How Long Pool Cartridge Filters Last: Complete Guide
Kim N.
Pool Service Hobbyist
When should I replace my cartridge filters? Pool store says monthly
Pulled another cartridge filter out of my pool after just one month and it's completely shot — this thing is burning through filters way faster than it should. They're expensive and I'm wondering if I'm being upsold.
How often do cartridge filters actually need to be replaced versus just cleaned? I've been hosing mine off when they get dirty, but I'm not sure when I should throw in the towel and buy new ones. What's the real lifespan I should expect?
Pool cartridge filters typically last 2-4 weeks between cleanings and should be replaced every 12 months or after 15-20 cleaning cycles, depending on pool usage and water conditions.
Understanding Cartridge Filter Lifespan
Cartridge filters have two distinct lifespans to consider: the time between cleanings and the total filter life before replacement. Unlike sand or DE filters that can last years with proper maintenance, cartridge filters are consumable items designed for periodic replacement.
Time Between Cleanings
Most cartridge filters require cleaning every 2-4 weeks during swimming season. However, this interval can vary significantly based on several factors:
Total Filter Replacement Schedule
The physical filter cartridge itself should be completely replaced after 12 months of use or 15-20 cleaning cycles, whichever comes first. Each cleaning cycle gradually breaks down the filter media, reducing filtration effectiveness and increasing pressure drop across the filter.
Factors Affecting Filter Lifespan
Water Chemistry Balance
Proper water chemistry significantly extends cartridge life. Maintain these target ranges using accurate testing with a Taylor K-2006C test kit:
Imbalanced chemistry can clog filters prematurely. High calcium levels cause scaling, while low pH can damage filter media. Always test and adjust chemistry before assuming filter problems.
Environmental Conditions
Environmental factors dramatically impact filter lifespan:
Pool Usage Patterns
Bather load directly correlates with filter cleaning frequency. Each swimmer introduces oils, lotions, dead skin, and hair that accumulate in filter pleats. Pools hosting frequent parties or having many regular swimmers need more aggressive maintenance schedules.
Signs Your Cartridge Filter Needs Attention
Cleaning Required
Watch for these indicators that cleaning is needed:
Replacement Required
Replace cartridge filters when you notice:
Maximizing Cartridge Filter Life
Proper Cleaning Technique
Use this method to maximize filter life during cleaning:
  1. Remove cartridge from filter housing following manufacturer instructions
  2. Rinse with garden hose spray at 45-degree angle to pleats, working from inside to outside of each pleat
  3. For heavy buildup, use cartridge cleaner solution following label directions
  4. Never use pressure washers or brush aggressively
  5. Allow to air dry completely if using chemical cleaners
  6. Inspect for damage before reinstalling
Rotation System
Implement a two-cartridge rotation system. While one set filters the pool, the cleaned set dries completely. This prevents moisture-related issues and extends overall filter life by allowing complete drying between uses.
Water Chemistry Maintenance
Maintain proper water balance consistently. When addressing green or cloudy water, use the SLAM method (Shock Level And Maintain) with liquid chlorine rather than store-bought "shock" products. Monitor FC levels and maintain shock level continuously until both combined chlorine (CC) equals zero and all algae is eliminated, then resume normal chlorine levels based on your CYA reading.
Cost Considerations and Planning
Budget approximately $40-120 annually for cartridge replacements, depending on filter size and brand. High-quality filters like Unicel or Pleatco may cost more initially but often provide better filtration and longer life than generic alternatives.
Purchase replacement cartridges at the beginning of swimming season to ensure availability. Stock 2-3 sets to maintain proper rotation and avoid emergency purchases at premium prices.
Avoid these practices that shorten filter life:
pool test kit garden hose cartridge cleaner replacement cartridges
Tags: #cartridge filter #filter maintenance #filter replacement #pool filtration
