Can Salt Water Pool Turn Hair Green? Prevention & Solutions
Salt water pool turning my blonde hair green - what's causing this?
Planning to enjoy our new 25,000 gallon saltwater pool this summer, but I'm completely stumped why my daughter's blonde hair keeps turning green after every swim. I always thought salt water pools were supposed to be gentler than traditional chlorine pools, so I'm confused about what's happening here.
My salt cell has been running normally and chlorine levels test around 2-3 ppm, which seems right. The pH hovers around 7.4 and alkalinity is at 120 ppm. I've tried different shampoos and even bought a clarifying treatment, but the green keeps coming back after she swims. Is there something in salt water that causes this discoloration, or am I missing something with my water chemistry? I really want to figure out how to prevent this from happening again.
Salt water pools can turn hair green due to copper in the water reacting with chlorine. Proper water balance and copper removal prevent green hair discoloration. Regular testing and maintenance are crucial.
Why Salt Water Pools Cause Green Hair
The green hair phenomenon occurs when copper ions dissolve into your pool water and then oxidize in the presence of chlorine. In salt water pools, several factors make this more likely:
- Constant chlorine production: Your salt chlorine generator continuously produces chlorine, maintaining consistent oxidizing conditions
- pH fluctuations: Salt water systems tend to drive pH higher, so they need regular acid; the thing to avoid is letting pH stay low, since sustained acidic (corrosive) water is what dissolves copper from heaters and plumbing
- Copper heat exchangers: Many pool heaters use copper components that can leach copper into the water
- Copper-based algaecides: Some pool owners add copper algaecides without realizing the hair-staining potential
- Corrosion: Low pH conditions can corrode copper plumbing, releasing copper into the water
Testing and Identifying Copper Levels
Before addressing green hair issues, test your copper levels using a reliable test kit. A quality copper test (a copper drop-test kit or copper test strips) provides accurate readings. Copper levels should be zero in swimming pools - any detectable copper (above 0.1 ppm) can potentially cause hair staining.
You should also test your complete water chemistry:
- Free Chlorine (FCFree Chlorine — The chlorine actively sanitizing your water right now. This is the number you keep an eye on. how much you need →): Set your FC target based on your CYACyanuric Acid (stabilizer) — Sunscreen for your chlorine — it keeps sunlight from burning it off. The catch: the more you have, the more chlorine you need to keep. learn more → level (FC is a percentage of CYA, not equal to it) using the all-in-one pool calculator
- pH: Maintain 7.4-7.6 for salt water pools
- Total Alkalinity (TATotal Alkalinity — The buffer that keeps your pH from bouncing around. Get this in range and pH gets a lot easier to manage. learn more →): Keep at 60-80 ppm for salt chlorine generators
- Cyanuric Acid (CYA): Target around 70-80 ppm for an outdoor salt chlorine generator - salt pools run higher CYA than plain-chlorine pools (check manufacturer specifications for your specific salt chlorine generator)
- Calcium Hardness: 250-350 ppm for plaster pools, 175-225 ppm for vinyl/fiberglass
Removing Copper from Your Salt Water Pool
If testing reveals copper in your water, you'll need to remove it before it can stain hair. Here's the proper approach:
Step 1: Stop the Copper Source
First, identify and eliminate the copper source:
- Check if you've used copper-based algaecides recently
- Test your pH history - has it dropped below 7.0 recently?
- Inspect copper plumbing and heat exchanger components
- Consider your water source - some well water contains copper
Step 2: Use a Metal Sequestrant
Add a quality metal treatment product like CuLator Metal Eliminator (physical removal) or ProTeam Metal Magic (sequestrant). Follow manufacturer's dosing instructions, typically:
- CuLator: One pouch treats up to 20,000 gallons for 30 days
- Liquid sequestrants: Usually 1 quart per 20,000 gallons initially
Important: Run your salt chlorine generator at reduced output (25-50%) while treating with sequestrants to avoid interference.
Step 3: Maintain Proper Water Balance
Keep your water chemistry in the ideal ranges mentioned above. This prevents future copper dissolution and ensures your salt system operates efficiently.
Preventing Green Hair in Salt Water Pools
Prevention is always better than treatment. Follow these strategies:
- Test copper monthly: Regular testing catches problems early
- Maintain stable pH: Avoid rapid pH swings that can dissolve copper from plumbing
- Use quality test kits: Taylor K-2006C provides accurate readings for salt water pools
- Avoid copper algaecides: Use polyquat algaecides (such as 60% concentration polyquaternary ammonium) instead of copper-based products
- Regular water testing: Test FC, pH, and TA 2-3 times weekly during swimming season
Treating Hair That's Already Green
If hair is already discolored, these methods can help:
- Clarifying shampoo: Use a strong clarifying shampoo designed for swimmers
- Baking soda paste: Mix baking soda with water, apply for 5-10 minutes, then shampoo
- Lemon juice: The acid can help break down copper deposits
- Professional products: UltraSwim or Malibu C products are specifically designed for this issue
Many salt water pool owners make these errors that worsen green hair problems:
- Ignoring pH drift: Salt systems naturally raise pH, requiring regular acid additions
- Over-shocking: Excessive chlorine levels accelerate copper oxidation
- Using the wrong algaecide: Always choose polyquat-based algaecides for salt water pools
- Neglecting regular testing: Monthly copper testing prevents surprise staining incidents
Contact a pool professional if:
- Copper levels remain high after treatment
- You suspect copper plumbing corrosion
- Water chemistry remains unstable despite proper maintenance
- Your salt chlorine generator isn't producing adequate chlorine
Remember, salt water pools require different maintenance approaches than traditional chlorine pools. The key to preventing green hair is maintaining proper water balance and eliminating copper sources before they become a problem.
