How to Clean Pool Filter: Complete Troubleshooting Guide
Jennifer F.
Saltwater Pool Convert
What's the right way to clean different types of pool filters?
Standing here looking at my pool filter right now and there's conflicting advice all over the internet because my friends with cartridge, sand, and DE filters are all doing completely different maintenance routines.
Some people say rinse every week, others say backwash when you feel like it, and I have no idea what I'm supposed to be doing or when. Is there actually a proper schedule for each type of filter, or are we all just winging it and hoping our pools don't turn into swamp water?
Pool filter cleaning depends on your filter type. Cartridge filters need rinsing and rotation every 2-4 weeks, sand filters require backwashing when pressure rises 8-10 PSI, and DE filters need backwashing and fresh DE powder.
Diagnosing Your Filter Cleaning Needs
Good news: cleaning your pool filter is solidly DIY territory—no $150 service call needed, just 20 minutes and the right troubleshooting steps. The cleaning method varies dramatically depending on whether you have a cartridge, sand, or diatomaceous earth (DE) filter, and the current condition of your system.
Check your pressure gauge first. If pressure has risen 8-10 PSI above your clean starting pressure (varies by system but often 10-20+ PSI when clean), your filter needs attention. Also look for reduced water flow from return jets, cloudy water that won't clear despite proper chemistry, or if it's been 2-4 weeks since your last cleaning.
Cartridge Filter Cleaning Solutions
For cartridge filters, you'll need a rotation system with multiple sets of cartridges. Remove the dirty cartridges and rinse them with a garden hose using a spray nozzle, working from top to bottom. Spray between each pleat to remove debris.
  1. Turn off your pool pump and release system pressure
  2. Remove the filter housing lid or clamp band
  3. Lift out the dirty cartridge(s) - they may be heavy when saturated
  4. Rinse with garden hose at 45-degree angle to pleats
  5. For stubborn buildup, use a cartridge cleaning solution or TSP (trisodium phosphate)
  6. Install your clean, damp cartridges
  7. Reassemble housing ensuring proper O-ring seal
  8. Prime pump and restart system
Soak heavily soiled cartridges overnight in a cartridge cleaner solution or 1 cup TSP per 5 gallons of water. Never use a pressure washer or brush aggressively as this damages the filter media.
Sand Filter Backwashing Process
Sand filters require backwashing when pressure rises significantly. The process reverses water flow to flush trapped debris from the sand bed.
  1. Turn off pool pump completely
  2. Set multiport valve to "BACKWASH" position
  3. Turn pump back on and watch sight glass if equipped
  4. Backwash for 2-3 minutes until water runs clear
  5. Turn off pump and set valve to "RINSE"
  6. Run pump for 30 seconds to settle sand bed
  7. Turn off pump and return valve to "FILTER"
  8. Restart pump and check pressure - should drop 8-10 PSI
Warning: Never move the multiport valve while the pump is running as this can damage the valve assembly and create costly repairs.
Sand should be replaced every 3-5 years as it becomes rounded and less effective. If backwashing doesn't reduce pressure significantly, you may need fresh sand.
DE Filter Maintenance Solutions
DE filters provide the finest filtration but require more maintenance. They need backwashing plus fresh DE powder after each cleaning.
  1. Backwash similar to sand filter process above
  2. After backwashing and rinsing, add fresh DE through skimmer
  3. Use 1 pound of DE per 10 square feet of filter area
  4. Add DE slowly while pump runs to coat grids evenly
  5. Monitor pressure over next few days
Monthly, you should disassemble DE filters to clean the grids directly. Remove grids and spray clean, checking for tears or damage. Soak in TSP solution if heavily coated with oils or debris.
Chemical Balance During Filter Cleaning
Maintain proper water chemistry to reduce filter workload. Keep FC (free chlorine) at appropriate levels based on your CYA (stabilizer) level - minimum of CYA/10 for normal conditions. For example, with 40 ppm CYA, maintain 4 ppm FC minimum.
pH should stay between 7.4-7.6 for optimal filtration and sanitizer effectiveness. High pH reduces chlorine efficiency, leading to more organics that clog filters faster.
Troubleshooting Persistent Filter Problems
If filters clog quickly after cleaning, investigate root causes. Test your water chemistry - high bather loads, algae blooms, or environmental contamination create extra debris.
Short filter cycles often indicate inadequate circulation time. Run your pump 8-12 hours daily minimum, with circulation during peak sunlight hours when algae growth is highest.
Cloudy water persisting after filter cleaning may require a SLAM (Shock Level And Maintain) process. Raise FC to shock level based on CYA and maintain until water clears and chlorine loss stops overnight.
Preventive Filter Maintenance
Establish a regular cleaning schedule rather than waiting for high pressure. Cartridge filters benefit from 2-week rotations, while sand and DE filters should be backwashed when pressure rises 8 PSI.
Keep detailed records of cleaning dates and pressure readings. This helps identify patterns and optimize your maintenance schedule based on actual usage and environmental conditions.
Consider upgrading to variable speed pumps which can extend filter cycles through improved circulation patterns and energy efficiency.
garden hose with nozzle filter cleaning solution TSP or cartridge cleaner pressure gauge replacement cartridges if needed
Tags: #filter maintenance #cartridge filter #sand filter #DE filter #backwashing #pool circulation
