How to Clear Cloudy Pool Water: Complete Step-by-Step Guide
My pool looks like chocolate milk - what's the fix?
Spent all weekend trying to decide between shocking my pool again or calling a professional for this cloudy water that appeared practically overnight. You literally can't see the bottom anymore, it's that cloudy. I'm guessing I need to do something with chemicals but honestly have no clue where to start.
Should I be testing the water first? And what about shocking it - is that even safe when it's this cloudy? Also wondering if I need to run my filter more or if there's a specific order I should be doing things in. Don't want to waste time (or money on chemicals) doing the wrong steps!
Clear cloudy pool water by first testing and balancing pH (7.4-7.6), then shock to proper FC/CYA levels, run filter 24/7, and maintain shock level until water clears completely.
Understanding What Causes Cloudy Water
Cloudy pool water results from microscopic particles suspended in your water that are too small for your filter to catch immediately. These particles can be organic matter (algae spores, bacteria, body oils) or inorganic matter (dust, pollen, chemical precipitates). The key to clearing cloudiness is creating the right chemical environment to kill organics and coagulate particles so your filter can remove them.
Before adding any chemicals, you need accurate readings of your current water balance. Use a quality test kit like the Taylor K-2006C to test:
- Free Chlorine (FC) - Your sanitizer level
- pH - Affects chlorine effectiveness and swimmer comfort
- Total Alkalinity (TA) - pH buffer
- Cyanuric Acid (CYA) - Chlorine stabilizer
- Calcium Hardness (CH) - Prevents equipment damage
Safety Warning: Never mix different types of pool chemicals, and always add chemicals to water, never water to chemicals.
Step 2: Balance pH First
Chlorine works most effectively when pH is between 7.4-7.6. If your pH is outside this range:
- pH too high (above 7.6): Add muriatic acid. Use 6-8 oz per 10,000 gallons to lower pH by 0.2 units
- pH too low (below 7.2): Add sodium carbonate (soda ash). Use 6 oz per 10,000 gallons to raise pH by 0.2 units
Wait 2-4 hours after adding pH adjusters for complete mixing and stabilization, then retest before proceeding.
Step 3: Determine Your Shock Level
The amount of chlorine needed depends on your CYA level. Use this FC/CYA relationship:
- CYA 30ppm: Shock level = 12ppm FC
- CYA 40ppm: Shock level = 16ppm FC
- CYA 50ppm: Shock level = 20ppm FC
- CYA 60ppm: Shock level = 24ppm FC
- CYA 70ppm: Shock level = 28ppm FC
- CYA 80ppm: Shock level = 32ppm FC
If your CYA is above 80ppm, you'll need to partially drain and refill your pool as chlorine becomes ineffective at higher stabilizer levels.
Step 4: Add Liquid Chlorine
Use liquid chlorine (sodium hypochlorite) rather than granular shock, as it won't add unnecessary chemicals or raise pH dramatically. Calculate the amount needed:
Formula: (Target FC - Current FC) × Pool gallons ÷ 96,000 = Gallons of liquid chlorine needed (assumes 12.5% sodium hypochlorite)
For example, if you need to go from 2ppm to 16ppm FC in a 20,000-gallon pool: (16-2) × 20,000 ÷ 120,000 = 2.33 gallons of liquid chlorine.
Add the chlorine around the perimeter of your pool with the pump running to ensure even distribution.
Step 5: Start the SLAM Process
SLAM (Shock Level And Maintain) is the most reliable method for clearing cloudy water:
- Maintain shock level FC 24/7 - Test FC every few hours and add chlorine as needed
- Run your filter continuously - 24 hours per day until clear
- Brush pool surfaces daily - Helps circulation and prevents dead spots
- Clean filter frequently - Backwash sand filters daily, clean cartridge filters every 12 hours
- Test and adjust - Check FC levels multiple times daily and dose accordingly
Step 6: Monitor Progress and Maintain
Your pool should start clearing within 24-48 hours. You'll know the SLAM is working when:
- Water clarity improves daily
- FC loss overnight becomes minimal (less than 1ppm)
- You can see the bottom of the deep end clearly
Continue the SLAM process until you pass the Overnight Chlorine Loss Test (OCLT) - losing less than 1ppm FC overnight indicates all contaminants are eliminated.
Using algaecide or clarifiers during SLAM: These products can interfere with the process and prolong clearing time. Chlorine is your primary tool.
Not running filter continuously: Intermittent filtration allows particles to resettle, prolonging the cloudy condition.
Inadequate FC levels: Shocking to shock level isn't enough - you must maintain that level consistently.
Ignoring CYA levels: Too much stabilizer renders chlorine ineffective, while too little wastes chlorine to sun degradation.
Prevention Strategies
Prevent future cloudiness by:
- Maintaining proper FC/CYA ratios daily
- Testing water 2-3 times per week
- Ensuring adequate filtration runtime (8-12 hours daily minimum)
- Regular brushing and skimming
- Proper bather load management
- Maintaining balanced water chemistry year-round
Following these comprehensive steps will restore crystal-clear water and help you maintain it long-term. The key is patience, consistency, and proper chemical balance rather than quick-fix products that often create more problems.
