How to Raise Pool Alkalinity: Complete Step-by-Step Guide
Nancy B.
Saltwater Pool Convert
Cheapest way to raise pool alkalinity without pool store ripoff?
Planning my weekly pool maintenance this morning when I spotted cloudy, dull water that was crystal clear yesterday, plus my test strips are showing low alkalinity. My 10,000 gallon pool's alkalinity is low and I need to get it up by about 10 ppm.
I know there has to be a DIY solution that doesn't break the bank. What's the most cost-effective way to raise alkalinity myself? I have basic test strips so I can monitor the levels, just need to know the right chemical and dosage amounts.
Raise pool alkalinity by adding sodium bicarbonate (baking soda) at a rate of 1.5 pounds per 10,000 gallons to increase alkalinity by 10 ppm. Test first, add chemical gradually, and retest after 6 hours.
First, Let's Diagnose Your Alkalinity Problem
Wondering why your pool water stays cloudy and your chemicals never seem to work properly? The answer is simpler than you think. Low alkalinity typically shows these symptoms:
Test your water using a reliable test kit like the Taylor K-2006 or comparable digital tester. Your target alkalinity should be 80-120 ppm for traditional chlorine pools, or 60-80 ppm for salt water generator pools.
Primary Solution: Adding Sodium Bicarbonate
The most effective and economical way to raise alkalinity is using sodium bicarbonate, commonly known as baking soda. However, use pool-grade sodium bicarbonate rather than grocery store baking soda for large adjustments.
Calculating the Correct Dose
Use this precise formula: 1.5 pounds of sodium bicarbonate per 10,000 gallons will raise alkalinity by 10 ppm.
For example, if your 20,000-gallon pool tests at 60 ppm and you want to reach 100 ppm (a 40 ppm increase), you'll need: 20,000 gallons ÷ 10,000 = 2, then 2 × 1.5 pounds × 4 (for 40 ppm increase) = 12 pounds of sodium bicarbonate.
Step-by-Step Application Process
  1. Test current levels: Measure both alkalinity and pH before starting. Record these numbers.
  2. Calculate needed amount: Use the formula above to determine exact chemical requirements.
  3. Prepare the pool: Ensure your circulation system is running and will continue for at least 6 hours.
  4. Add chemical gradually: Never dump all the sodium bicarbonate at once. Add no more than 2-3 pounds per 10,000 gallons in a single application.
  5. Distribute evenly: Walk around the pool perimeter, broadcasting the sodium bicarbonate across the water surface, focusing on the deep end.
  6. Allow circulation: Let the pump run for at least 6 hours to fully dissolve and distribute the chemical.
  7. Retest and adjust: Test alkalinity again after 6-8 hours. If you need more, repeat the process.
Alternative Solutions for Specific Situations
When pH is Also Low
If both alkalinity and pH are low, sodium bicarbonate is still your best choice as it raises both parameters. However, if alkalinity is low but pH is already high (above 7.8), you may need to lower pH first with muriatic acid, then raise alkalinity with sodium bicarbonate in smaller increments to avoid overshooting pH.
For Salt Water Generator Pools
SWG pools should maintain lower alkalinity (60-80 ppm) because the chlorine generation process naturally drives pH up. If your alkalinity is extremely low (below 40 ppm), add sodium bicarbonate conservatively and monitor pH closely.
Common Troubleshooting Issues
Alkalinity Won't Stay Stable
If alkalinity keeps dropping after you raise it, investigate these causes:
pH Rises Too High After Treatment
Sodium bicarbonate will raise pH along with alkalinity. If pH exceeds 7.8 after treatment:
  1. Stop adding sodium bicarbonate temporarily
  2. Add muriatic acid or sodium bisulfate to lower pH to 7.4-7.6
  3. Wait at least 4-6 hours for complete circulation and mixing before retesting both parameters
  4. Continue alkalinity adjustments if needed
Safety Considerations and Best Practices
Safety first: Always add chemicals to water, never water to chemicals. Wear safety glasses and avoid inhaling chemical dust. Store sodium bicarbonate in a cool, dry location away from other pool chemicals.
For ongoing maintenance, test alkalinity weekly and adjust promptly when it drops below your target range. Small, frequent adjustments are easier to manage than large corrections.
Remember that alkalinity acts as a buffer for pH, so stable alkalinity means stable pH, which translates to more effective chlorine and better overall water balance.
pool test kit sodium bicarbonate measuring cup safety glasses
Tags: #alkalinity #sodium bicarbonate #water balance #pH #pool chemistry
