How to Winterize Above Ground Pool: Complete 2024 Guide
Jessica D.
Pool Service Hobbyist
Complete winterizing steps for above ground pool?
Around here winter hits fast, so I'm planning to winterize my above ground pool this Saturday — what supplies and steps do I need ready? Don't want freeze damage or a swamp when I open next spring.
What's the full process? Water chemistry, equipment, covers - the whole deal. Step by step would be great.
Winterizing an above ground pool involves balancing water chemistry, cleaning thoroughly, removing or protecting equipment, lowering water level, adding winterizing chemicals, and installing a proper cover to prevent freeze damage and algae growth.
Free Tool: Pool Closing Checklist - Never miss a step when winterizing your pool.
Pre-Winterization Water Chemistry Balance
Start winterization 1-2 weeks before your final pool closing to ensure proper chemical balance. Use a quality test kit like the Taylor K-2006C to test and adjust these levels:
If your pool is green or cloudy, perform a SLAM (Shock Level And Maintain) process using liquid chlorine before winterization. This involves maintaining chlorine at shock level for your CYA reading until you can maintain overnight chlorine loss of 1 ppm or less.
Deep Cleaning Process
Thorough cleaning prevents algae blooms and staining during winter months:
  1. Brush all surfaces: Pay special attention to steps, corners, and behind ladders where algae spores hide
  2. Vacuum to waste: Remove all debris without returning dirty water to the pool
  3. Clean the waterline: Use a waterline cleaner or mild abrasive to remove oils and buildup
  4. Backwash or clean filter: For sand filters, backwash until water runs clear. For cartridge filters, clean with filter cleaner and let dry
Equipment Removal and Protection
Proper equipment handling prevents expensive freeze damage:
Items to Remove Completely
Pump and Filter System
For above ground pools, you have two options:
Complete Removal (Recommended): Disconnect and store pump, filter, and heater indoors. This eliminates freeze damage risk entirely. Drain all equipment completely, including pump housing and filter tank.
Winterization in Place: If removal isn't possible, drain all water from pump housing, filter tank, and plumbing lines. Remove drain plugs and store them in the pump basket. Add non-toxic propylene glycol RV antifreeze to pump housing if temperatures drop below 20°F regularly (use RV antifreeze rated for your lowest expected temperature).
Water Level and Plumbing
Unlike inground pools, above ground pools require specific water level management:
  1. Lower water level: Reduce water to 4-6 inches below the skimmer opening, but keep enough water to prevent liner floating or ice damage to walls
  2. Blow out return lines: Use a shop vacuum or leaf blower to remove water from return plumbing
  3. Install winter plugs: Insert expansion plugs into skimmer and return openings to prevent water entry
  4. Protect skimmer: Add a skimmer guard or skimmer plate to prevent freeze damage if water level rises
Winterizing Chemical Treatment
Add winterizing chemicals in the evening for best distribution:
  1. Algaecide: Add 1 quart of winterizing algaecide per 15,000 gallons (winterizing algaecide is more concentrated than regular algaecide). Avoid copper-based algaecides that can stain liners
  2. Winter chemical kit: Follow manufacturer's directions for kits containing algaecide, clarifier, and enzyme products
  3. Optional chlorine: Only add liquid chlorine if levels are below 1 ppm - add 1 gallon per 10,000 gallons several days before adding winterizing chemicals to avoid interference
Important: Never add chlorine and algaecide simultaneously - wait at least 4 hours between applications.
Winter Cover Installation
A quality winter cover is your pool's primary protection:
Solid Winter Covers
Best for above ground pools because they block sunlight completely, preventing algae growth. Install cover tightly with:
Warning: Winter covers are not safety covers. They cannot support weight and pose drowning risks. Never walk on winter covers and ensure children cannot access the covered pool area.
Common Winterization Mistakes to Avoid
Climate-Specific Considerations
Mild Winter Areas: You may choose to run equipment monthly during winter instead of full winterization. Maintain 1-2 ppm chlorine and check chemistry monthly.
Severe Freeze Areas: Consider partial draining if temperatures regularly drop below 10°F. Consult manufacturer guidelines for your specific pool model's freeze line recommendations.
Spring Opening Preparation
Proper winterization makes spring opening significantly easier. Keep winterization notes including final chemical readings and equipment storage locations. Schedule spring opening 2-3 weeks after your area's last freeze date for optimal timing.
pool test kit liquid chlorine winterizing chemicals pool brush vacuum winter cover cover clips expansion plugs cover pump
Tags: #above ground pool #winterizing #pool closing #freeze protection #winter chemicals #pool covers
