How to Clear Cloudy Pool Water: Expert Troubleshooting Guide
Dave E.
Pool still cloudy after adding shock - what am I doing wrong?
Planning a pool party this weekend but my water turned cloudy three days ago and now looks like milk no matter what I add. My pool has been cloudy for over a week now and I've thrown everything at it - multiple bags of shock, algaecide, you name it. The water looks like milk and I can barely see the bottom. I'm pretty sure I've been adding chemicals but maybe not in the right order or amounts?
I have a feeling I might be missing something basic with my water chemistry, but I honestly don't know where to start troubleshooting this mess. How long should it actually take to clear up cloudy water when you do it right? I just want my pool back to crystal clear so we can actually use it this summer.
Clear cloudy pool water by first testing chemistry levels, then shocking to proper FC/CYA ratio, running filtration 24/7, and using clarifier if needed. Most cases resolve within 24-48 hours with proper chlorine levels.
First, Let's Diagnose the Root Cause
Why is my pool water cloudy?" is hands down the most common question we get from pool owners, and there's a good reason it stumps so many people. Before throwing chemicals at your pool, we need to identify what's creating the cloudiness. The most common culprits are inadequate chlorine levels, poor filtration, chemical imbalances, or algae beginning to bloom.
Start by examining your water closely. Is it a milky white cloudiness, greenish tint, or more of a dull hazy appearance? White cloudiness typically indicates filtration issues or chemical imbalances, while any green tint suggests algae growth requiring immediate SLAM treatment.
Using a reliable test kit like the Taylor K-2006C, test these critical parameters:
If your FC is below the recommended level for your CYA, this is likely your primary issue. Low chlorine allows contaminants and micro-organisms to multiply, creating cloudiness.
Step 2: Balance pH and Total Alkalinity First
Before addressing chlorine, get your pH in the proper range. If pH is above 7.6, chlorine becomes less effective. Add muriatic acid to lower pH—see manufacturer instructions for dosing as the amount needed varies based on starting pH and alkalinity levels, then retest.
If TA is too high (common cause of rising pH), you'll need to lower it using muriatic acid with the aeration method. Add acid to bring pH to 7.0-7.2, then aerate until pH rises back to 7.4-7.6. Repeat this process until TA reaches target range.
Step 3: Shock to Proper Chlorine Level
Once pH is balanced, bring your FC up to the appropriate shock level based on your CYA reading. Use liquid chlorine (sodium hypochlorite) rather than granular pool shock, which often contains calcium hypochlorite that can cloud water further.
For shock levels, follow the FC/CYA relationship:
Add liquid chlorine according to manufacturer specifications based on the product's sodium hypochlorite concentration (typically 10.5-12.5%). Always add chemicals to water, never water to chemicals, and ensure proper ventilation.
Step 4: Run Filtration System Continuously
Switch your pool pump to run 24/7 until water clears. Your filtration system is crucial for removing the particles causing cloudiness. Clean or backwash your filter before starting—a dirty filter can't effectively clear cloudy water.
For sand filters, backwash until water runs clear. For cartridge filters, remove and hose down thoroughly or replace if they're beyond cleaning. DE filters should be backwashed and recharged with fresh diatomaceous earth.
Step 5: Monitor and Maintain Shock Level
Test FC levels every few hours and add more liquid chlorine as needed to maintain shock level. This is the SLAM (Shock Level And Maintain) method. Don't let FC drop below shock level until your water is completely clear and you're passing the OCLT (Overnight Chlorine Loss Test).
The SLAM process typically takes 1-3 days for cloudy water, longer if algae is present. You'll know you're winning when FC levels stop dropping rapidly between doses.
Alternative Solutions for Persistent Cloudiness
If proper chemistry and filtration don't clear your pool within 48 hours, consider these additional steps:
Pool Clarifier
Add a quality clarifier like SeaKlear or BioGuard Polysheen Blue to help coagulate tiny particles your filter can catch. Follow label directions—typically 1 ounce per 5,000 gallons. Run filtration continuously and clean filter frequently as it captures clumped particles.
Flocculant Treatment
For severe cloudiness, flocculant drops particles to the pool bottom for vacuuming to waste. Turn off circulation, add floc according to directions, let settle 8-12 hours, then vacuum directly to waste. This removes water from your pool, so be prepared to refill.
When to Retest and Adjust
Retest water chemistry every 4-6 hours during treatment. Once water clears, perform the overnight chlorine loss test: note FC level at dusk, test again at dawn. If FC drops more than 1 ppm overnight, continue SLAM process.
After achieving crystal clear water and passing OCLT, reduce FC to normal maintenance levels for your CYA and resume regular testing schedule.
Prevention Moving Forward
Maintain proper FC levels daily, test chemistry 2-3 times weekly, clean filters regularly, and ensure adequate circulation. Consistent maintenance prevents future cloudiness issues and keeps your pool swim-ready.
pool test kit liquid chlorine muriatic acid pool clarifier clean filter cartridges
Tags: #cloudy water #pool chemistry #SLAM method #filtration #chlorine shock
