Is it safe to filter my pool water for drinking during emergencies?
I've seen some advanced water filtration systems advertised that claim to remove chemicals and contaminants. Would something like reverse osmosis or activated carbon filtration be able to remove all the pool chemicals like chlorine, cyanuric acid, and other sanitizers to make it safe for drinking? I'm concerned about the health risks but need to understand if there are any reliable methods that could work in an emergency situation.
You can make pool water drinkable in an emergency — a maintained pool actually starts cleaner than a stream. Chlorine is easy to remove and germs are caught by a 0.1-micron backpacking filter; the real limits are dissolved cyanuric acid and salt, which need reverse osmosis or distillation, not pool filters.
The honest answer: a maintained pool is a legitimate emergency reserve
Because a balanced pool is continuously chlorinated, its bacteria and virus load is already far lower than untreated wild water. That makes it a reasonable backup source in a water outage. The reason it's "not practical" isn't that it's poisonous — it's that pool water carries dissolved chemistry (stabilizer, salt, sometimes metals) that simple filters leave behind. So use tap, bottled, and stored water first; reach for the pool only when those run out.
What's actually in pool water — and how risky is it?
Chlorine — the one everyone worries about, and shouldn't
Pool chlorine is the same hypochlorous acid and hypochlorite that disinfects municipal drinking water. The EPA allows up to 4 ppm of chlorine residual in tap water, and a balanced pool typically runs around 1-4 ppm free chlorine (higher right after shocking). There's no special "pool form" of chlorine that makes it more dangerous to drink — and it's the easiest thing to deal with. Let water sit uncovered in sunlight for a day and the chlorine gases off on its own; any activated-carbon filter strips it in seconds; boiling drives it off too.
Cyanuric acid (CYA / stabilizer)
A typical outdoor pool holds 30-80 ppm of CYACyanuric Acid (stabilizer) — Sunscreen for your chlorine — it keeps sunlight from burning it off. The catch: the more you have, the more chlorine you need to keep. learn more →. It has low oral toxicity — the rat oral LD50 is around 7,700 mg/kg, which toxicologists class as low toxicity. The frightening kidney-stone research you may have seen is about cyanuric acid combined with melamine (the 2008 contaminated-food scandal), not CYA on its own at pool levels. The real issue with CYA is simply that it's a dissolved solid a backpacking filter can't remove — so it's a reason not to live on pool water indefinitely, not a reason one glass will hurt you.
Salt (saltwater pools only)
A saltwater pool runs about 2,700-3,400 ppm salt — brackish-tasting and not something you'd want to drink long-term, but only a fraction of seawater (~35,000 ppm) and not acutely dangerous in small amounts. Only reverse osmosis or distillation removes it. A traditional chlorine-tablet pool has negligible salt, so this only matters for salt-chlorinated pools.
Metals, algaecide and pH chemicals
These are the ingredients to actually steer clear of. If the pool has recently been treated with a copper-based algaecide or metal product, dosed with a metal sequestrant, or shocked to a high level, don't drink it. Day-to-day pH chemicals (muriatic acid, soda ash) are consumed in balancing the water and aren't a meaningful drinking hazard at normal levels.
Germs — where pool water beats wild water
Continuous chlorination keeps bacteria and viruses knocked down. The classic chlorine-resistant parasites — Cryptosporidium and Giardia — can survive chlorine for a while, but they're 4-12 microns across, so any 0.1-micron backpacking filter blocks them completely. The article you may have read elsewhere conflates "survives chlorine" with "survives a physical filter." It doesn't.
What happens if you swallow a little?
Not much. The mouthful or two you swallow while swimming is harmless — just rinse with clean water afterward. Swallowing a larger amount of heavily chlorinated water can cause nausea, stomach cramps, or vomiting, which usually pass on their own. Drink some clean water to dilute it and watch how you feel over the next 48-72 hours; call your doctor or poison control if symptoms are severe or persistent. Healthy, balanced pool water is not the "chemical burn and organ damage" hazard it's sometimes made out to be.
Why your pool's own filter won't make it drinkable
Your pump and filter clean the water you swim in — they are not water purifiers. They strain out dirt and debris but do nothing to dissolved chlorine, CYA, salt, or germs:
- Sand filters trap particles down to roughly 20-40 microns.
- Cartridge filters reach about 10-15 microns.
- DE (diatomaceous earth) filters get down to 1-3 microns — finer, but still no help with dissolved chemistry or the smallest pathogens.
So "I'll just run it through my pool filter" doesn't work. You need a drinking-water filter, not a pool filter.
How to actually make pool water drinkable (emergency steps)
- Use other sources first. Tap, bottled, and stored emergency water all beat pool water. Treat the pool as backup.
- Skip a recently treated pool. Don't use water that's just been shocked, dosed with algaecide or a copper/metal product, or had a fecal incident.
- Pre-filter for debris. Pour the water through a clean cloth or coffee filter to remove leaves and grit.
- Run it through a backpacking filter rated 0.1 micron or finer (Sawyer, Katadyn and similar). That removes the bacteria and protozoa. A model with an activated-carbon element also pulls out the chlorine and cleans up the taste.
- No carbon filter? Deal with the chlorine separately. Let the water sit uncovered in sunlight for a day so the chlorine gases off, or run it through a carbon pitcher filter.
- For real preparedness, distill or reverse-osmose it. A countertop distiller or RO unit makes pool water fully potable — salt, CYA and all. That's the only way to get genuinely clean drinking water from a saltwater pool.
Bottom line
You can filter pool water to drink, and a maintained pool is a legitimate emergency reserve that starts cleaner than a creek. The honest framing is "not practical," not "deadly": the chlorine is easy to remove, a backpacking filter catches the germs, and the only things that stay behind — cyanuric acid and salt — are low-toxicity and need distillation or reverse osmosis to strip out. Keep it as a backup plan, not your everyday tap.
