Does Walmart Have Pool Liners? Complete Shopping Guide 2024
Rachel J.
First-time Pool Owner
Can I buy a pool liner at Walmart? New pool owner needs help
Before I could even enjoy summer, my above-ground pool liner developed tears along the bottom, fading that makes it look ancient, AND wrinkles that won't smooth out. The pool store quoted me $200+ for a new liner, which seems pretty steep for my budget right now.
Does Walmart actually carry pool liners in stock? I've seen some pool stuff there before but wasn't sure if they'd have the right size or quality. Would love to save some money if possible, but also don't want to buy something that won't last. Any advice from experienced pool owners would be great!
Yes, Walmart does carry above-ground pool liners both in-store and online, typically stocking popular sizes like 24', 27', and 28' round pools, plus oval shapes. Their selection includes basic blue and printed patterns from brands like Summer Waves and Intex.
Step-by-Step Guide to Finding Pool Liners at Walmart
  1. Check Walmart.com first - Start your search online at Walmart.com using terms like "above ground pool liner" or your specific size like "24 foot pool liner." The website will show both items available for shipping and what's in stock at your local store.
  2. Verify your pool measurements - Before shopping, measure your pool's diameter (for round pools) or length and width (for oval pools), plus the wall height. Common sizes Walmart stocks include 12', 15', 18', 21', 24', 27', and 28' round pools, with wall heights of 48" or 52".
  3. Visit the seasonal section - In physical Walmart stores, pool liners are typically located in the seasonal/outdoor living section, usually available from March through August. The selection peaks in late spring and early summer.
  4. Check brand availability - Walmart commonly carries Summer Waves, Intex, and their own brand pool liners. These are typically overlap-style liners in basic blue or simple printed patterns like tile or mosaic designs.
  5. Compare prices with specialty retailers - While Walmart's prices are competitive for basic liners ($80-200 for most sizes), compare costs with pool supply stores like Leslie's, In The Swim, or local pool dealers who may offer better quality materials.
  6. Verify return policy - Confirm Walmart's current return policy for pool liners, as seasonal items sometimes have different terms. Keep your receipt and original packaging until installation is complete.
  7. Consider installation requirements - Walmart liners are typically DIY-friendly overlap style, but ensure you have the necessary tools and skills for installation, or budget for professional installation.
What Types of Pool Liners Does Walmart Carry?
Liner Styles Available
Walmart primarily stocks overlap liners, which are the most common and easiest to install for above-ground pools. These liners drape over the pool wall and are secured with clips or a coping strip. You're unlikely to find beaded liners (which snap into a track) or j-hook liners (which hook into a receiver) at Walmart, as both require specific track systems built into the pool wall.
Material Quality
Most Walmart pool liners are made from 20-gauge vinyl, which is adequate for basic use but thinner than premium 25 or 28-gauge liners offered by specialty retailers. The thinner material means lower cost but potentially shorter lifespan - expect 3-5 years versus 7-10 years for heavier gauge liners.
Pattern and Color Options
Walmart's selection typically includes:
Walmart vs. Specialty Pool Retailers
Advantages of Buying from Walmart
Limitations of Walmart's Selection
Installation Considerations
Tools You'll Need
If you purchase a liner from Walmart, ensure you have these installation tools:
Professional vs. DIY Installation
DIY installation is possible with overlap liners from Walmart, but consider professional installation ($300-600) if:
Alternative Shopping Options
If Walmart doesn't have what you need, consider these alternatives:
Important: Regardless of where you purchase your liner, proper water chemistry maintenance will extend its life significantly. Maintain proper pH levels (7.2-7.6), adequate sanitizer levels, and avoid over-chlorination which can degrade vinyl over time.
measuring tape pool dimensions internet access transportation for pickup
Tags: #walmart #pool-liner #shopping #above-ground-pools #replacement-liner
