Should You Shock Your Pool Before Closing for Winter?
Should I add shock treatment before winterizing my pool?
The pool shutdown is coming up and I'm probably overthinking this, but should I really be shocking before closing or am I missing something obvious? My pool looks pretty clear right now, but I've heard mixed advice about whether you need to shock the water as part of the winterization process. Some people say it's essential, others say it's a waste of money if the water already looks good. What's the right approach here? I'd rather spend a little extra now than deal with a mess when I open next spring.
Yes, shocking your pool before closing is recommended even if the water looks clear. This ensures any hidden contaminants are eliminated and prevents algae growth during the closed season.
Why Shocking Before Closing Makes Sense
First question: does your pool water look crystal clear right now but you're still debating whether to shock before closing? Even when your pool looks pristine, there can be organic contaminants, bacteria, and early-stage algae spores that aren't visible to the naked eye. A proper shock treatment before winterizing eliminates these potential problems and sets you up for a much easier spring opening.
The key principle here is prevention. It's far easier and less expensive to shock now than to deal with a green, algae-filled pool when you remove the cover next year. Water chemistry changes slowly over the winter months, and any contaminants present at closing will have months to multiply and establish themselves.
The Right Way to Shock Before Winterizing
Timing is everything when it comes to pre-closing shock treatments. You'll want to shock your pool about 24-48 hours before you actually close it, giving the chlorine time to do its work and then dissipate to safer handling levels.
Start by testing your water chemistry completely. Your pH should be between 7.2-7.6, and total alkalinity should be in the 80-120 ppm range. If these aren't balanced, adjust them first - shock treatments work much more effectively when your water chemistry is properly balanced.
For the shock treatment itself, use calcium hypochlorite (cal-hypo) rather than dichlor or trichlor products. Cal-hypo doesn't add cyanuric acid to your water, which is important since CYA levels can build up over the closed season. Use our chlorine calculator to determine the exact amount needed for your pool size.
Dosing and Application
Shock dosage varies by pool conditions and manufacturer recommendations - typically around 1 pound of cal-hypo per 10,000 gallons, but always follow product label instructions for your specific situation. Dissolve the shock in a bucket of pool water first - never add it directly to the pool. Always wear safety goggles and gloves when handling pool chemicals, and add chemicals to water, never water to chemicals. Pour the dissolved solution around the perimeter of the pool while the pump is running to ensure even distribution.
Run your filtration system for at least 8 hours after shocking to circulate the treated water and filter out any particles that the chlorine breaks down. This also helps ensure even distribution throughout your pool's water volume.
What Happens If You Skip the Pre-Closing Shock
Pools that aren't shocked before closing commonly develop algae problems over the winter months. Even with a good winter cover, some light penetration and organic debris can fuel algae growth. Without adequate sanitizer levels, these organisms have free rein to multiply.
Come spring, you might face a full-scale algae bloom that requires the complete SLAM treatment process to clear. This typically takes several days, uses significantly more chemicals, and delays your pool opening by at least a week.
Coordinating with Other Closing Steps
The shock treatment should be part of your broader winterization routine, not a standalone process. After shocking and allowing the chlorine to dissipate, you'll still need to balance your closing chemistry according to your specific climate and cover type.
Most winterizing guides recommend slightly higher pH levels (around 7.6) and alkalinity (100-120 ppm) for the closed season, as these tend to drift downward over time. You'll also want to add your winter algaecide after the shock treatment has done its work - adding algaecide too early can interfere with the shock's effectiveness.
For a complete step-by-step approach to pool closing, refer to our detailed winterization guide that covers all the chemical and mechanical aspects of proper pool closing.
Special Considerations for Different Pool Types
Salt water pools still benefit from pre-closing shock treatments, even though they generate their own chlorine. The salt cell's production drops significantly in cooler water, so a manual shock ensures adequate sanitizer levels going into winter.
Vinyl liner pools can use the same shock treatment approach, but be extra careful about dissolving the chemicals completely before adding them to avoid any potential liner damage from undissolved granules.
Above-ground pools often have less water volume, making the shock treatment more cost-effective and faster-acting. However, they also tend to accumulate more debris under winter covers, making the pre-closing shock even more important.
