Do Salt Water Pools Have Chlorine? The Truth Explained
Jennifer L.
Saltwater Pool Convert
Wait, do saltwater pools actually still have chlorine in them?
Walked into this thinking saltwater pools were chlorine-free last month, but now I'm drowning in conflicting information about how they actually produce chlorine somehow. And if they do, do I still need to worry about testing and maintaining chemical levels like a regular pool? I thought the whole point was to avoid dealing with chlorine!
Salt water pools do contain chlorine - the salt chlorine generator converts salt into chlorine through electrolysis. You still need to maintain proper chlorine levels and test regularly.
First, Let's Diagnose the Confusion
Many pool owners believe salt water pools don't have chlorine because they don't add liquid chlorine or chlorine tablets. However, the salt chlorine generator is constantly producing chlorine from the salt in your pool water. When you test your water, you'll find measurable free chlorine (FC) levels just like any other pool.
The confusion often stems from marketing materials that emphasize the "gentler" nature of salt water pools, leading people to assume they're chlorine-free. In reality, salt water pools typically maintain chlorine levels between 1-3 ppm, the same range as traditional chlorine pools.
How Salt Water Chlorine Generation Works
Your salt chlorine generator uses electrolysis to convert sodium chloride (salt) into sodium hypochlorite, which dissolves in water to form hypochlorous acid (chlorine), plus sodium hydroxide. The process happens in the generator cell as water flows through it:
  1. Salt water passes through the generator cell containing titanium plates coated with precious metals
  2. Electrical current is applied to the plates, splitting salt molecules
  3. Chlorine is produced and immediately dissolves into the pool water
  4. The chlorine sanitizes your pool just like traditional chlorine
  5. After sanitizing, the chlorine converts back to salt, repeating the cycle
Testing and Maintaining Chlorine in Salt Water Pools
You still need to test and maintain proper chlorine levels in your salt water pool. Here's your troubleshooting approach:
Testing Requirements
Test your water 2-3 times per week using a quality test kit like the Taylor K-2006C. Focus on these key parameters:
When Chlorine Levels Are Low
If your FC tests below 1 ppm, troubleshoot in this order:
  1. Check that your salt generator is running adequate hours (typically 8-12 hours daily)
  2. Verify salt levels are within manufacturer specifications
  3. Clean the generator cell if it shows calcium buildup
  4. Increase generator output percentage if needed
  5. Add liquid chlorine as a temporary boost while adjusting the system
When Chlorine Levels Are High
If FC exceeds 5 ppm:
  1. Reduce generator runtime or output percentage
  2. Check for over-stabilization (high CYA levels)
  3. Ensure pH hasn't risen too high (reduces chlorine effectiveness)
  4. Allow time for chlorine to naturally dissipate
Key Differences from Traditional Chlorine Pools
While salt water pools do contain chlorine, there are important operational differences:
pH Management
Salt chlorine generators naturally raise pH, so you'll need muriatic acid more frequently than traditional pools. Test pH weekly and maintain 7.4-7.6 for optimal chlorine effectiveness.
Stabilizer Levels
Salt water pools require higher CYA levels (70-80 ppm) compared to traditional pools (30-50 ppm). This protects the generated chlorine from UV degradation and improves efficiency.
Alkalinity Control
Keep total alkalinity lower (60-80 ppm) in salt water pools to prevent excessive pH rise and calcium scaling on the generator cell.
Troubleshooting Common Salt Water Pool Issues
"My pool smells like chlorine"
Strong chlorine odor actually indicates chloramines (combined chlorine), not free chlorine. This happens when FC levels are too low relative to bather load. Increase generator output and maintain FC at 3 ppm until the odor disappears.
"I thought salt water pools were gentler"
They can be gentler on skin and eyes when properly balanced, but this is due to consistent chlorine production and proper pH management, not the absence of chlorine. The chlorine is identical whether produced by a generator or added manually.
Emergency Chlorination
During algae outbreaks or heavy bather loads, you may need to supplement with liquid chlorine even with a salt generator. The SLAM process (Shock Level And Maintain) works the same way - maintain shock level chlorine based on your CYA until the pool clears.
Warning: Never assume your salt water pool is self-maintaining. Regular testing is crucial because the chlorine is still present and active. Over-chlorination can damage pool surfaces and equipment, while under-chlorination allows dangerous bacteria and algae growth.
Always maintain your generator cell according to manufacturer instructions, including regular acid washing to remove calcium buildup that can reduce chlorine production.
pool test kit pH strips salt test strips muriatic acid
Tags: #salt water pools #chlorine levels #pool chemistry #salt chlorine generator
