How to Increase Pool Alkalinity - Step-by-Step Guide
Greg U.
What's the proper method to raise total alkalinity in my pool?
After testing my 10,000 gallon pool at dangerously low alkalinity levels, I'm standing in the pool supply store aisle staring at sodium bicarbonate, alkalinity increaser, and pH buffers with no clue which product I actually need. I've tested the water and confirmed the alkalinity is below optimal range.
What's the standard chemical treatment and dosage rate for raising total alkalinity? I want to follow proper water chemistry procedures, including appropriate testing intervals and gradual adjustment methods to avoid overshooting the target levels.
To increase pool alkalinity, add sodium bicarbonate (baking soda) at 1.5 lbs per 10,000 gallons to raise total alkalinity by 10 ppm. Test first, add chemicals gradually, and retest after 6 hours.
First, Let's Diagnose Your Alkalinity Problem
The real cause of cloudy water, burning eyes, and corroded pool equipment usually isn't chlorine levels—it's your alkalinity silently wreaking havoc behind the scenes. Total alkalinity (TA) acts as a pH buffer in your pool water, and proper levels are crucial for water balance and swimmer comfort.
Test your water using a reliable test kit - I recommend the Taylor K-2006 or Taylor K-2005 for accurate readings. Your target total alkalinity should be:
If your alkalinity is below these ranges, you'll likely notice pH that's difficult to maintain, frequent pH swings, or water that feels "sharp" to swimmers. Low alkalinity can also cause equipment corrosion and surface etching.
Calculate Your Sodium Bicarbonate Dosage
Sodium bicarbonate (baking soda) is the safest and most effective way to raise pool alkalinity. Commercial alkalinity increasers typically contain sodium bicarbonate as the primary ingredient but may include additional buffering compounds. Here's the dosing formula you need:
1.5 pounds of sodium bicarbonate per 10,000 gallons raises total alkalinity by 10 ppm
Let's work through an example: If you have a 20,000-gallon pool with alkalinity at 60 ppm and you want to reach 100 ppm, you need to raise it by 40 ppm. Your calculation would be:
Safety Warning: Never add more than 2 lbs per 10,000 gallons at one time, as this can cause cloudy water and pH spikes.
Step-by-Step Application Process
  1. Turn on your circulation system - Your pump should run throughout the entire process to ensure even distribution.
  2. Pre-dissolve the sodium bicarbonate - Fill a 5-gallon bucket with pool water and slowly add your calculated dose of baking soda while stirring. This prevents undissolved powder from settling on your pool surfaces.
  3. Pour around the pool perimeter - Walk around your pool while slowly pouring the dissolved solution, focusing on areas with good water movement like near return jets.
  4. Brush if necessary - If any undissolved powder settles on surfaces, brush it gently to help it dissolve completely.
  5. Continue circulation for 6 hours minimum - This allows the chemical to fully integrate and stabilize in your water.
  6. Retest your water - After 6 hours, test both alkalinity and pH levels to confirm your results.
Managing pH During Alkalinity Adjustment
Here's where many pool owners run into trouble: sodium bicarbonate will raise both alkalinity and pH. If your pH climbs above 7.8 during this process, you'll need to bring it down with muriatic acid before continuing.
The key is patience. Add your alkalinity increaser in smaller doses (1-1.5 lbs per 10,000 gallons), test after 6 hours, and adjust pH if needed before adding more. This prevents the frustrating cycle of constantly chasing chemical balance.
If you need to lower pH during this process, use muriatic acid in small amounts - dosing varies based on current pH and alkalinity levels, so start with small doses and test frequently. Always add acid to water, never water to acid, and pour into the deep end with your pump running.
Cloudy water after adding baking soda: This usually means you added too much too quickly. Continue running your filter, and the cloudiness should clear within 24-48 hours. Consider adding a clarifier if cloudiness persists.
pH keeps climbing: This is normal when raising alkalinity. Lower pH with small amounts of muriatic acid between alkalinity additions, and don't rush the process.
Alkalinity won't stay up: If alkalinity drops quickly after raising it, check for excessive aeration (waterfalls, fountains) or ensure you're not over-chlorinating, as high chlorine levels can interfere with accurate water testing.
Maintenance and Prevention Tips
Once you achieve proper alkalinity levels, maintain them by testing weekly and making small adjustments as needed. Heavy rain, swimmer load, and chemical additions all affect alkalinity over time.
Keep sodium bicarbonate on hand for minor adjustments - it's much cheaper to buy in bulk from pool supply stores than grocery store baking soda, though both are chemically identical.
Remember that proper alkalinity makes pH management much easier, so getting this right will save you time and frustration with overall water balance. Always adjust alkalinity first, then pH, then other chemical levels for best results.
Taylor test kit sodium bicarbonate 5-gallon bucket pool brush measuring cup
Tags: #alkalinity #sodium bicarbonate #water balance #pH buffer #pool chemistry
