How to Clean Pool Cartridge Filter: Complete Guide
New pool owner - how often should I clean my cartridge filters?
Somewhere in the back of my mind I'm wondering if it's dangerous that I'm attempting to clean my cartridge filter without proper knowledge since I've got kids who use the pool daily? The pool store told me I need to clean my cartridge filters regularly, but I'm not exactly sure what the proper process is or how often I should be doing it.
I have the basic cartridge filter system, but I'm worried about damaging the filters if I clean them wrong. Should I be using any special cleaners? And I've heard people mention having spare cartridges - is that really necessary? Any step-by-step guidance would be really helpful since I want to make sure I'm maintaining everything properly.
Clean pool cartridge filters by removing them from the housing, rinsing with a garden hose from top to bottom, soaking in filter cleaner solution, and rotating with spare cartridges every 2-4 weeks for optimal performance.
Step-by-Step Cleaning Process
- Turn off your pool pump - Always ensure the system is completely shut down before removing any filter components for safety.
- Release system pressure - Open the air relief valve on top of the filter housing to release built-up pressure.
- Remove the filter housing top - Unscrew or unclamp the housing lid, depending on your system type (Pentair Clean & Clear, Hayward Star-Clear, etc.).
- Carefully lift out the cartridge - Remove the dirty cartridge, noting its orientation for proper reinstallation.
- Initial rinse - Using a garden hose with good pressure, spray the cartridge from top to bottom, working between each pleat fold.
- Rotate the cartridge - Turn it 90 degrees and repeat the rinsing process, ensuring you clean all surfaces thoroughly.
- Focus on stubborn debris - Pay special attention to areas with visible dirt, oils, or algae buildup between the pleats.
- Final inspection - Check that all visible debris has been removed and the pleats appear clean and white.
Deep Cleaning with Chemical Solutions
For cartridges with heavy buildup, oils, or persistent staining, a chemical cleaning is necessary:
TSP (Trisodium Phosphate) Cleaning
Safety Warning: Wear gloves and eye protection when handling TSP as it can cause skin and eye irritation.
- Mix 1 cup of TSP per 5 gallons of water in a clean bucket or trash can
- Submerge the rinsed cartridge completely in the solution
- Allow to soak for 8-12 hours or overnight
- Remove and rinse thoroughly with fresh water
- Let air dry completely before reinstalling
Commercial Filter Cleaners
Products like Natural Chemistry Filter Perfect or Leisure Time Filter Clean work effectively for routine deep cleaning. Follow manufacturer instructions for dilution ratios, typically 1 part cleaner to 10 parts water.
Cartridge Rotation System
The most effective maintenance approach involves having two sets of cartridges:
- Set A in use - Currently filtering your pool water
- Set B drying - Previously cleaned cartridges air-drying completely
- Rotation schedule - Swap sets every 2-4 weeks depending on pool usage and environmental factors
- Thorough drying - Always allow cartridges to dry completely between uses, as this helps kill bacteria and makes future cleaning easier
Cleaning Frequency Guidelines
Your cleaning schedule depends on several factors:
- Every 2 weeks - Heavy pool usage, frequent storms, or nearby construction
- Every 3-4 weeks - Normal residential use with proper water chemistry
- Monthly - Light usage pools with excellent chemical balance
- Pressure gauge indicator - Clean when pressure rises 8-10 PSI above the clean filter reading
When to Replace vs. Clean
Cartridge filters aren't permanent and require replacement when:
- Pleats won't come clean - Persistent gray or brown discoloration after chemical cleaning
- Fabric breakdown - Frayed edges, loose pleats, or visible tears in the filter media
- Shortened cycles - Pressure builds up quickly even after thorough cleaning
- One year mark - Most cartridges need replacement annually with proper maintenance
- End cap damage - Cracked or damaged plastic end caps that allow bypass
Common Cleaning Mistakes to Avoid
- Using a pressure washer - High pressure can damage the filter media and reduce effectiveness
- Cleaning with pool chemicals - Never use chlorine, acid, or other pool chemicals directly on cartridges
- Insufficient rinsing - Soap residue or cleaning chemicals left on the filter can cause foaming
- Reinstalling wet cartridges - Moisture can promote bacterial growth and reduce filter life
- Ignoring the housing - Clean the filter housing interior while cartridges are out
Maintaining Water Chemistry
Proper water balance extends cartridge life significantly:
- pH levels - Maintain 7.4-7.6 to prevent premature filter media breakdown
- Free chlorine - Keep Free Chlorine (FC) at appropriate levels (1-4 ppm) based on your CYA level
- Total alkalinity - Maintain 80-120 ppm for pH stability
- Calcium hardness - Keep within range to prevent scaling on filter media
Regular testing with a quality test kit like the Taylor K-2006 helps maintain these parameters and reduces filter cleaning frequency.
