Above Ground Above Ground — How Long Above Ground Pool Filters Last - Complete Guide
Linda N.
Linda N.
When to replace above ground pool filters? Complete breakdown
Got called out by my husband for never replacing our pool filter in three years and now I'm wondering if that's why our water keeps getting cloudy. Got an above ground pool and want to know how long each type lasts before I'm throwing money away.
Specifically looking for info on cartridge, sand, and DE filters. When do you actually need to replace vs just clean? Don't want to replace too early but also don't want nasty water.
An above ground pool filter housing lasts many years — it is the internal media or element you replace periodically. Cartridge elements are cleaned every 2-4 weeks in season and replaced every 2-5 years, sand is replaced roughly every 5-7 years, and DE grids typically last 5-10 years (only the DE powder is replenished after each backwash).
Filter Lifespan by Type
Cartridge Filters (Most Common)
Cartridge filters are the most popular choice for above ground pools and have the shortest individual lifespan. A cartridge element typically lasts 2-5 years before it needs replacing. What you do every 2-4 weeks in season is clean it (rinse off the trapped dirt) — not replace it. Rotating between 2-3 cartridges (use one while the others dry) makes cleaning easier and extends element life.
The cartridge housing itself lasts for years and rarely needs replacing — only when you notice cracking, warping, or when cartridges no longer fit properly. Signs your cartridge needs immediate replacement include visible tears, collapsed pleats, slimy buildup that won't rinse off, or shortened time between cleanings.
Sand Filters
Sand filter media has a long lifespan, typically lasting 5-7 years before replacement is needed. The filter tank itself often lasts much longer - 15-20 years or more - with proper care, since you typically replace only valves and gaskets. You'll know it's time to replace the sand when your pool water remains cloudy despite proper chemical balance, when you're backwashing more frequently than normal, or when the sand has formed hard clumps that don't break apart.
Replace sand filter media completely - don't just add new sand on top. Use #20 silica sand specifically designed for pool filters, typically requiring 150-300 pounds depending on your filter size.
Diatomaceous Earth (DE) Filters
DE filter grids typically last 5-10 years — you replenish the DE powder after each backwash, but the grids themselves last for years. The filter tank can last 5-8 years. Replace grids when you notice tears, holes, or when they no longer hold their shape properly. Quality DE grids from manufacturers like Hayward or Pentair tend to last longer than generic alternatives.
Factors Affecting Filter Lifespan
Usage and Bather Load
Heavy pool usage dramatically shortens filter life. Pools used daily by multiple swimmers will require more frequent filter replacements than occasionally used pools. Body oils, sunscreen, and other contaminants quickly clog filter media.
Water Chemistry
Maintaining proper water balance significantly extends filter life. Keep pH between 7.4-7.6 (acceptable 7.2-7.8), total alkalinity at 80-120 ppm, and maintain appropriate free chlorine levels based on your CYACyanuric Acid (stabilizer) — Sunscreen for your chlorine — it keeps sunlight from burning it off. The catch: the more you have, the more chlorine you need to keep. learn more → (cyanuric acid) level. Poor water chemistry forces filters to work harder and clogs them faster.
High calcium hardness (above 400 ppm) can cause scaling on filter media, while low pH (below 7.0) can degrade filter materials prematurely.
Environmental Factors
Pools surrounded by trees, exposed to frequent storms, or in dusty areas will require more frequent filter replacements. Pollen, leaves, and debris quickly overwhelm filter capacity.
Extending Filter Life
Proper Cleaning Schedule
For cartridge filters, rinse weekly with a garden hose, rotating spray to remove debris from pleats. Monthly, soak in a cartridge cleaner solution such as TSP (trisodium phosphate), Pleatco Filter Wash, or Simple Green overnight, then rinse thoroughly.
Sand filters should be backwashed when pressure gauge reads 8-12 psi above clean starting pressure. DE filters need backwashing when pressure rises similarly, followed by adding fresh DE powder.
Chemical Balance
Test water 2-3 times weekly using a reliable test kit like Taylor K-2006C. Maintain FC/CYAFC/CYA chart — The chart that sets your chlorine target from your stabilizer (CYA) level — the two go together. see the chart → ratio according to the all-in-one pool calculator - typically about 11-13% of your CYA level for your daily target FCFree Chlorine — The chlorine actively sanitizing your water right now. This is the number you keep an eye on. how much you need → (per Trouble Free Pool, 7.5% is the minimum - don't let FC fall below it).
Safety Warning: Always turn off pump before removing or servicing any filter components to prevent injury.
Rotation System
For cartridge systems, maintain 2-3 cartridges in rotation. This allows thorough drying between uses, which helps kill bacteria and extends cartridge life significantly.
When to Replace vs. Clean
Replace cartridges immediately if you notice: fabric separation from plastic frames, collapsed or permanently flattened pleats, tears or holes, or persistent algae/bacteria growth that cleaning cannot remove.
For sand filters, replace media when backwashing frequency increases dramatically or when sand appears hardened or discolored despite proper chemical balance.
DE grids need replacement when fabric shows wear, tears, or when grids no longer maintain their rigid structure.
Cost Considerations
Budget approximately $100-200 annually for cartridge replacement in moderately used pools. Sand replacement costs $50-100 every 3-5 years, while DE grids cost $80-150 for replacement sets.
Investing in quality filter media from reputable manufacturers like Unicel, Pleatco, or OEM replacements typically provides better longevity than generic alternatives, making them more cost-effective long-term.
Tags: #above-ground-pools #filter-replacement #pool-maintenance #cartridge-filters #sand-filters
