Can Pool Chemicals Make You Sick? Health Risks Explained
What health risks come from swimming pool chemicals?
Before I let my kids jump in this morning, I spotted a strong chemical smell around our freshly treated 20,000-gallon pool that wasn't there yesterday. I've been handling chlorine tablets, shock treatments, and pH adjusters, but I'm concerned about whether these chemicals could be making my family sick. We've noticed some skin irritation after swimming sessions, and I occasionally experience a scratchy throat after adding chemicals to the water.
I maintain chlorine levels around 2-3 ppm and pH between 7.2-7.6 based on my test strips, but I'm wondering if exposure to these chemicals during storage, handling, or swimming could cause health problems. I store all chemicals in my garage and sometimes notice strong fumes when opening containers. What are the main ways pool chemicals can affect your health, and how can I minimize any risks while keeping the water safe for swimming?
Pool chemicals can make you sick through skin irritation, respiratory problems, and chemical burns when improperly handled or when chemical levels are imbalanced. Proper storage, handling, and water chemistry prevent most health risks.
How Pool Chemicals Can Affect Your Health
Direct Chemical Exposure
The most immediate danger comes from direct contact with concentrated pool chemicals. Chlorine gas exposure can occur when chemicals are mixed improperly or stored in poorly ventilated areas. This can cause severe respiratory irritation, coughing, chest pain, and in extreme cases, chemical pneumonia.
Skin contact with concentrated chemicals like muriatic acid or calcium hypochlorite can cause chemical burns. Even brief exposure to dry chlorine can irritate skin and eyes, while prolonged contact may result in serious burns requiring medical attention.
Swimming in Chemically Imbalanced Water
Poor water chemistry creates several health risks. When pH levels are too high (above 7.8), chlorine becomes less effective, allowing harmful bacteria and algae to thrive. Low pH (below 7.0) makes water acidic, causing eye and skin irritation, and can damage pool equipment.
High chlorine levels (above 10 ppm free chlorine) can cause skin rashes, eye irritation, and respiratory problems, especially for sensitive individuals. Conversely, insufficient chlorine allows dangerous pathogens like E. coli, Cryptosporidium, and Legionella to multiply.
Specific Health Risks and Symptoms
Respiratory Issues
Chloramines (combined chlorine) create that strong "chlorine smell" and cause the most respiratory problems. When chloramine levels exceed 0.5 ppm, swimmers may experience:
- Coughing and throat irritation
- Chest tightness
- Wheezing or asthma-like symptoms
- Nasal congestion
- Eye irritation and redness
Indoor pools with poor ventilation pose higher risks, as chloramine gases become concentrated in the air.
Skin and Eye Problems
Imbalanced pool chemistry commonly causes:
- Red, itchy, or burning eyes
- Skin rashes and dryness
- Hair discoloration and brittleness
- Eczema flare-ups in sensitive individuals
- Contact dermatitis from chemical residues
Gastrointestinal Illness
Poorly sanitized pools can harbor waterborne pathogens causing:
- Diarrhea and stomach cramps
- Nausea and vomiting
- Cryptosporidiosis (resistant to normal chlorine levels)
- Giardia infections
Prevention Through Proper Chemical Management
Maintaining Safe Chemical Levels
Follow these TFP (Trouble Free Pool) guidelines for safe water chemistry:
- Free Chlorine (FC): 1-3 ppm for traditional pools with CYA 30-50 ppm; 5-7+ ppm for salt pools with CYA 70-80 ppm
- pH: 7.4-7.6 for optimal comfort and chlorine effectiveness
- Total Alkalinity (TA): 80-120 ppm for traditional pools, 60-80 for salt water generators
- Cyanuric Acid (CYA): 30-50 ppm for traditional pools; 70-80 ppm for salt water systems
- Combined Chlorine: Keep below 0.5 ppm to minimize chloramine formation
Test water chemistry 2-3 times weekly using a reliable test kit like the Taylor K-2006. Retest 30 minutes after adding chemicals to verify proper levels.
Safe Chemical Handling Practices
Always wear protective equipment: safety goggles, chemical-resistant gloves, and long sleeves when handling concentrated chemicals. Work in well-ventilated areas to avoid inhaling fumes.
Never mix chemicals: Add chemicals to water separately, waiting at least 10 minutes between most additions (30+ minutes between muriatic acid and chlorine). Mixing dry chemicals can cause violent reactions, fires, or toxic gas release.
Proper storage: Keep chemicals in original containers, away from heat sources, and in a cool, dry location. Store liquid chlorine and muriatic acid separately from other chemicals.
When Pool Chemicals Become Dangerous
Emergency Situations
Seek immediate medical attention if you experience:
- Severe breathing difficulty after chemical exposure
- Chemical burns on skin or in eyes
- Persistent coughing or chest pain
- Severe skin reactions or blistering
For chemical spills or skin contact: Immediately flush affected areas with clean water for at least 15 minutes. Remove contaminated clothing and seek medical attention for severe exposure.
High-Risk Individuals
People with asthma, allergies, or sensitive skin should be extra cautious around pool chemicals. Children and pregnant women may be more susceptible to chemical irritation and should avoid areas during chemical treatment.
Safe Swimming Practices
Wait appropriate times before swimming after chemical additions:
- Liquid chlorine: 30 minutes with circulation running
- Muriatic acid: 1 hour minimum
- Shock treatment: Until you can clearly see the bottom and main drain
Shower before and after swimming to remove chemical residues and reduce contamination. Avoid swallowing pool water, and teach children proper pool hygiene.
By following proper chemical handling procedures and maintaining balanced water chemistry, you can enjoy your pool safely while minimizing health risks. When in doubt, consult with a certified pool professional or your healthcare provider about specific health concerns.
