Do Pools Need Cyanuric Acid? Complete CYA Guide
Jessica N.
Pool Newbie
Should I add stabilizer to my pool when reopening after winter?
After balancing pH, adding shock, running clarifier, and treating algae — my pool still looks off and I'm wondering if missing cyanuric acid is the culprit. My pool store keeps pushing cyanuric acid (stabilizer) but I'm not sure if it's really necessary or just an upsell. Last season I had trouble keeping my chlorine levels steady and wonder if missing stabilizer was the issue. Do I really need to add CYA to my pool, or can I skip it and save some money?
Most outdoor pools need cyanuric acid (CYA) to protect chlorine from UV degradation, but indoor pools and those using alternative sanitizers may not require it. Proper CYA levels should be maintained between 30-50 ppm for optimal chlorine efficiency.
Understanding Cyanuric Acid's Role in Pool Chemistry
Cyanuric acid (CYA), commonly called pool stabilizer or conditioner, serves as chlorine's bodyguard against the sun's ultraviolet rays. Without this protection, UV light rapidly breaks down free chlorine, leaving your pool vulnerable to algae and bacteria growth. For most outdoor pools, CYA is absolutely essential for maintaining effective sanitization.
The science is straightforward: unstabilized chlorine in direct sunlight loses most of its effectiveness within hours. With proper CYA levels, that same chlorine remains active throughout the day, dramatically reducing your chemical costs and maintenance headaches.
When Your Pool Needs Cyanuric Acid
Outdoor pools using liquid chlorine, granular chlorine, or salt water chlorine generators definitely need CYA. These chlorine sources contain no built-in stabilizer, making them extremely vulnerable to UV degradation. You'll want to maintain CYA levels between 30-50 ppm for optimal performance.
Pools using trichlor tablets or dichlor shock already contain cyanuric acid, so additional stabilizer may not be needed initially. However, these products continuously add CYA with each dose, which can lead to overstabilization over time.
Special Situations Where CYA Isn't Needed
Proper CYA Levels and Testing
Target CYA levels depend on your sanitization method. For liquid chlorine or salt pools, I recommend maintaining 30-50 ppm. This range provides excellent UV protection without overstabilizing your chlorine. Higher levels require proportionally more chlorine to achieve the same sanitizing effect.
Use the CYA calculator to determine your proper chlorine targets based on your current stabilizer levels. Remember that CYA doesn't break down naturally - it only leaves your pool through water removal via backwashing, splashing, or draining.
Testing CYA Accurately
Standard test strips are notoriously unreliable for CYA measurement. You'll get much better results using a turbidity test kit or taking a sample to a pool store with proper testing equipment. Test CYA levels monthly during swimming season, as levels change slowly over time.
Adding Cyanuric Acid to Your Pool
Cyanuric acid comes in granular form and dissolves slowly in pool water. The easiest application method is to add the required amount to your skimmer basket with the pump running. This allows gradual dissolution and even distribution throughout your pool.
Calculate the needed amount carefully - it's much easier to add more CYA than to remove excess. For a typical 20,000-gallon pool, raising CYA by 10 ppm typically requires approximately 13 ounces of stabilizer (always verify dosage with your specific product manufacturer as formulations vary).
Application Tips
  1. Add CYA when the pump will run for at least 8-12 hours
  2. Avoid adding more than 1 pound per 10,000 gallons at once (consult product instructions for your specific brand). Use proper safety equipment including gloves and eye protection when handling chemicals
  3. Wait 24-48 hours before retesting CYA levels
  4. Brush any undissolved granules toward return jets
The Overstabilization Problem
While CYA protects chlorine from UV rays, too much creates serious problems. Overstabilized pools require excessive chlorine levels to maintain sanitation, making shock treatments less effective and algae problems more likely. This is why understanding your pool's complete water chemistry picture is crucial.
CYA levels above 80-100 ppm generally reduce chlorine effectiveness, with many pool professionals noting that very high levels (often 100+ ppm) can make chlorine sanitization challenging. The only cure for overstabilization is partial water replacement, as CYA doesn't break down naturally.
Seasonal Considerations and Maintenance
When reopening your pool after winter, test CYA levels before adding any chlorine products. If you used trichlor tablets the previous season, you likely have adequate stabilizer already. Pools closed with liquid chlorine may need fresh CYA addition.
Throughout the swimming season, monitor how your CYA levels trend. Pools using stabilized chlorine products will see gradual increases, while those using liquid chlorine or salt systems typically maintain stable levels once established.
For pools requiring frequent water addition due to evaporation or splash-out, CYA levels remain relatively stable since the stabilizer doesn't evaporate. However, significant water loss from leaks or extensive backwashing will reduce CYA levels proportionally.
CYA test kit Pool calculator Measuring cup
Tags: #cyanuric acid #stabilizer #chlorine protection #UV protection #pool chemistry
