Does Salt Pool Need CYA? Stabilizer Requirements for SWG
Rebecca T.
DIY Pool Enthusiast
Do I really need CYA stabilizer in my salt water pool?
Around year 8 with my salt water generator and it's still running strong, but the pool store keeps pushing cyanuric acid — necessary or just a sales pitch? I thought the whole point of switching to salt was to avoid constantly buying chemicals!
My salt water generator seems to be working fine making chlorine, so do I actually need this CYA stuff? And if so, what levels should I be targeting - same as regular chlorine pools or different? Looking to understand what's truly necessary vs what's just another upsell.
Yes, salt pools absolutely need CYA (cyanuric acid) stabilizer to protect the chlorine produced by your salt water generator from UV degradation. Salt pools actually require higher CYA levels (70-80 ppm) compared to traditional chlorine pools (30-50 ppm).
Why Salt Pools Need CYA Stabilizer
Despite what many pool owners believe, salt water pools aren't magically exempt from needing CYA stabilizer—in fact, they require it just as much as traditional chlorine pools. This is a critical component that many new salt pool owners overlook, leading to rapid chlorine loss and constant algae battles.
Your salt water generator (SWG) produces pure chlorine through electrolysis, but this chlorine is completely vulnerable to UV destruction without proper stabilizer protection. In direct sunlight, unstabilized chlorine can lose 90% of its effectiveness within 2-3 hours. CYA acts like sunscreen for your chlorine, forming cyanurate-chlorine complexes that resist UV degradation while still maintaining sanitizing power.
Optimal CYA Levels for Salt Water Generators
Salt pools require higher CYA levels than traditional chlorine pools due to how salt water generators operate:
The higher range for salt pools accounts for the constant chlorine production. Your SWG runs for several hours daily, and without adequate stabilizer protection, you'll waste enormous amounts of energy producing chlorine that immediately dissipates in sunlight.
Testing and Adjusting CYA Levels
Use a quality test kit like the Taylor K-2006 to measure CYA levels accurately. Pool store test strips are notoriously unreliable for CYA readings.
Adding Stabilizer to Your Salt Pool
If your CYA is below 70 ppm, you'll need to add cyanuric acid:
Safety warning: Always add chemicals to water, never water to chemicals. Wear protective equipment when handling cyanuric acid.
The FC/CYA Relationship
CYA levels directly impact how much free chlorine (FC) your pool needs. Higher CYA requires proportionally higher chlorine levels to maintain the same sanitizing effectiveness.
For salt pools with 70-80 ppm CYA, target these FC levels:
If algae appears, you'll need to perform a SLAM (Shock Level And Maintain) process, maintaining FC at shock level (approximately 32 ppm for 80 ppm CYA) until the pool clears completely.
Managing CYA in Established Salt Pools
Unlike traditional pools where you add stabilized chlorine products, salt pools don't naturally accumulate CYA from chlorine production since the generator produces pure chlorine. However, CYA can still build up from:
When CYA Gets Too High
If CYA exceeds 100 ppm, you'll experience chlorine lock - your sanitizer becomes ineffective regardless of FC levels. The only solution is partial water replacement:
Seasonal CYA Management
CYA levels remain relatively stable in salt pools, but monitor them monthly during swimming season. UV degradation slowly reduces CYA over time, typically requiring annual adjustment.
Test CYA levels:
Remember that proper CYA levels are essential for your salt water generator's efficiency and longevity. Running your SWG without adequate stabilizer forces it to work harder, potentially shortening cell life and increasing energy costs. Maintain that 70-80 ppm sweet spot, and your salt pool will reward you with crystal-clear, properly sanitized water.
Taylor K-2006 test kit cyanuric acid stabilizer measuring cup mixing bucket protective equipment
Tags: #CYA #stabilizer #salt water generator #cyanuric acid #chlorine protection
