Do You Need Sand for Above Ground Pool? Complete Guide
Nicole F.
Saltwater Pool Convert
Do I actually need sand under my first above ground pool?
Already embarrassed to ask this, but why is everyone giving me completely different advice about whether I need sand under my first above ground pool?
I'm honestly pretty confused about what's actually required versus what's just recommended. Does it depend on the type of pool I have or the condition of my yard? I want to make sure I do this right since it's my first time, but I also don't want to spend money on sand if there are other options that work just as well.
Sand is not always required for above ground pools - it depends on your pool type, ground conditions, and manufacturer requirements. Many pools use foam padding or ground cloth instead.
Diagnosing Your Sand Requirements
The need for sand under your above ground pool isn't universal. Start by checking these critical factors:
When Sand is Required
Manufacturer Specifications
Several major above ground pool manufacturers, including some Intex and Coleman models, recommend a sand base as an option in their installation instructions. These pools typically require a 2-3 inch layer of mason sand (similar to but typically finer than concrete sand) spread evenly across the pool area.
Ground Condition Problems
Sand becomes necessary when your installation site has these issues:
Sand Alternatives and Solutions
Foam Pool Padding
Many pool owners successfully use closed-cell foam padding instead of sand. This option provides excellent cushioning, won't shift over time, and creates a moisture barrier. Foam padding works particularly well on relatively level, firm ground.
Ground Cloth Systems
Heavy-duty ground cloth or pool underlayment offers puncture protection without the labor intensity of sand installation. These materials work best on already-level surfaces and provide adequate protection for most above ground pools.
Crushed Stone Base
For permanent installations or problematic soil conditions, a crushed stone base with proper drainage may be superior to sand. This involves excavating 6-8 inches, installing crushed stone, and topping with sand or foam padding.
Proper Sand Installation Process
If your diagnosis indicates sand is necessary, follow this systematic approach:
  1. Calculate sand requirements - Plan for 2-3 inches of depth across an area extending 1 foot beyond the pool edge all around (creating an area 2 feet larger than your pool diameter
  2. Excavate the area - Remove grass, roots, and debris to create a level base
  3. Order mason sand - Avoid play sand or sandbox sand, which is too fine and shifts easily
  4. Spread sand evenly - Use a rake to distribute sand, then level with a long 2x4 board
  5. Compact lightly - Walk over the entire area or use a hand tamper, but don't over-compact
  6. Check for level - Use a carpenter's level on your 2x4 to ensure the entire pool area is level within manufacturer specifications (typically no more than 1 inch across the entire area)
  7. Smooth the surface - Remove any footprints or irregularities before pool installation
Common Installation Mistakes
Wrong Sand Type
Using play sand instead of mason sand creates problems. Play sand is too fine, shifts easily, and doesn't provide stable support. Mason sand has angular particles that lock together better.
Excessive Depth
More than 3 inches of sand can create instability problems. The pool walls may settle unevenly, causing structural stress and potential collapse.
Inadequate Compaction
Loose sand will shift under the pool's weight, creating low spots that stress the liner and pool structure. Light compaction is essential for stability.
Maintenance Considerations
Sand bases require periodic maintenance throughout your pool's life. Check annually for settling or washing away of sand, particularly after heavy rains or pool drainage. Add sand as needed to maintain proper support.
Ground cloth or foam alternatives typically last the pool's lifetime without maintenance, making them attractive options when suitable for your conditions.
Cost Analysis
Sand installation costs vary significantly by region and pool size. A typical 24-foot round pool requires approximately 4-6 cubic yards of mason sand, costing $150-300 including delivery. Factor in rental costs for leveling tools and the significant labor involved.
Foam padding systems cost $100-200 for the same pool size but install much faster with less physical effort. Ground cloth solutions typically cost $50-100 but provide less cushioning than other options.
Safety Warning: Never install any above ground pool on unlevel ground exceeding manufacturer specifications, regardless of base material. Uneven installations can lead to catastrophic pool failure and potential injury.
rake 2x4 leveling board carpenter's level hand tamper measuring tape shovel
Tags: #installation #sand base #pool setup #ground preparation
