Does a Pool Need CYA? Cyanuric Acid Requirements Explained
Do I actually need cyanuric acid in my pool or is it optional?
Before I shell out $180 for my pool guy to balance my cyanuric acid levels, I'm wondering if this is something I can figure out myself. Some people say it's absolutely essential, others act like it's just another chemical companies are trying to sell me. My pool keeps eating through chlorine like crazy and I'm wondering if CYA is the missing piece.
I've got a regular chlorine pool (not saltwater) and I'm tired of adding shock every other day just to keep it clear. Is cyanuric acid actually necessary, and if so, what levels should I be targeting? I want to get this right once and for all instead of throwing more money at random chemicals.
Yes, pools need CYA (cyanuric acid) to protect chlorine from UV degradation. Target 30-50ppm for regular pools and 70-80ppm for salt water generators.
First, Let's Diagnose Your CYA Situation
Before determining what action to take, you need to identify your current CYA status and pool type:
Test Your Current CYA Level
Use a reliable test method to measure your existing CYA. The Taylor K-2006C test kit provides the most accurate readings using the turbidity method. Pool test strips are notoriously inaccurate for CYA testing and should be avoided for this critical measurement.
If you don't have a proper test kit, take a water sample to a pool store, but specify you want a CYA test - many basic tests don't include it.
Identify Your Pool System Type
- Traditional chlorine pools: Target CYA range of 30-50ppm
- Salt water generator (SWG) pools: Target CYA range of 70-80ppm
- Indoor pools: May not need CYA since UV exposure is minimal
Why Your Pool Needs CYA
UV Protection for Chlorine
Cyanuric acid forms a weak bond with free chlorine, creating a protective shield against ultraviolet rays. Without this protection, a properly chlorinated pool can lose all its sanitizing power in just 2-3 hours of direct sunlight. This explains why some pool owners struggle with constant algae problems despite adding chlorine regularly.
Economic Benefits
Properly stabilized pools use significantly less chlorine. A pool with 40ppm CYA will retain chlorine 8-10 times longer than an unstabilized pool, translating to substantial chemical cost savings over a swimming season.
Target CYA Levels and Chlorine Relationship
CYA and free chlorine work together in a specific ratio. Higher CYA levels require proportionally higher chlorine levels to maintain effective sanitization:
- CYA 30ppm: Minimum FC 2ppm, Shock level 12ppm
- CYA 40ppm: Minimum FC 3ppm, Shock level 15ppm
- CYA 50ppm: Minimum FC 4ppm, Shock level 19ppm
- CYA 70ppm: Minimum FC 5ppm, Shock level 26ppm
- CYA 80ppm: Minimum FC 6ppm, Shock level 30ppm
Salt water generators work more efficiently with higher CYA levels (70-80ppm) because the constant chlorine production compensates for the higher minimum chlorine requirements.
Solutions for Different CYA Scenarios
Scenario 1: No CYA Present (0-10ppm)
Add stabilizer immediately using these dosing guidelines:
- Granular cyanuric acid: 13 ounces per 10,000 gallons raises CYA by 10ppm
- Stabilized chlorine (dichlor): 1 pound per 10,000 gallons adds approximately 9ppm CYA
For granular stabilizer, pre-dissolve in warm water or add directly to skimmer with pump running. Full dissolution takes 24-48 hours, so retest after this period.
Scenario 2: Low CYA (10-29ppm)
Calculate the difference between your current level and target level, then dose accordingly. For example, if you have 20ppm and want 40ppm in a 15,000-gallon pool:
(40-20) × 15,000 ÷ 10,000 × 13 ounces = 39 ounces of granular cyanuric acid
Scenario 3: Optimal CYA Range
Maintain current levels through regular testing. CYA doesn't degrade from sunlight or normal pool operations, so levels remain stable unless you drain water or experience heavy rainfall overflow.
Scenario 4: High CYA (Over 50ppm for regular pools, over 80ppm for SWG)
The only way to reduce CYA is dilution through partial water replacement. Calculate the percentage of water to replace:
Water replacement % = (Current CYA - Target CYA) ÷ Current CYA × 100
Special Considerations and Warnings
Stabilized vs. Unstabilized Chlorine
Warning: Trichlor tablets and dichlor shock contain cyanuric acid. Using these products exclusively will cause CYA to climb above optimal levels over time. Balance your sanitization approach by using unstabilized liquid chlorine for daily dosing and save stabilized products for specific applications.
New Pool Startup
Add CYA early in the startup process, ideally before or immediately after achieving proper pH and alkalinity balance. This prevents chlorine waste during the initial sanitization phase.
Seasonal Considerations
CYA becomes more critical during peak sun months (May through September). Pools that seem fine in spring may struggle with chlorine loss as UV intensity increases through summer.
Testing and Maintenance Schedule
Test CYA levels monthly during swimming season and after any significant water dilution events. Unlike other chemical parameters that require frequent adjustment, CYA typically remains stable for extended periods.
Retest 48 hours after any CYA additions to verify dissolution and proper levels before adjusting chlorine targets accordingly.
