Is it safe to run my pool pump with a broken skimmer temporarily?
I'm wondering if I can temporarily close off the skimmer line completely and just run the pump using suction from the main drain until I can fix the skimmer properly. Will this provide adequate circulation for my pool size, and are there any risks I should be aware of? I'm concerned about whether the main drain alone can handle all the filtration needs and if this might cause any damage to my pump or affect water quality during this temporary period.
You can temporarily run your pool pump without a skimmer by using only the main drain for suction, but this reduces circulation efficiency and surface debris removal. This should only be a short-term solution while you repair or replace the skimmer. Bump your free chlorine a little above your CYA-based target to compensate for reduced circulation and test water chemistry twice daily. Ensure proper safety precautions and monitor for issues that indicate the need for permanent repairs.
How to Run Your Pump Without Skimmer
Method 1: Main Drain Only Operation
- Locate your skimmer valve - Find the valve that controls water flow from the skimmer line to your pump
- Close the skimmer valve completely - Turn the valve handle to shut off suction from the skimmer
- Open the main drain valve fully - Ensure maximum suction from the bottom of your pool. Verify that your main drain has a proper VGB-compliant anti-entrapment cover securely in place before operating
- Prime your pump - Fill the pump basket and impeller housing with water to prevent air lock
- Start the pump - Begin with shorter run times and monitor for proper operation
- Check for proper flow - Verify water is circulating through your filter and returning to the pool
Method 2: Temporary Skimmer Bypass
If your main drain isn't functioning properly, you can create a temporary suction line:
- Use a vacuum hose - Connect a pool vacuum hose to the suction side plumbing using a dedicated suction port (consult your pool professional if unsure about proper connection points)
- Submerge the other end - Place the free end of the hose in the deep end of your pool, ensuring a leaf trap or inline strainer is installed to prevent large debris from entering the pump
- Prime the system - Fill the hose with water to eliminate air bubbles
- Start the pump gradually - Begin operation and adjust flow as needed
Why This Isn't Ideal Long-Term
Circulation Problems
Running without a skimmer creates several circulation issues. Your pool's skimmer removes the majority of floating contaminants before they sink to the bottom. Without it, leaves, oils, and debris accumulate on the surface, creating unsanitary conditions and increased chemical demand.
Filtration Efficiency Drops
Main drain-only operation pulls water from the bottom of your pool, missing the crucial surface layer where most contamination occurs. This leads to cloudy water, algae growth potential, and higher sanitizer consumption.
Energy Costs Increase
Your pump may work harder to maintain proper flow rates when relying solely on main drain suction, especially if the drain is partially blocked or the line has restrictions.
Water Chemistry Adjustments
When operating without a skimmer, you'll need to be more aggressive with your chemical maintenance:
Increase Chlorine Levels
Boost your free chlorine (FCFree Chlorine — The chlorine actively sanitizing your water right now. This is the number you keep an eye on. how much you need →) by 1-2 ppm above your typical target levels (your target scales with CYACyanuric Acid (stabilizer) — Sunscreen for your chlorine — it keeps sunlight from burning it off. The catch: the more you have, the more chlorine you need to keep. learn more → — there is no flat "standard" number) to compensate for reduced circulation. Test daily using a Taylor K-2006C test kit and maintain FC according to your cyanuric acid (CYA) levels using the all-in-one pool calculator.
More Frequent Testing
Test your water chemistry twice daily instead of the normal every-other-day schedule. Pay special attention to:
- Free Chlorine - Should remain consistent throughout the day
- pH levels - Target 7.4-7.6 for comfort and balanced water
- Total Alkalinity - Maintain 80-120 ppm for pH stability
Brush More Frequently
Without proper surface skimming, brush your pool walls and floor twice daily to prevent algae establishment and keep debris in suspension for the main drain to capture.
Safety Precautions
Never run your pump dry - Without proper suction, pumps can lose prime and run without water, causing expensive damage to the impeller and motor.
Monitor pressure gauges closely - Watch your filter pressure gauge for unusual readings that might indicate flow problems or air in the system.
Avoid swimming during initial startup - Until you verify proper circulation patterns, avoid pool use to prevent safety issues.
Main drain entrapment warning - Never swim when operating on main drain suction only, as this creates potential entrapment hazards. Ensure main drain covers are VGB-compliant and in good condition before operating.
When to Make Permanent Repairs
This temporary solution should last no more than 1-2 weeks. Schedule skimmer repairs immediately if you notice:
- Persistent surface debris accumulation
- Difficulty maintaining proper chlorine levels
- Increased algae growth or water cloudiness
- Higher than normal chemical consumption
- Reduced water clarity despite proper chemical balance
Common Skimmer Problems Requiring This Fix
Cracked Skimmer Body
Underground leaks in the skimmer housing can cause air intrusion, making normal operation impossible until repairs are completed.
Blocked Skimmer Line
Debris, toys, or even small animals can completely block the suction line from skimmer to pump.
Broken Skimmer Basket Housing
Damaged basket housing can allow debris to enter the pump, requiring immediate shutdown until replacement parts arrive.
Remember, this bypass method is strictly temporary. Proper pool circulation requires both surface skimming and bottom suction to maintain healthy, clear water efficiently.
