Can Salt Water Pools Raise Blood Pressure? Health Facts
Will swimming in my saltwater pool mess with my blood pressure?
Despite looking at my saltwater pool right now and there's all this concern about salt exposure potentially affecting my blood pressure like my doctor mentioned. I'm wondering if all that time I spend floating around in there could actually be making things worse? Like, am I basically soaking in a giant salt bath that's gonna spike my BP?
I know the ocean is super salty, but I'm not sure how my pool compares. Plus I've been having some skin irritation issues lately when the chemicals get out of whack - could that stress be affecting my blood pressure too? Just trying to figure out if my relaxing pool time is actually working against me here!
Salt water pools do not raise blood pressure through skin absorption, as pool salt levels are much lower than ocean water. However, improper chemical balance can cause skin irritation that may indirectly affect stress levels.
Diagnosing the Health Concern
First, let's diagnose the root of this concern. Many pool owners worry about salt water pools affecting their health, particularly blood pressure, due to misconceptions about how salt water generators work. The confusion often stems from comparing pool salt levels to dietary salt intake recommendations.
Pool salt (sodium chloride) in a salt water pool serves as the raw material for chlorine generation through electrolysis. The salt doesn't disappear - it remains in the water at consistent levels. However, these levels are:
- 10-13 times lower than ocean water
- Equivalent to about 1/4 teaspoon of salt per gallon
- Below the taste threshold for most people
- Not absorbed through skin in meaningful amounts
Understanding Salt Water Pool Chemistry
To properly address health concerns, you need to understand your pool's actual chemistry. Test your water weekly using a quality test kit like the Taylor K-2006C to monitor these parameters:
Critical Levels for Health and Comfort
- Salt Level: 2,700-3,400 ppm (follow your generator's specifications)
- Free Chlorine (FC): 1-3 ppm for daily use, higher during SLAM treatment
- pH: 7.4-7.6 for optimal comfort and sanitizer efficiency
- Total Alkalinity: 60-80 ppm for salt water pools
- Calcium Hardness: 250-350 ppm for plaster pools, 150-250 for vinyl/fiberglass
- Cyanuric Acid (CYA): 70-80 ppm for salt water generators
Troubleshooting Actual Health Impacts
Problem 1: Skin and Eye Irritation
If you're experiencing irritation that causes stress (potentially affecting blood pressure indirectly), check these common causes:
- Test pH immediately - High pH (above 7.8) is the most common cause of irritation in salt pools
- Verify chlorine levels - Both too high (above 5 ppm) and too low (below 1 ppm) cause problems
- Check salt cell condition - Calcium buildup reduces efficiency and can cause pH drift
- Measure total dissolved solids - Excessive TDS (above 1,500 ppm over startup level) affects water quality
Problem 2: Metallic Taste or Skin Residue
If you notice unusual tastes or feel a film on your skin:
- Test copper and iron levels - Salt cells can liberate metals from plumbing
- Inspect your salt cell - Clean with a 10:1 solution (10 parts water to 1 part muriatic acid - always add acid to water, never water to acid) monthly
- Check calcium hardness - Low CH can make water aggressive, affecting metal components
- Verify proper grounding - Electrical issues can accelerate corrosion
Solutions for Optimal Health and Comfort
Maintaining Proper Balance
- Balance pH first: Add muriatic acid in 1-pint increments per 10,000 gallons to lower pH by 0.2 units
- Adjust alkalinity: Use muriatic acid to bring TA to 60-80 ppm range
- Calibrate salt levels: Add pool salt at 8.5 lbs per 1,000 gallons to raise levels by 1,000 ppm
- Clean salt cell regularly: Inspect every 3 months, clean when calcium deposits are visible
- Monitor chlorine production: Adjust generator output to maintain 1-3 ppm FC
Special Considerations for Hypertension
If you have diagnosed high blood pressure:
- Consult your physician about swimming frequency and duration
- Monitor pool temperature - Hot water can affect circulation
- Stay hydrated - Chlorinated water can have a mild diuretic effect
- Rinse immediately after swimming to remove any chemical residue
Contact a pool professional if:
- You cannot maintain stable pH levels
- Salt cell requires frequent cleaning
- Water consistently appears cloudy or has strong chemical odors
- You experience persistent skin irritation despite balanced chemistry
Consult your doctor if:
- You have uncontrolled hypertension
- Swimming causes unusual fatigue or dizziness
- You develop skin reactions or respiratory irritation
Prevention and Long-term Health
Maintain a healthy salt water pool environment by:
- Testing weekly during swim season, bi-weekly during off-season
- Keeping detailed logs of chemical additions and readings
- Replacing test reagents annually for accurate readings
- Scheduling professional inspections of electrical components annually
- Following TFP methodology for any algae or clarity issues
Remember that properly maintained salt water pools are generally gentler on skin and eyes than traditional chlorine pools, making them potentially more comfortable for people with sensitivities. The key is maintaining proper chemical balance through regular testing and appropriate adjustments.
