Do I Need a Pool Closing Kit? Winter Closing Guide 2024
Nancy Z.
Saltwater Pool Convert
Are pool closing kits worth it or just overpriced marketing?
Nobody told me that my first winter as a pool owner would involve sales people pushing expensive "winter closing kits" that might just be overpriced marketing nonsense.
I've been looking into buying the chemicals separately - seems like I could get algaecide, shock, and antifreeze for way less money. Has anyone tried the DIY approach instead of buying the fancy branded kits? I'm just frustrated with how expensive pool maintenance has gotten and want to know if I can save some cash without screwing up my winter closing.
Pool closing kits are convenient but not necessary - you can buy winterizing chemicals separately and often save money. The key is having algaecide, winterizing shock, and antifreeze for your specific pool size and climate.
First, Let's Diagnose Whether You Need a Pool Closing Kit
Consider this a warning sign — the moment you start shopping for expensive pool closing kits is when pool companies know they've got another easy target. However, let's troubleshoot your specific situation to determine the best approach for your pool and budget.
Analyzing Your Pool Closing Kit Options
What's Actually in Most Pool Closing Kits
Most commercial pool closing kits contain three main components:
The problem with many kits is they're sized generically and may not match your pool's specific needs. A 15,000-gallon kit might contain the same algaecide as a 25,000-gallon kit, just with different labeling.
Cost Analysis: Kit vs. Individual Chemicals
Here's where troubleshooting gets interesting. Let's break down the real costs:
You'll typically save 20-30% buying components individually, plus you can choose higher-quality products.
When a Closing Kit Makes Sense
Scenario 1: First-Time Pool Owner
If you've never closed a pool before, a kit provides peace of mind with included instructions. However, make sure to verify the chemical amounts match your actual pool volume, not just the kit's stated range.
Scenario 2: Small Pool or Hot Tub
For pools under 10,000 gallons or spas, the convenience factor often outweighs the cost savings. Buying individual chemicals in small quantities can be challenging.
Scenario 3: Time Constraints
If you're closing late in the season and need everything immediately, a kit from your local pool store might be your fastest option.
When to Skip the Kit and Buy Separately
Better Chemical Selection
Individual purchases allow you to choose superior products. For example, you can select a high-quality polyquat 60 algaecide from reputable manufacturers, rather than the generic copper-based algaecides in most kits.
Proper Dosing for Your Pool
Calculate your actual needs:
Climate Considerations
Your local climate affects chemical needs significantly. In mild winter areas (zones 8-10), you may not need antifreeze at all. In harsh climates (zones 3-5), you'll need more robust protection than most kits provide.
The Proper Winterizing Chemical Process
Step 1: Balance Your Water First
Before adding any winterizing chemicals, test and adjust:
Step 2: Shock Treatment
Add calcium hypochlorite shock to reach 10-12 ppm free chlorine. For a 20,000-gallon pool, this typically requires 2-3 pounds of cal-hypo shock (exact amount depends on product's available chlorine percentage - see manufacturer specifications). Never use trichlor tablets for winterizing - they'll continue dissolving and create acidic conditions.
Step 3: Add Winterizing Algaecide
Wait at least 8 hours after shocking, then add your winterizing algaecide. Polyquat 60 formulations are superior to copper-based products because they won't stain and work in all water types. Add 1 quart per 20,000 gallons and circulate for 2-4 hours.
Step 4: Final Steps
Add stain preventer if you have metal issues in your water supply. Use antifreeze only in plumbing lines that can't be completely drained - never add antifreeze to the pool water itself.
Quality Considerations and Brand Recommendations
If buying separately, consider these proven products:
Final Recommendation
For most pool owners, buying winterizing chemicals separately offers better value and superior results. The 20-30% cost savings, combined with the ability to choose higher-quality products and proper dosing for your specific pool, makes individual purchases the smarter choice. However, if convenience is your priority and you're comfortable with generic formulations, a closing kit can still effectively winterize your pool.
Safety reminder: Always add chemicals with the pump running, never mix different chemicals together, and wear appropriate safety equipment when handling pool chemicals.
pool test kit winterizing chemicals pool brush safety equipment
Tags: #pool closing #winterizing #pool chemicals #algaecide #pool shock
