Salt Water Salt Water — How to Clean Salt Water Pool: Complete Maintenance Guide
Dave M.
Dave M.
Salt water pool maintenance - what am I missing?
Salt pool has been running great for two years but it's starting to look dull — waterline buildup, cell is crusty, and the water just doesn't sparkle like it used to. Nobody told me saltwater pools needed this much upkeep. What's the proper maintenance routine I should be following?
Cleaning a salt water pool requires testing and balancing chemistry (FC, pH, CYA), maintaining the salt cell, and regular physical cleaning of surfaces and equipment.
First, Let's Diagnose Your Salt Water Pool's Current Condition
Yes — cleaning your salt water pool requires a different approach than chlorine pools, and skipping these specific steps will leave you with cloudy water and costly repairs. Salt water pools have unique maintenance requirements compared to traditional chlorine pools, and the cleaning approach depends on your pool's current state.
Start by visually inspecting your pool water. Is it crystal clear, cloudy, green, or showing algae growth? Check your salt cell for calcium buildup or scaling. These observations will determine which cleaning protocol to follow.
Step 1: Test and Balance Water Chemistry
Salt water pool chemistry is the foundation of proper cleaning. Use a quality test kit like the Taylor K-2006 to get accurate readings of all parameters.
Critical Chemistry Parameters for Salt Water Pools:
  • Free Chlorine (FCFree Chlorine — The chlorine actively sanitizing your water right now. This is the number you keep an eye on. how much you need →): Should be the right level for your CYACyanuric Acid (stabilizer) — Sunscreen for your chlorine — it keeps sunlight from burning it off. The catch: the more you have, the more chlorine you need to keep. learn more → (typically 5-10 ppm, and never below 5, for an SWGSalt Water Generator — The "salt cell" that makes chlorine from the salt in a saltwater pool. Same chlorine — it just makes its own. pool terms → pool with CYA 70-80) for normal maintenance, higher during SLAMShock Level And Maintain — raise free chlorine to a target based on your CYA and hold it there until the algae is gone. It's a process, not a one-time dose. the SLAM walkthrough →
  • pH: Keep between 7.2-7.6 (salt cells work best in this range)
  • Total Alkalinity (TATotal Alkalinity — The buffer that keeps your pH from bouncing around. Get this in range and pH gets a lot easier to manage. learn more →): Target 60-80 ppm for salt water systems
  • Cyanuric Acid (CYA): Maintain 70-80 ppm for outdoor salt water pools
  • Salt Level: Usually 2700-3400 ppm depending on your system
  • Calcium Hardness: 250-350 ppm for plaster pools, 175-225 ppm for vinyl/fiberglass
If your FC falls below the minimum for your CYA (especially near or under 1 ppm) or you see algae, you'll need to perform a SLAM (Shock Level And Maintain) process using liquid chlorine, not your salt cell alone.
Step 2: Clean the Salt Cell
The salt cell is the heart of your system and requires regular cleaning every 3-4 months or when you notice white calcium buildup on the plates.
  1. Turn off power to the salt system
  2. Remove the salt cell from the plumbing (mark the flow direction)
  3. Inspect plates for calcium scale or debris
  4. Mix roughly 4 parts water to 1 part muriatic acid in a plastic container (add acid to water); a milder mix or plain water can clear light scale
  5. Safety Warning: Always add acid to water, never water to acid. Wear safety goggles and gloves
  6. Soak the cell for 10-15 minutes maximum
  7. Rinse thoroughly with fresh water
  8. Reinstall cell ensuring proper flow direction
Troubleshooting Salt Cell Issues:
If your cell has heavy scaling, increase cleaning frequency. If plates appear damaged or corroded, the cell may need replacement. A typical salt cell lasts 3-7 years with proper maintenance.
Step 3: Address Water Clarity Issues
For cloudy or green water, salt water pools require the same SLAM method used in traditional pools, but with additional considerations.
SLAM Process for Salt Water Pools:
  1. Turn off your salt cell during SLAM to prevent damage from high chlorine levels
  2. Add liquid chlorine to reach shock level based on your CYA reading
  3. Use the all-in-one pool calculator to determine the shock level: about 28 ppm FC for 70 ppm CYA and 31-32 ppm for 80 ppm CYA
  4. Run filtration 24/7 during SLAM
  5. Brush all surfaces twice daily
  6. Test FC 2-3 times daily, adding chlorine to maintain shock level
  7. Continue until combined chlorine (CCCombined Chlorine — "Used-up" chlorine left over from doing its job. Above about 0.5 ppm is the classic sign water needs a shock. learn more →) is 0.5 ppm or less and you pass the Overnight Chlorine Loss Test (OCLT)
For a 20,000-gallon pool, have about 10 gallons of 10% liquid chlorine on hand for a SLAM - total use depends on how long the SLAM runs, since you re-dose back to shock level several times a day until it clears.
Step 4: Physical Cleaning and Maintenance
Salt water pools still require regular physical cleaning despite the automated chlorine generation.
  1. Brush weekly: Use a nylon brush for vinyl pools, stainless steel brush for plaster (only when necessary for stubborn algae)
  2. Vacuum or run robotic cleaner: Remove debris before it decomposes
  3. Empty skimmer baskets: Check 2-3 times per week
  4. Clean pump basket: Monthly or when flow decreases
  5. Backwash filter: When pressure rises 8-10 psi above clean reading
Step 5: Equipment Inspection and Maintenance
Salt water is corrosive, requiring additional attention to metal components.
  • Inspect ladder handrails and light fixtures for corrosion
  • Check pump seals and gaskets for deterioration
  • Clean salt cell housing and connections
  • Verify proper bonding and grounding of all equipment
  • Test GFCI breakers monthly
Troubleshooting Common Salt Water Pool Problems
High pH Issues:
Salt cells naturally raise pH. If pH consistently rises above 7.6, reduce salt cell output and add muriatic acid. Calculate acid dosing based on current pH and pool volume using the all-in-one pool calculator, then retest after 4 hours.
Low Chlorine Production:
Check salt levels first. If salt is correct (testing with strips isn't accurate - use a digital tester), inspect cell for scaling or damage. Clean as described above.
Corrosion Problems:
Ensure proper water balance, especially calcium hardness. Low CH accelerates corrosion of metal components.
Prevention and Long-Term Care
Establish a routine testing schedule: test basic chemistry 2-3 times weekly, complete chemistry monthly. Keep detailed records to identify trends. Replace test reagents annually for accuracy.
During winter or extended downtime, maintain salt levels but reduce cell output. Many salt cells stop generating chlorine below about 50-60°F (check your manufacturer's spec), so switch to manual chlorination in cold weather; the real damage risk is freezing (around 32°F).
Remember: Salt water pools are not maintenance-free. They require the same attention to chemistry and cleaning as traditional pools, plus additional care for the salt cell and corrosion prevention.
Tags: #salt water pool #pool cleaning #salt cell maintenance #water chemistry #SLAM method
