How to Lower Pool Stabilizer (CYA) - Complete Guide
Melissa N.
Saltwater Pool Convert
Pool stabilizer too high - how to bring CYA levels down?
According to my test strips my pool's cyanuric acid is sky-high, my chlorine isn't working effectively, AND I'm getting that weird chemical smell all at once. Chlorine isn't working like it should and I'm pretty sure it's because the stabilizer levels are through the roof.\n\nIs there any chemical I can add to lower it? Or do I need to drain water? What's the fastest way to get CYA back to normal range?
The only effective way to lower pool stabilizer (cyanuric acid) is through partial drain and refill, as it doesn't break down naturally. You'll need to drain 1/3 to 1/2 of your pool water and refill with fresh water.
Pool Stabilizer: How to Reduce CYA Levels
Good news: lowering your pool's stabilizer levels is completely doable without calling a pool pro—though it does require some patience and elbow grease. Generally, levels above 50ppm for regular pools or 80ppm for salt water pools may require intervention. While complete chemical neutralization isn't possible, physical water replacement can effectively reduce levels.
Diagnosing High Stabilizer Levels
Confirm stabilizer levels using a reliable test method. Professional test kits using turbidimetric method are recommended over basic colorimetric test strips, which lack accuracy for CYA testing. Ensure proper sample preparation and reagent mixing for best accuracy.
Recommended Target Levels:
Elevated levels can lead to reduced chlorine effectiveness, potentially compromising water sanitation.
Causes of Stabilizer Accumulation
Stabilizer builds up through:
Stabilizer Reduction Process
Consult a pool professional for precise drainage calculations. General approach includes:
  1. Turn off pool equipment
  2. Test current chemical levels
  3. Verify local drainage regulations
  4. Drain partially according to professional guidance
  5. Refill with fresh water
  6. Allow 24-48 hours for water circulation and equilibration
  7. Test CYA levels and rebalance chemical levels
Prevention Strategies
Warning:
Consult a professional pool technician for specific guidance tailored to your pool's unique characteristics.
pool test kit submersible pump or drain valve garden hose pool chemicals calculator
Still need help? Ask a Pool & Spa Expert
Tags: #stabilizer #cyanuric acid #CYA #drain and refill #water balance
