How Pool Filter Sand Works: Complete Filtration Guide
Can someone explain exactly how sand filtration works in pools?
Called in sick Friday to prep for swapping my pool's cartridge filter to sand this Saturday — what exactly makes sand filtration work so my setup goes smooth?
I have a 20,000 gallon inground pool with a Pentair sand filter that I inherited from the previous homeowner. While it seems to be working fine - my water stays clear and my chemical levels are balanced (chlorine at 2.5 ppm, pH at 7.4) - I'm curious about what's actually happening inside that big tank.
Specifically, I'd like to know how the sand physically captures debris and particles, what size particles it can actually filter out, and how the water flows through the system. I've read conflicting information online about whether smaller particles just pass right through or if the sand bed actually catches them. Understanding this would help me make better decisions about maintenance and when to replace the sand.
Pool filter sand works by creating a filtration bed that physically traps particles as small as 20-40 microns. Water flows down through the sand bed, where debris gets caught between sand grains, then clean water flows back up through the laterals to your pool.
The Sand Filtration Process
Sand filtration works through three distinct mechanisms that work together to clean your pool water effectively. Understanding this process helps you maintain your filter properly and troubleshoot issues when they arise.
Physical Straining
The primary filtration method is physical straining, where particles larger than the spaces between sand grains get trapped. #20 silica sand (the standard pool filter sand) has grains sized between 0.45-0.55mm with an effective size (D10) that should meet manufacturer specifications, creating microscopic pathways that catch debris. As water flows down through the sand bed, larger particles get stuck near the top, while smaller particles penetrate deeper before being trapped.
This layered filtration effect means your sand filter becomes more effective over time as trapped debris creates even finer filtration spaces. A slightly "dirty" sand filter actually filters better than a freshly backwashed one, which is why you shouldn't backwash too frequently.
Biological Filtration
Within 2-4 weeks of operation, beneficial bacteria colonize the top 2-3 inches of your sand bed, creating a biological layer. These bacteria consume organic matter and help break down oils, lotions, and other contaminants that physical straining alone cannot remove. This biological layer is crucial for optimal filtration performance.
Warning: Never use antibacterial products or excessive chlorine shocking directly in your filter, as this destroys the beneficial bacterial layer and reduces filtration effectiveness.
Electrochemical Attraction
Sand grains develop a slight negative charge that attracts positively charged particles through electrochemical forces. This helps capture very fine particles that might otherwise pass through the physical spaces in the sand bed.
Water Flow Pattern Through Sand Filter
Understanding the water flow pattern helps explain why proper sand depth and lateral placement are critical for effective filtration.
- Water Entry: Pool water enters through the multiport valve and flows down through the sand bed from the top
- Downward Flow: Water moves down through 18-24 inches of sand, with particles being trapped at various depths based on their size
- Lateral Collection: Clean water reaches the bottom laterals, which are slotted pipes that collect filtered water
- Return Flow: Filtered water flows up through the center pipe and back to your pool
The key to this process is maintaining proper water flow velocity. Too fast, and particles don't have time to be trapped. Too slow, and you don't get adequate circulation. Most residential sand filters operate optimally at 10-15 gallons per minute per square foot of filter surface area for conventional rate filtration (high-rate filters typically operate at 15-20 GPM per square foot).
Particle Size Removal
Sand filters effectively remove particles in the 20-40 micron range, making them highly effective for most pool contamination. Here's what different sized particles look like:
- 40+ microns: Visible debris, leaves, insects, large algae
- 20-40 microns: Fine dirt, small algae, pollen
- 10-20 microns: Dead algae spores, fine dust (requires filter aid)
- Under 10 microns: Requires additional chemical treatment or filter aids like DE powder
For comparison, human hair is about 100 microns thick, so sand filters remove particles much smaller than what your eye can easily see.
Maintaining Your Sand Filter
Proper maintenance ensures your sand filter operates at peak efficiency and lasts its full 5-7 year lifespan.
Backwashing Schedule
Monitor your pressure gauge and backwash when pressure rises 8-10 PSI above the clean starting pressure. This typically occurs every 2-4 weeks during swimming season, depending on bather load and environmental factors.
Chemical Balance Impact
Maintain proper water chemistry to protect your sand filter:
- pH: Keep between 7.2-7.6 to prevent sand degradation
- Free Chlorine: Follow FC/CYA chart - typically 1-3 ppm for CYA of 30-50 ppm
- Calcium Hardness: 250-350 ppm prevents sand from dissolving
- Total Alkalinity: 80-120 ppm (60-80 for salt water pools)
Sand Replacement
Replace filter sand every 5-7 years or when backwashing no longer effectively cleans the filter. Signs you need new sand include: persistently cloudy water, frequent backwashing needs, or channeling (water taking shortcuts through the sand bed rather than filtering properly).
If your sand filter isn't performing well, check these common problems:
- Short filter runs: Usually indicates high contamination load - test and balance chemistry first
- Cloudy water after backwashing: Normal for first few hours as beneficial bacteria layer rebuilds
- Sand in pool: Indicates broken laterals or standpipe - requires filter inspection
- Poor filtration despite backwashing: May need sand replacement or deep cleaning with filter cleaner
