Can You Clean Pool with Bleach? Safe Methods & Alternatives
New pool owner - can I use regular bleach instead of pool chemicals?
Every pool maintenance manual I've read says never use household bleach, but my neighbor's been using it for years at half the cost of liquid chlorine. The pool store sells liquid chlorine but it's pretty expensive, and I noticed it's basically the same ingredient as regular household bleach.
Can I save money by using bleach from the grocery store instead? If so, how much would I need to add? My pool is about 10,000 gallons. I want to make sure I'm doing this safely and not damaging anything. Any guidance from experienced pool owners would be really appreciated!
Yes, you can use unscented household bleach (sodium hypochlorite) to clean your pool, but liquid chlorine designed for pools is more cost-effective and safer. Calculate about 21 fl oz of 6% bleach per 10,000 gallons to raise chlorine ~1 ppm (a gallon raises ~6 ppm). For regular maintenance, target 4-6 ppm FC for CYA 30-50 and 6-8 ppm for CYA 60-80. Use the SLAM method for shock treatments, raising FC to shock level based on CYA. Always add chemicals separately and follow safety guidelines.
Step-by-Step Guide to Using Bleach in Your Pool
Step 1: Choose the Right Type of Bleach
- Select only plain, unscented household bleach, typically 5.25-8.25% sodium hypochlorite (read the label and match your dose to the actual strength)
- Avoid bleaches with additives, fragrances, or colorants
- Check the label to ensure sodium hypochlorite is the only active ingredient
- Verify the concentration percentage on the bottle
Step 2: Test Your Current Water Chemistry
- Use a reliable test kit like Taylor K-2006 to measure current free chlorine (FCFree Chlorine — The chlorine actively sanitizing your water right now. This is the number you keep an eye on. how much you need →) levels
- Test pH levels - keep them in the 7.2-7.8 range for swimmer comfort and to protect surfaces and equipment (lower pH actually makes chlorine slightly more active, so don't raise pH to boost sanitizing)
- Check total alkalinity (TATotal Alkalinity — The buffer that keeps your pH from bouncing around. Get this in range and pH gets a lot easier to manage. learn more →) - target 80-120 ppm for regular pools
- Measure cyanuric acid (CYACyanuric Acid (stabilizer) — Sunscreen for your chlorine — it keeps sunlight from burning it off. The catch: the more you have, the more chlorine you need to keep. learn more →) levels to determine proper chlorine target
Step 3: Calculate Bleach Dosage
- As a rule of thumb, a gallon of 6% household bleach raises FC by roughly 6 ppm per 10,000 gallons (5.25% bleach is a bit weaker). For the amount that fits your pool, use our easy-to-use pool calculator or browse our pool guides.
- Multiply by your desired FC increase - typically 4-6 ppm for regular maintenance (CYA 30-50) or 6-8 ppm for CYA 60-80
- Use the FC/CYAFC/CYA chart — The chart that sets your chlorine target from your stabilizer (CYA) level — the two go together. see the chart → relationship — our all-in-one pool calculator estimates the free chlorine target for your CYA.
Step 4: Add Bleach Safely
- Pour bleach directly into the deep end of the pool with pump running
- Never mix bleach with other chemicals
- Add bleach in the evening to prevent sun degradation
- Walk around the pool perimeter while pouring to distribute evenly
- Allow circulation for at least 30 minutes before retesting
Step 5: Retest and Adjust
- Wait 30-60 minutes after addition before testing FC levels
- Retest pH as chlorine addition can raise pH slightly
- Add muriatic acid if pH exceeds 7.6
- Continue monitoring FC levels and maintain appropriate levels based on CYA
Why Pool Liquid Chlorine is Better Than Household Bleach
Cost Effectiveness
Pool liquid chlorine typically contains 10-12.5% sodium hypochlorite compared to household bleach's roughly 5-8%. This higher concentration means you need less product and often pay less per pound of available chlorine. A gallon of pool liquid chlorine treats approximately twice as much water as household bleach.
Purity and Consistency
Pool-grade liquid chlorine is just sodium hypochlorite at a consistent, higher strength with minimal additives. Plain, unscented household bleach is essentially the same thing — only weaker — and is perfectly fine in a pool. What to avoid is "splash-less," scented, or "outdoor" bleach, which add thickeners, fragrances, or surfactants that can foam or throw off your water. So it isn't that unscented bleach is suspect — it's the specialty versions you skip.
When Bleach Makes Sense
Household bleach can be useful in emergency situations when pool stores are closed or for small above-ground pools where convenience outweighs cost. It's also readily available at grocery stores and can work for shock treatments when you can't find pool chlorine.
Never mix bleach with other pool chemicals, especially acids or other chlorine products. This can create dangerous chlorine gas. Always add chemicals separately with the pump running and wait between additions.
Store bleach in a cool, dark place as sodium hypochlorite degrades quickly in heat and sunlight. Old bleach loses potency and won't effectively sanitize your pool.
SLAM Method with Bleach
If your pool is green or cloudy, you can perform the SLAMShock Level And Maintain — raise free chlorine to a target based on your CYA and hold it there until the algae is gone. It's a process, not a one-time dose. the SLAM walkthrough → (Shock Level And Maintain) method using household bleach. Raise FC to shock level based on your CYA reading and maintain that level 24/7 until combined chlorine (CCCombined Chlorine — "Used-up" chlorine left over from doing its job. Above about 0.5 ppm is the classic sign water needs a shock. learn more →) is 0.5 ppm or less, you pass the overnight chlorine loss test, and achieve crystal clear water.
For CYA of 30 ppm, maintain FC at 12 ppm during SLAM. This requires frequent testing and bleach additions every few hours, making liquid pool chlorine more practical for large shock treatments.
Bottom Line
While household bleach can clean your pool effectively, liquid pool chlorine offers better value, higher concentration, and more consistent results. Save bleach for emergencies and invest in proper pool chemicals for regular maintenance.
