How to Raise Pool Stabilizer (CYA) Levels - Complete Guide
What's the proper dosage to increase cyanuric acid in my pool?
Wondering if my three-year-old pool that's burning through chlorine way too fast with CYA at 15ppm needs more stabilizer or has a bigger issue?
What's the standard dosage rate for cyanuric acid, and what target levels should I be aiming for? I have a standard chlorinated pool, not a salt water system, so I want to make sure I don't overdose and create other water balance issues.
To raise pool stabilizer, add cyanuric acid at a rate of 1 pound per 3,000 gallons to increase CYA by approximately 30ppm. Target levels are 30-50ppm for regular pools or 70-80ppm for salt water generators.
First, Let's Diagnose Your Stabilizer Situation
Nothing ruins a perfectly balanced pool faster than watching your chlorine disappear within hours, leaving you with cloudy water and a hefty chemical bill. Low stabilizer typically occurs in new pools, after heavy dilution from splash-out and refilling, or following a partial drain and refill.
Test your water using a reliable test kit - the Taylor K-2006C is the gold standard for accurate CYA readings. Strip tests are notoriously inaccurate for stabilizer levels. Your target CYA should be 30-50ppm for regular chlorine pools, or 60-80ppm if you have a salt water generator system.
Calculating Your Stabilizer Dosage
Once you know your current CYA level, calculate how much cyanuric acid you need. The basic formula is:
- 1 pound of cyanuric acid per 10,000 gallons raises CYA by approximately 13ppm
- For a 20,000-gallon pool going from 0 to 50ppm: (50 ÷ 13) × (20,000 ÷ 10,000) = approximately 7.7 pounds needed
- Always round down and add incrementally - you can't remove CYA easily once it's in
Warning: Never add more than you need. High CYA levels (over 100ppm) create chlorine lock, making sanitization nearly impossible and requiring partial water replacement.
Step-by-Step Stabilizer Addition Process
Method 1: Sock Method (Recommended)
- Place the calculated amount of cyanuric acid in a clean sock or mesh bag
- Tie the sock securely and place it in your pool skimmer basket
- Run your pump continuously for 24-48 hours to slowly dissolve the stabilizer
- Move the sock occasionally to prevent it from blocking water flow
- Remove the empty sock once all granules have dissolved
Method 2: Pre-Dissolution Method
- Fill a large bucket with warm pool water (never use hot water)
- Slowly add cyanuric acid while stirring constantly
- Continue stirring until most granules dissolve (this takes time)
- Pour the mixture slowly around the pool perimeter with pump running
- Brush the pool bottom to distribute any undissolved particles
Timing and Water Balance Considerations
Cyanuric acid dissolves very slowly, often taking 2-7 days to fully integrate into your water. During this period:
- Keep your pump running continuously for proper circulation
- Don't test CYA levels for at least 48-72 hours after addition
- Maintain normal chlorine levels - your FC/CYA ratio should follow TFP guidelines
- Avoid shocking the pool during dissolution period unless absolutely necessary
The stabilizer won't affect your pH significantly, but cyanuric acid is mildly acidic. Monitor pH levels and adjust if needed after the CYA has fully dissolved.
Testing and Verification
After 72 hours, retest your stabilizer level using your Taylor test kit. Follow the turbidity test procedure exactly:
- Fill the sample tube with pool water to the marked line
- Add the specified drops of stabilizer reagent
- Cap and invert the tube several times
- Look down through the sample for the black dot to disappear
- Read the CYA level where the dot vanishes
If your levels are still below target, repeat the addition process with a smaller dose. Remember, patience is key - rushing this process often leads to overdosing.
Stabilizer Won't Dissolve
If granules remain on your pool bottom after several days, increase circulation time and brush more frequently. Cyanuric acid dissolves best in moving water at normal pool temperatures (75-85°F).
Cloudy Water After Addition
Temporary cloudiness is normal when adding stabilizer. Continue running your filter and the water should clear within 24-48 hours. If cloudiness persists, check your filter system and consider backwashing or cleaning cartridges.
CYA Levels Too High
If you've overdosed, partial water replacement is your only option. Drain 25-50% of your pool water and refill, then retest. This is why conservative dosing is crucial.
Long-Term Stabilizer Management
Once properly balanced, CYA levels remain stable unless you drain water. However, monitor levels monthly during peak season and after any significant water replacement. Indoor pools typically need less stabilizer (around 30ppm) since UV protection is minimal, while outdoor pools in sunny climates benefit from slightly higher levels within the recommended range.
