How to Clear Green Pool Water: Complete Algae Treatment Guide
Melissa R.
Saltwater Pool Convert
Pool turned green overnight. What's the fastest way to clear it?
Woke up Monday morning to a pool that looked like a swamp — dark green water, can't see the bottom, and it smells terrible. Weekend guests are arriving Friday. Need to know the fastest way to get this thing back to swimmable condition without draining and refilling.
To clear green pool water, first diagnose the algae type and severity, then use the SLAM method by maintaining shock-level chlorine based on your CYA levels until the water clears completely.
First, Let's Diagnose Your Green Pool Problem
Most people don't realize that green pool water contains billions of microscopic algae cells that can multiply faster than any chemical treatment can kill them. Green pool water is almost always caused by algae growth, but the severity and type determine your treatment approach.
Look at your pool and assess the green color intensity:
Next, check if you can see the bottom of your pool. If you can see the main drain clearly, you're dealing with light algae. If you can't see past 2-3 feet deep, you have a heavy infestation.
Essential Water Testing Before Treatment
Grab your Taylor K-2006 test kit (which uses FAS-DPD titration method) or comparable FAS-DPD test kit and measure these crucial levels:
Safety Warning: Never mix different types of pool chemicals. Always add chemicals to water, never water to chemicals, and wear protective equipment.
The SLAM Method: Your Green Pool Solution
SLAM (Shock Level And Maintain) is the most effective method for clearing green pools. Here's how to execute it properly:
Step 1: Calculate Your Shock Level
Your shock level depends entirely on your CYA reading. Use this FC/CYA relationship:
If your CYA is above 80ppm, you'll need to partially drain and refill your pool before treatment becomes effective.
Step 2: Adjust pH First
Before adding chlorine, get your pH between 7.2-7.4 using muriatic acid. High pH makes chlorine less effective, so this step is crucial. Add acid slowly in the deep end with the pump running, then retest after 2 hours.
Step 3: Add Liquid Chlorine
Use only liquid chlorine (sodium hypochlorite) for the SLAM process. Avoid cal-hypo shock products as they'll raise your pH and calcium levels. Calculate your initial dose:
For every 10,000 gallons of water, add approximately 1 gallon of 12.5% liquid chlorine to raise FC by 6.4ppm. So if you need to go from 0ppm to 20ppm FC, you'll need roughly 3.2 gallons for a 10,000-gallon pool.
Add the chlorine around the perimeter of the pool with the pump running. Never pour all the chlorine in one spot.
Maintaining Shock Level Until Clear
Here's where many pool owners fail: you must maintain shock level continuously until the water clears completely. This means:
  1. Test FC every 2-4 hours during daylight hours
  2. Add more liquid chlorine whenever FC drops below shock level
  3. Run your pump 24/7 during treatment
  4. Clean your filter daily or backwash sand/DE filters
The algae is dying when your FC loss slows down significantly overnight (less than 1ppm loss). Continue until you can maintain shock level overnight with minimal chlorine consumption.
Filtration and Circulation Critical Points
Your filtration system works overtime during algae treatment:
Timeline Expectations and Troubleshooting
Light green pools typically clear within 24-48 hours using proper SLAM technique. Dark green pools may take 3-7 days of consistent treatment.
If your pool isn't clearing after 48 hours:
Post-Treatment Pool Maintenance
Once your pool passes the overnight chlorine loss test (OCLT) and water is crystal clear:
  1. Allow FC to drop naturally to your normal operating range (based on CYA level)
  2. Rebalance pH to 7.4-7.6 and TA to proper range
  3. Clean and sanitize all pool equipment that contacted algae-infected water
  4. Resume normal sanitation and testing schedule
Remember, green pools are preventable with consistent water testing, proper chlorine levels, and regular brushing. The SLAM method works every time when executed correctly, but patience and persistence are essential for complete algae elimination.
FAS-DPD test kit liquid chlorine muriatic acid pool brush telescopic pole
Tags: #SLAM method #algae treatment #liquid chlorine #pool chemistry #water testing
