Salt Water Salt Water — Do I Need Pool Salt? Complete Saltwater Pool Guide 2026
Adam Q.
Adam Q.
Is pool salt necessary for my kids' swimming pool?
Spent $800 on a saltwater pool conversion quote and now I'm second-guessing whether I actually need salt or if regular chlorine works just fine. My kids spend hours in the water every day during summer, and I want to make sure I'm maintaining it properly for their safety. I keep seeing conflicting information online about whether all pools need salt or not.
Some neighbors have mentioned adding salt to their pools, but I'm not sure if that's something I should be doing too. What determines whether a pool actually needs salt? I don't want to add unnecessary chemicals, but I also don't want to skip something important that could affect water quality when my children are swimming.
You only need pool salt if you have a saltwater chlorinator system installed. Traditional chlorine pools don't use salt, while saltwater pools require 2,700-3,400 ppm of salt to operate properly.
How to Determine if You Need Pool Salt
a handy way to know if you need salt is to look at your pool equipment. Walk to your pool's equipment pad and look for a salt chlorine generator - it's typically a rectangular or cylindrical unit connected to your plumbing with an electrical control panel. Popular brands include Pentair IntelliChlor, Hayward AquaRite, and Jandy AquaPure systems.
If you see one of these units, you have a saltwater pool and need to maintain proper salt levels. If you only see a traditional pump, filter, and heater without a salt generator, you have a conventional chlorine pool and don't need salt.
Understanding Saltwater Pool Systems
Saltwater pools don't actually swim in salt water like the ocean. Instead, they use salt to generate chlorine through a process called electrolysis. The salt chlorine generator passes pool water through an electrolytic cell that converts dissolved salt (sodium chloride) into hypochlorous acid - the same sanitizing agent found in liquid chlorine.
This system provides several advantages: steadier chlorine levels, softer-feeling water, and reduced need to handle chlorine chemicals. However, it requires maintaining proper salt levels, typically costs more upfront, and needs specific water chemistry parameters.
Proper Salt Levels and Testing
If you have a saltwater system, maintain salt levels between 2,700-3,400 ppm, with most manufacturers recommending around 3,200 ppm as the optimal target (check your unit — Hayward AquaRite targets about 3,200 ppm, while Pentair's IntelliChlor targets 3,600 ppm). Test salt levels monthly. The most accurate home test is a reagent drop kit like the Taylor K-1766; a digital salt meter is convenient (though it can drift out of calibration), and salt strips are the quick, cheaper option (usually fine, but occasionally off).
Salt is dosed by your pool volume and how far your current reading is from target. Rather than working it out by hand, use our easy-to-use pool calculator — it works out how much salt to add from your current and target levels. Pool salt purity varies, so add gradually and retest.
Adding Salt to Your Pool
When adding salt, use pure sodium chloride pool salt - never use table salt, rock salt, or salt with additives. Popular brands include Morton Pool Salt and Diamond Crystal Pool Salt.
  1. Calculate an estimate of salt needed using the formula above
  2. Turn off your salt chlorine generator but keep the pump running
  3. Pour salt directly into the deep end of the pool while the pump circulates water
  4. Brush the pool bottom to help salt dissolve faster
  5. Run the pump for 24 hours before retesting salt levels
  6. Once salt levels are correct, turn the generator back on
Water Chemistry for Saltwater Pools
Saltwater pools require specific chemistry parameters different from traditional pools. Maintain pH between 7.4-7.6, as salt systems tend to drive pH higher. Target total alkalinity between 80-120 ppm to help control pH drift.
Indoor saltwater pools generally don't need CYACyanuric Acid (stabilizer) — Sunscreen for your chlorine — it keeps sunlight from burning it off. The catch: the more you have, the more chlorine you need to keep. learn more → at all, since there's no sunlight to protect the chlorine against; outdoor saltwater pools typically run 70-80 ppm to shield chlorine from UV degradation - check your manufacturer's specifications. Test and adjust these levels weekly, as proper chemistry extends cell life and ensures effective sanitization.
Saltwater vs Traditional Pool Comparison
Traditional chlorine pools use liquid chlorine, tablets, or granular chlorine added manually or through automatic feeders. These pools typically have lower operating costs but require more frequent chemical additions and monitoring. They don't need salt but require regular chlorine purchases.
Saltwater pools have higher upfront costs ($1,500-$4,000 for equipment) but lower ongoing chemical costs. The salt cell typically lasts 3-7 years depending on usage and maintenance, costing $300-$800 to replace. Water feels softer and many people find it less irritating to skin and eyes.
Common Saltwater Pool Mistakes
Many pool owners add salt unnecessarily after being told by pool stores they "need more chemicals." Salt levels only decrease through physical water loss - splash-out, backwashing, or draining. Salt does not evaporate with water. Don't add salt based on low chlorine readings; instead, check your generator's operation and cell condition.
Safety warning: Never add salt to a pool without a salt chlorine generator. This won't sanitize your water and can damage pool surfaces and equipment not designed for salt exposure.
Making the Switch to Saltwater
Converting from traditional chlorine to saltwater requires installing a salt chlorine generator compatible with your pool size and plumbing. Professional installation typically costs $2,000-$5,000 including equipment. Consider factors like local electricity costs, as salt systems use more power than simple chlorine addition methods.
Recommended for this job
Tags: #saltwater pools #pool salt #salt chlorinator #pool conversion
