keeps your pH from bouncing around. Get this in range and pH gets a lot easier to manage. learn more →) and pH. Target TA should be 80-120 ppm for most pools, with pH in the ideal range of 7.4-7.6.
Step 2: Add Muriatic Acid
Use 31.45% muriatic acid (hydrochloric acid). Add acid in small, calculated doses—use a pool calculator app or website to determine estimated amounts based on your current TA level and pool volume. Never drop pH below 7.0 in a single treatment to avoid equipment damage. Pour acid slowly into the deepest part of the pool with the pump running (and when pre-diluting in a bucket, always add acid to water, never water to acid).
Step 3: Aerate Aggressively
After adding acid, aerate the water to raise pH back up WITHOUT raising alkalinity. Run deck jets, point returns upward to ripple the surface, use fountain attachments, run spa spillovers, or use a sump pump to create a waterfall effect. Aeration drives off dissolved carbon dioxide (CO2), which shifts the carbonate equilibrium and raises pH without affecting TA.
Step 4: Test and Repeat
Re-test pH and TA after 12-24 hours of aeration (larger pools or less effective aeration methods may take longer). Repeat the acid/aeration cycle until TA lands in the 80-120 ppm range and pH stabilizes at 7.4-7.6. This process takes multiple cycles but is the most effective way to lower alkalinity without permanently crashing pH.
Final Check: Once balanced, your water should feel comfortable and equipment should be protected from scale or corrosion.
Safety Warning
ACID HANDLING: Always add acid to water, NEVER water to acid. Avoid splashing it on skin or in your eyes, and rinse with water if you do. Wear gloves and eye protection when pouring from the full-strength jug. Add acid slowly to the deepest part of the pool with the pump running, preferably upwind to avoid fumes. Use muriatic acid outdoors only with good airflow—do not inhale fumes. Keep all electrical equipment away from acid handling areas. Store acid in a cool, ventilated, locked area away from other pool chemicals (especially chlorine — acid mixed with chlorine releases toxic gas) and metals.
