Do You Need Pool Stabilizer? Complete CYA Guide
Should I be using stabilizer in my swimming pool?
Walked into the pool store and they're pushing $30 stabilizer on me — can't afford their markup right now, is this chemical actually necessary? Some people say it's essential, others say it causes problems. Is stabilizer something I actually need to add to my pool water, or can I skip it?
Pool stabilizer (cyanuric acid) is essential for outdoor pools to protect chlorine from UV degradation. Indoor pools and some salt systems may not need it, and too much can reduce chlorine effectiveness.
Understanding What Pool Stabilizer Does
Yes — you need pool stabilizer if you use chlorine, because without it, the sun destroys up to 90% of your chlorine within hours. Without it in outdoor pools, the sun's UV rays will destroy your free chlorine within hours, making it nearly impossible to maintain proper sanitizer levels.
The answer to whether you need stabilizer depends entirely on your pool type and location. Outdoor pools almost always require stabilizer, while indoor pools typically don't need any.
When Stabilizer Is Essential
You'll definitely want stabilizer if you have an outdoor pool using liquid chlorine, bleach, or cal-hypo shock. The sun destroys unstabilized chlorine rapidly - I'd recommend maintaining CYA levels between 30-50 ppm for most outdoor pools.
Salt water pool owners should note that many salt cells may produce their own stabilized chlorine, so you may not need to add additional CYA. Check your salt system specifications first.
The Stabilizer Balancing Act
Here's where it gets tricky - while stabilizer protects chlorine from UV, it also reduces chlorine's killing power. Too much CYA can reduce chlorine effectiveness, sometimes called "chlorine lock," where your chlorine may become less effective against algae and bacteria.
Target levels depend on your chlorine type:
- Liquid chlorine/bleach: 30-50 ppm CYA
- Trichlor tablets: Often builds up naturally, monitor carefully
- Cal-hypo: 30-50 ppm CYA
- Salt pools: Usually 70-80 ppm, but verify with manufacturer
You can check your current CYA level with a proper test kit and use our CYA calculator to determine if adjustments are needed.
When to Skip Stabilizer
Indoor pools rarely need stabilizer since there's no UV exposure. Adding CYA to an indoor pool just reduces your chlorine's effectiveness without providing any benefit.
Some pool owners prefer unstabilized chlorine systems, accepting higher chlorine consumption in exchange for maximum sanitizing power. This approach works but requires more frequent dosing and higher chemical costs.
Managing High Stabilizer Levels
Many pool owners discover they have too much CYA, often from using trichlor tablets exclusively. Once CYA exceeds 50-60 ppm, your chlorine typically becomes less effective, requiring higher FC levels to maintain proper sanitation.
Unfortunately, stabilizer doesn't break down naturally. The only ways to reduce CYA are partial water replacement or using a reverse osmosis service. This is why monitoring CYA levels regularly prevents expensive corrections later.
Adding Stabilizer Correctly
If testing shows you need stabilizer, add cyanuric acid gradually. Granular stabilizer dissolves slowly and works best when pre-dissolved in a bucket of pool water before adding to the pool.
Start with small amounts - it's much easier to add more stabilizer than to remove excess. Retest CYA levels 2-3 days after addition, as it takes time to fully dissolve and circulate.
