Is Pool Algae Dangerous? Health Risks of Swimming in Algae
Laura J.
Is swimming in algae-infested pool water dangerous?
Found green algae covering my pool after being away for two weeks. Shocked it twice, brushed the walls, ran the filter non-stop for 48 hours — water's still green as swamp water. My kids are begging to swim and asking if a little algae will hurt them. Replaced the cartridge filter yesterday and added more chlorine but I'm wondering about health risks while I'm fighting this mess.
Pool algae itself is generally not harmful, but it creates conditions that harbor dangerous bacteria and pathogens. Swimming should be avoided until proper sanitization is restored through effective algae treatment.
Don't Swim Until You Clear This Up
You need to keep everyone out of that pool right now. While algae itself typically won't harm you, it's creating a breeding ground for bacteria, parasites, and other pathogens that absolutely can make you sick. The green algae is consuming your chlorine and preventing proper sanitization — that's the real danger.
Your current approach isn't going to cut it. Two shock treatments and some brushing won't eliminate established algae blooms. You need to implement the SLAM method immediately to regain control of your water chemistry.
What Makes Algae-Infested Water Dangerous
The algae creates a protective biofilm that shields harmful microorganisms from your sanitizer. Behind that green curtain, you could have E. coli, Cryptosporidium, Giardia, or Legionella thriving in your pool. These pathogens cause everything from stomach illness to serious respiratory infections.
Algae also makes your pool surfaces incredibly slippery, creating slip-and-fall hazards around steps, ladders, and pool edges. The cloudy water obscures the bottom, making it impossible to see swimmers in distress.
Immediate Action Plan
Test your water right now using a reliable test kit. You need to know your Free Chlorine (FC), Combined Chlorine (CC), pH, Total Alkalinity, and Cyanuric Acid (CYA) levels before proceeding.
Your shock level needs to be based on your CYA reading — not guesswork. Use our chlorine calculator to determine the proper SLAM target level. You'll likely need to maintain elevated FC levels - use a reliable calculator to determine the proper SLAM target based on your specific CYA reading.
Here's your priority sequence:
  1. Adjust pH to 7.2-7.4 range first
  2. Calculate and add your SLAM dose of liquid chlorine
  3. Brush all surfaces thoroughly — this breaks up the biofilm
  4. Run your filter continuously
  5. Test FC levels every few hours and maintain SLAM level
  6. Backwash or clean filter when pressure rises significantly above clean pressure (consult your filter manufacturer's guidelines)
When It's Safe to Swim Again
Don't let anyone in the water until you've completed the full SLAM process. You'll know you're done when:
This process typically takes several days to over a week depending on algae severity, pool size, filtration system, and water chemistry - completion time varies significantly. I know it's frustrating with eager swimmers, but cutting corners puts their health at risk.
Filter Maintenance During Treatment
That cartridge filter you just replaced is going to get clogged quickly with dead algae. You'll need to clean or replace it multiple times during SLAM treatment. Consider having backup cartridges on hand, or upgrade to a sand or DE filter that handles algae removal more efficiently.
Don't rely on clarifiers or algaecides right now — they'll interfere with the sanitization process. Chlorine and proper circulation are your primary weapons against this problem.
Preventing Future Outbreaks
Once you've regained control, maintain consistent FC levels based on your CYA reading. Follow proper water chemistry guidelines and don't let sanitizer levels drop, especially during hot weather or heavy bather loads.
Regular brushing, proper filtration, and balanced water chemistry prevent algae from gaining a foothold in the first place. It's much easier than fighting established blooms like you're dealing with now.
liquid chlorine test kit pool brush pH adjuster
Tags: #algae #health risks #SLAM method #water safety
