Do I Need Pool Conditioner? Complete CYA Guide for Pool Owners
Should I be using cyanuric acid in my pool?
Before adding chlorine to my crystal-clear, chemically balanced pool, it lasted days — now it vanishes within hours like something's devouring it. My pool seems fine without it so far, but I'm wondering if I'm missing something important here?
Also if I do need it, what levels should I be shooting for? I've got a regular chlorine pool, not saltwater. Don't want to mess anything up but also don't want to buy chemicals I don't actually need!
Yes, most pools need conditioner (cyanuric acid) to protect chlorine from UV rays. Target 30-50 ppm for regular pools or 70-80 ppm for salt water pools.
What Pool Conditioner Actually Does
Pool conditioner, also known as cyanuric acid (CYA) or stabilizer, acts as sunscreen for your chlorine. When UV rays hit chlorine molecules in your pool, they break them down rapidly - sometimes within hours on a bright sunny day. Conditioner forms a weak bond with chlorine molecules, creating "stabilized chlorine" that resists UV degradation while still maintaining its sanitizing power.
Without conditioner, you'd need to add chlorine multiple times daily during summer months, making pool maintenance expensive and frustrating. However, too much conditioner reduces chlorine effectiveness, creating its own set of problems.
When You DON'T Need Conditioner
There are specific situations where conditioner isn't necessary or beneficial:
- Indoor pools: No UV exposure means no need for stabilizer
- Heavily shaded pools: Pools under dense tree cover or structures with minimal sun exposure
- Pools using trichlor or dichlor exclusively: These products already contain CYA
- Commercial pools: Many use unstabilized chlorine for faster turnover
- Pools with CYA levels already too high: Above 100 ppm requires dilution, not more conditioner
Proper Conditioner Levels by Pool Type
Standard Chlorine Pools
Target range: 30-50 ppm. This provides adequate UV protection while maintaining chlorine effectiveness. At these levels, your free chlorine should be 2-4 ppm for proper sanitization according to the FC/CYA relationship.
Salt Water Generator Pools
Target range: 30-50 ppm (consult manufacturer specifications as some may recommend slightly higher levels). Maintain free chlorine at 1-3 ppm according to the FC/CYA relationship.
Hot Tubs and Spas
Target range: 30-50 ppm, though many spa owners prefer lower levels (20-30 ppm) due to higher temperatures and faster chemical reactions.
How to Test Conditioner Levels
Use a Taylor K-2006C test kit for accurate CYA testing. Test strips are notoriously unreliable for cyanuric acid. The turbidity test in quality kits measures cloudiness when reagent is added - the cloudier the sample, the higher the CYA level.
Test CYA levels monthly during swimming season and after adding any stabilized chlorine products. Always test in shade and read results at eye level for accuracy.
Adding Conditioner Safely
Pure cyanuric acid dissolves very slowly and can damage pool surfaces if added improperly. Follow these steps:
- Calculate needed amount: Add 1 pound of conditioner per 10,000 gallons to raise CYA by approximately 11-12 ppm
- Dissolve in warm water first: Mix conditioner in a bucket with warm water, stirring constantly
- Add near return jets with pump running to ensure circulation
- Brush pool surfaces immediately to prevent settling and staining
- Run pump continuously for 24-48 hours after addition
- Retest CYA levels after 48-72 hours (full dissolution takes time)
Safety Warning: Never add conditioner directly to pool surfaces or through skimmer. Always pre-dissolve and add slowly with proper circulation.
Common Conditioner Mistakes
Over-Stabilization
CYA levels above 100 ppm create "chlorine lock" where even high chlorine levels can't effectively sanitize. The only fix is dilution through partial water replacement.
Using Stabilized Shock Products
Dichlor and trichlor products contain CYA. Regular use will gradually increase conditioner levels beyond optimal ranges. Use liquid chlorine or cal-hypo for routine shocking once conditioner is established.
Not Accounting for Existing CYA
Many pool owners add conditioner without testing current levels, leading to over-stabilization. Always test before adding.
Seasonal Conditioner Management
CYA doesn't evaporate or break down naturally, so levels remain stable unless diluted. During winter, conditioner protects any residual chlorine. In spring, test CYA before adding chemicals - you may not need additional conditioner.
If you partially drain your pool for winter or maintenance, recalculate conditioner needs based on fresh water percentage added.
Cost-Benefit Analysis
A 25-pound bucket of cyanuric acid costs $60-80 and treats a 20,000-gallon pool for an entire season. Without it, you'd spend 3-5 times more on chlorine - potentially hundreds of dollars extra annually. The investment in proper conditioner levels pays for itself within weeks of summer swimming.
