Do I Need to Prime My Pool Pump? Complete Priming Guide
When do I actually need to prime my pool pump?
My pool tech wants $150 just to prime my pump and I'm wondering if this is something I can tackle myself instead. My neighbor says you need to prime every time you turn the pump on, but that seems like overkill?
I'm wondering when priming is actually necessary versus when I can skip it. Like after I clean the skimmer basket or do basic maintenance, do I always need to go through the whole priming process? And what about if the pump's been off for a few days - does that matter?
Just trying to figure out the real deal here because priming is kind of a pain and I don't want to do it more than I have to!
Yes, you need to prime your pool pump whenever it loses water from the system, such as after maintenance, repairs, or when air enters the lines. Priming fills the pump housing and plumbing with water to create proper suction.
When You Need to Prime Your Pool Pump
The real cause of most pool pump failures usually isn't a broken motor or clogged filter—it's simply an unprimed pump that's been running dry. Priming is essential whenever your pump system loses its prime and fills with air instead. This happens after winterizing, equipment maintenance, repairs, or when air leaks develop in your suction lines.
Your pump needs priming when you notice:
- No water circulation after startup
- Pump running but not moving water
- Loud cavitation noises from the pump
- Air bubbles constantly entering the pool
- After any service that required draining the system
- Following pool opening after winter closure
Understanding Why Pumps Need Priming
Pool pumps are centrifugal pumps that rely on water already being present in the system to create suction. Most residential pool pumps are self-priming designs, but they cannot pull water up from the pool when the system is completely full of air and has lost its prime. The impeller needs water around it to generate the pressure differential that draws more water through the system.
When air fills the pump housing and suction lines, the impeller just spins in air, creating no meaningful suction. This is called "losing prime" and can damage your pump motor through overheating if left running dry for extended periods.
Step-by-Step Pump Priming Process
Safety Warning: Always turn off power at the breaker before working on your pump. Water and electricity are a deadly combination.
Preparation Steps
- Turn off the pump at the breaker, not just the switch
- Ensure return line valves are open (closing return valves can create dangerous pressure buildup)
- Locate your garden hose and have it ready near a water source
- Remove the pump lid by turning counterclockwise (some have clamp-style lids)
- Check the pump lid O-ring for cracks or debris and clean if necessary
Priming Process
- Fill the pump strainer basket housing completely with water from your garden hose
- Continue adding water until it overflows slightly from the housing
- Quickly replace the pump lid, ensuring the O-ring seats properly
- Tighten the lid firmly but don't over-tighten (hand-tight plus 1/4 turn)
- Verify return line valves are open
- Turn the pump on at the breaker
- Watch for water flow to begin within 30-60 seconds
Troubleshooting Priming Problems
If Your Pump Won't Hold Prime
When you add water but it immediately drains out, you have an air leak in your suction system:
- Check pump lid O-ring for proper seating and lubricate with pool-safe lubricant
- Inspect all unions and connections on suction lines for loose fittings
- Examine the skimmer and main drain plumbing for cracks
- Look for damaged pipe underground (may require professional help)
- Check if your water level is too low, causing skimmer to suck air
Pump Runs But Won't Pull Water
This usually indicates a significant air leak or blockage:
- Verify all suction-side valves are fully open
- Clean out clogged skimmer baskets and pump strainer basket
- Check for closed or partially closed valves
- Inspect for major leaks in underground plumbing
- Consider if your pump may have lost significant capacity due to wear
Different Pump Types and Priming
Single-Speed and Two-Speed Pumps
Traditional pumps typically require manual priming as described above. Some Pentair and Hayward models have slight self-priming capabilities but still benefit from manual priming, especially after extended shutdowns.
Variable Speed Pumps
Many variable speed pumps like the Pentair IntelliFlo or Hayward TriStar VS have enhanced self-priming features. However, they still require initial priming after service. These pumps often have priming modes that run at higher speeds to help establish prime more quickly.
Preventing Prime Loss
Maintaining prime prevents many headaches:
- Keep pool water level at proper height (middle of skimmer opening)
- Regularly clean skimmer and pump baskets to prevent flow restrictions
- Service pump lid O-rings annually with pool-safe lubricant
- Address small leaks promptly before they worsen
- Never run your pump dry
- During maintenance, plug suction lines to prevent prime loss
Contact a pool technician if you experience:
- Repeated prime loss despite following proper procedures
- Underground plumbing leaks requiring excavation
- Pump motor issues or unusual noises beyond normal priming sounds
- Electrical problems with pump controls
- Cracked pump housings or major component failures
Proper priming is essential for pump longevity and efficient pool circulation. Taking time to prime correctly protects your investment and ensures your pool stays clean and safe for swimming.
